3rd Gen - 6x9's in the Front Doors
Old 10-02-2011, 11:00 PM
beckler's Avatar
As the title says, anyone think this is possible? The bass in the rear 6x9's is just too much of a stretch to feel in the front and I think if I add 6x9's somewhere in the front, the audio will be much better. Any idea's?
Old 10-02-2011, 11:15 PM
Impaqt's Avatar
Car: 88 Iroc-Z Convertible
Re: 3rd Gen - 6x9's in the Front Doors
Can it be done.. yes. But dont do it.
Get yourself a nice set of 6" woofers with a separate tweeter. Cut some plywood, Wrap it in Vinyl or carpet that matches the door.
THen put a sub in the back if you want Bass.
Old 10-03-2011, 12:43 AM
beckler's Avatar
Right now I have two JL's in the back. The audio coming from the speakers is fine, but it sounds awkward hearing that full sound behind me, and nothing on either side of me. It sounds like something's missing. I have a Grand Cherokee with the Infinity Sound System which is stock. I put six Rockford's in total. Two in the back doors, two in the front doors, and two tweeter's on the dashboard. It sounds perfect in there. I'm looking for a similar setup in the Camaro.
Old 10-03-2011, 08:29 AM
Impaqt's Avatar
What happened to your front speakers?
Old 10-03-2011, 12:41 PM
beckler's Avatar
The 4x6's in the front dash sound fine. Let me see if I can explain the issue better...
With the lack of the two front 6x9's, two issues come up.
One, the bass coming from the rear causes a slight echo throughout the car. It makes the bass sound slightly distorted when you're listening from the front seats. Adding two 6x9 bass/mid/hi's in the front doors would even out this bass distribution, stop that slight echo, and give the driver a more "fuller" sound experience.
The second issue; (If you have a second car that you normally drive, you should definitely notice this quicker). It takes me a few minutes to get used to the audio in the Camaro. The driver-side 4x6 is directly infront of the driver. So close, that the one speaker is the only one you really hear. It makes it sound a little lop-sided. (As if the opposite speaker isn't putting out equal power.) The 4x6 speaker sitting on the opposite side of you will always be alittle harder to hear, because it is so far away from your seat on the dash board. You SHOULD be hearing the driver side speaker through your LEFT ear. Instead, it's directly infront of you. The speakers in the Camaro are not spread apart like they are on in my Jeep. The Jeep's small tweeters are all the way in the far corner's by the A-Pillar. I hear the Left speaker with my left ear, and the right 6x9 with my right ear. These 4x6's are directly right infront of you. Adding two 6x9 bass/mid/hi's in the front doors will even out this audio distribution. Instead of just hearing my driver side 4x6, i'll hear my driver side 4x6 infront of me, my 6x9 to my left, and my 6x9 to my right. If we can figure out a way to integrate the 6x9's in the front doors, I'm telling you, it will make all the difference!
Old 10-03-2011, 12:52 PM
Impaqt's Avatar
6x9's are not the way to go. I've been doing car audio since these cars were brand new. back in the day, I did do a 6x9 or 2 in custom door panel despite my strong urging to not do that.
6x9's are simply not a sound speaker design from the get go. oblong woofers are prone to distort.
as I said before, you are much better off going for a nice set of 6" component speakers for the doors rather than another pair of 6x9's.
I pulled my 6x9's out in back and replaced those with a set of 5 1/4" Componants even. The subwoofer in the trunk provides plenty of bass with no "echo" at all. I have a COnvertible, so the accoustics are a bit different that yours, but I've never heard any sort of echo in car audio..... Cars simply are not big enough to reproduce an acoustical echo.
Old 10-04-2011, 08:30 AM
mrrman's Avatar
I used a Qlogic kick panel for the fronts, 2-6" round speakers and 2 tweeters
Old 10-04-2011, 10:10 PM
SWTWCGTA's Avatar
If you are wanting more mid bass up front I would suggest a 6 1/2" in the door and a 5 1/4" and tweeter set up in the kick panel. Then replace the rear 6X9 with another component set. If your sound stage sounds low up front you can put a tweeter in each A pillar and fire them directly at each other across the dash. This set up will provide an excellent sound stage in our cars.
Old 10-04-2011, 10:16 PM
cdoyle's Avatar
I agree, 6x9's are horrible speakers. I think they are only used by manufactures because they can get a little more low end out of them without using a subwoofer.
