white smoke from exhaust smells like fuel
Old 09-25-2011, 06:31 AM
thirdgeniroc87's Avatar
Car: 87 IROC-Z28
Transmission: 5 Speed
Hey guys just picked up an 87 IROC 5.0, 5 speed and need some help. Car was sitting for a while and had coolant leaks from lower intake manifold, removed intake and replaced lifters and adjusted rocker arms. Inaddition also replace cooling fan switch and coolant temp sensor. Engine is put back together and starts right up after playing with the timing a bit she runs just fine here is my dilema I have white smoke coming from exhaust it smells like fuel and not coolant and my oil and coolant are not showing sings of mixing ( drained old oil and coolant right away to check for contamination when first taking car home). My smog pump is seized so I don't know if this can cause my problems. I was thinking of getting a head gasket stop leak to see if it helps before I go digging into the motor. I figured if the smoke stopped or lessens then I will rip it apart further.. I am new to the forum and any help would be appreciated...
Old 09-25-2011, 06:49 AM
ternandes's Avatar
Car: 88 GTA
Transmission: WC T5
Axle/Gears: BW 9-bolt 3.27 posi
Re: white smoke from exhaust smells like fuel
In my experience, excessive fuel would give you black exhaust smoke. In the cases when I had white exhaust smoke, it was always coolant leaking into the combustion chamber without leaking into the oil. This can and does happen with a blown head gasket.
Old 09-25-2011, 07:52 AM
TreeFiddy's Avatar
Car: '86 TA
Engine: '74 350
Axle/Gears: 2.77
Have you run the car a few miles to warm it up, it's not just overnight condensation in the ex pipe evaporating? Or maybe it's the belt smoking from that seized smog pump lol
Old 09-25-2011, 10:49 AM
Car: 87 IROC-Z28
It was pretty warm .. smog pump never had belt to begin with..lol. dosent smoke when I drive it or at least don't see smoke while driving just sitting there...
Old 09-25-2011, 07:27 PM
camarorsssss's Avatar
Car: 1991 camaro rs convertible
Engine: Built ls1
Axle/Gears: 3:42
I am helping him fix the car it is currently at my house. Upon start up there is no smoke but when it starts to warm up It will begin to smoke a bit and as it gets hotter it smokes more. But as soon as you give it gas it clears up. It smells rich and is a bluish white color. Oil is clean, coolant Is also clean. There is no smell of coolant leaks anywhere either. A little bit of backstory, when we got the car it had an intake leak and it turned out the intake was cracked/broken at the 1 cylinder at the coolant port. We replaced all the gasket and were able to repair the broken intake. I am not yet convinced it's a headgasket I am thinking leaky injectors and maybe valve seals.
Old 09-25-2011, 08:13 PM
TreeFiddy's Avatar
Car: '86 TA
Engine: '74 350
Axle/Gears: 2.77
Just to rule it out, give it a health check - pull the plugs and do a compression test, or leakdown test if you can. That will reveal any ring, valve, or head gasket seal problems. But yeah, sounds like a top end problem.
Old 09-25-2011, 10:13 PM
Engine: Built ls1
Axle/Gears: 3:42
We will do a compression test. Stupid question but could misadjusted rocker arms cause this type of problem
Old 09-25-2011, 11:42 PM
aremy10's Avatar
Car: 91 firebird
Axle/Gears: stock
just curious how you fixed the cracked intake. was the flange just cracked, or in more than one place. under hotter temp. there will be more pressure , if you didnt fix the entire crack, especially on the inside of the intake, the excess pressure will push (or draw from the piston) the coolant into the chamber. may have some ring damage too considering the blue color of the smoke. as previously mentioned , it can get in there without getting in the oil. intake could also be warped so bad it didnt seal. what i would do is the compression test, and probebly change the intake too anyway. if it has a crack, it may be craked in other places and a new/used intake is not that expensive. might as well replace it and eliminate that as a possibility.
misadjusted rocker arms will either make it click loudly , or if overtightened it will run crappy cause the valves wont close all the way, then the piston cant compress the gas and air like it should cause it isnt sealed in there. if it is leaking coolant into the cylinder it could cause the gas to not completely burn, making it smell like gas
Old 09-26-2011, 06:08 AM
ternandes's Avatar
Car: 88 GTA
Transmission: WC T5
blue smoke is indicative of oil burning... I second the suggestion to do a compression/leakdown test.