As already mentioned, if you want a better front stage. You can either put 6.5 in your doors and/or have kicks built. This would sound WAY better than putting 6x9's in the door.
In my car, once I start the system I'm actually deleting the rear speakers all together. Going for kicks, door, and subs.
Old 10-05-2011, 07:25 AM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
i've opted for components in the kicks myself in my last 3 installs. cost and work is a bit higher, but sound will be much better. If you've got power windows, you have to build out the door quite a bit to clear the window motor
Old 10-05-2011, 08:42 PM
beckler's Avatar
As far as the 6" components go, do those speakers produce bass and treble? Maybe I'll go for the 6" in the kick panels.
Old 10-05-2011, 09:11 PM
cdoyle's Avatar
You'll get some mid bass, but not a low bass sound from them. They are not designed for that and that's what a sub woofer is designed for. They'll come with a separate tweeter that you'll want to mount close to it.
Old 10-05-2011, 10:46 PM
Impaqt's Avatar
If you have subwoofers, you dont need more base from your component speakers. Bass below 120hz is omnidirectional. you cannot localize it. if you think you can tell the bass is coming from behind you, its probably second harmonics and rattling of various components of your car thats causing the "Directionality". Get some Dynamat. Stiffen your subwoofer enclosure. get a better amplifier. better subwoofers.
Old 10-08-2011, 01:22 PM
-srs-'s Avatar
Car: 1991 Z28 Vert
Ditto on the "6x9's suck". You're getting good advice about the kicks...take it!
Old 10-09-2011, 09:05 AM
The Project's Avatar
Car: 89 IROC
Engine: 305 TPI / ZZ4 cam
Transmission: Stage 2 700R4, LS1 driveshaft
Axle/Gears: Strange 3.42 w/ Auburn
You could also get an amp with a "phase" function that would allow you to bring the bass forward...Just a suggestion.
Mids in the kick is good advice.
Old 10-10-2011, 09:20 AM
Impaqt's Avatar
You can just flip the +/- Leads on the speaker to accomplish the same thing.
Old 10-10-2011, 09:24 AM
Car: 89 IROC
True, but it's a matter of preference where you want the bass sound to come from and the dial is fun to play with.
Old 10-17-2011, 05:37 PM
morrow's Avatar
Car: 92 Camaro Rs.R
Transmission: wc t-5
there right oblong speakers distort to easily. if your not looking for custom stuff but want a nice look and great sound, i will add, kick pannels and components are the way to go, the only bass you need will be from the sub, thats its soul purpouse, and if your trying to push it out of your 6x9s and any mid rand speaker, it will sistort, its not desighned for that, and you will loose clarity. use you speakers for mid and highs, leave the bas for you sub.... the fidelity will sound much better and use less power... im curently making new door panels to house 6501 polk components, mid woofer in the door, tweeter in the dash. mounting the same set in the same in the sail pannels as well, and im only using 1 10inch l5 kicker in the back running of a 1200 watt jl mono block... if i wanted to the sub alone could rattle ear drums.... but we all know that sound like crap so granted i have it turned down so it works with the rest of the system, and filles the car with a nice smooth low tone, without trying. so its always consistant, you could also try running a capasiter too.
Old 12-23-2011, 08:14 PM
spdmetl's Avatar
Is it worthwhile to put a 2-6 inchers in each door, at either end?
Old 12-24-2011, 04:23 AM
Car: 89 IROC
Depends on how much midbass you like. I used to run two in each door.
Old 12-26-2011, 06:33 PM
dcil's Avatar
One really good set of 6.5 components in the door with the tweeter down low will keep the front sound stage optimal. Tweeters low will keep the distance from your ears close to the same so that it doesn't interfere with timing. Ditch the 4x6's all together. A set of 6.5 mid-bass/woofers in the sail panels (no tweeter). I would put a small 4 channel amp on them for extra clarity and freq control, high pass the front at about 80hz low pass the rear at 100hz. Would be an incredibly clean sounding system. Then add a sub and amp in the back. You'll fall in love.
Frozer!!!
01-19-2024 04:55 PM
1992 Trans Am
05-10-2023 07:19 PM
1992 Trans Am
Exterior Parts for Sale
04-04-2016 12:50 PM
69 Six Pack
10-05-2015 07:51 PM
BlackTopKing
08-19-2015 12:13 PM
Quick Reply: 3rd Gen - 6x9's in the Front Doors