Old 09-26-2011, 07:20 AM
Engine: Built ls1
Axle/Gears: 3:42
We will def do the compression test to see if there are any cylinders that are low. I would rather it be a headgasket at this point than a ring problem. As far as how the intake was fixed it was almost like the intake was chipped/broken not really cracked and it wasn't all the way through the coolant passage more a surface defect causing it not to seal. It was fixed with marine strength jb weld type stuff by a mechanic. It was smoothed out and was almost good as new and sealed fine, atleast from the outside(no leaks)
Do a dry and wet compression test or would a dry test be good enough?
Old 09-27-2011, 07:17 PM
DENN_SHAH's Avatar
Engine: 92 5.7 tpi 5.3
Transmission: 700r4 6L60E
Axle/Gears: 2.42 too high
2 in a row with the same symptoms.
white tail pipe smoke that has a very strong gasoline smell is raw fuel being vaporized in the exhaust. its very flammable, so no smoking cigarettes.
look for leaking injectors or fuel pressure regulator.
first thing to check is the fuel pressure regulator. it not uncommon for them to leak fuel into the intake. any signs of liquid fuel in the vacuum hose is a sure sign its bad.
also in this case, check for a leaking cold start valve if the FPR checks ok.
Old 10-05-2011, 05:04 PM
TopdownIroc's Avatar
Car: 1990 IrocZ Convertible
Engine: TPI 305 (factory & anemic)
Axle/Gears: Crappy factory 2.73
Yep, sounds just like whats going on with mine. Its running ULTRA-MEGA rich at this point (raw white fuel vapor puffing when I gas it). It's to the point that last time I fired it; the next morning the garage smelled like a can of fuel spilled ... I have checked the injector ohm's and a couple seem to be out of tolerance but I hear them clicking while running. Car hard starts, but runs great and revs out fine. It's just super rich. My CTS ohmed at .929k ohms which was correct for the temp of the coolant, and all my injectors have 12.5 volts to their wiring pins. I also get no codes when shorting the ALDL. I am almost to the point of calling this a stuck open injector because I find no leakage in the FPR vacuum line. Might be time to call Southbay, but I hate to throw parts at it until something sticks.
Old 10-06-2011, 01:18 PM
lunaticinaZ's Avatar
Car: 1991 Black Z28 G92
Engine: 350 for now
Transmission: wc t5
Axle/Gears: factory 3:42
I had the same problems. Turned out my coolant was leaking into the combustion chambers and on top of that. I had a leaking injector. thus causing the white smoke that smells like gas.
Old 10-06-2011, 01:28 PM
SRTH8R's Avatar
Leaky cold start injector was my problem. Didn't have the smoke but actually hydro locked. Luckily nothing got hurt.
Old 10-06-2011, 03:46 PM
Well the smoking has stopped and the rich condition is getting better. I think my injectors were hung open from the car sitting to long. I seafoamed the tank and now it seems as if the injectors are cleaning up some. As of yet, it shows no sign of using coolant. I figured the same so I marked my levels. Now I need to replace my injectors. So was yours a head gasket or an intake gasket?
Old 10-06-2011, 05:43 PM
Car: 87 IROC-Z28
Just replaced the head gaskets today didn't pit everything back together yet I will keep everyone posted..
Old 10-06-2011, 08:38 PM
Cool man. Did you also do valve stem seals? I know that if they split they can cause more than just start-up smoke. They can smoke under acceleration much like a ring, but not as bad.
Old 10-06-2011, 09:14 PM
xxZ28xx's Avatar
Car: 1988 Camaro, Holley 600 series.
Engine: 350 w/350 TPI heads
Transmission: 90+ 700R4
Axle/Gears: not sure
How do you tell if you have a leaky injector and how do you find out if your coolant is leaking into your combustion chamber?
Old 10-06-2011, 09:32 PM
As far as coolant leaking into the engine ie. blown head gasket or leaking manifold gasket there are several signs. A head gasket can blow three different ways. It can leak into the block turning the oil a chocolate milk consistency and color, it can blow hot exhaust gases back into the coolant causing an overheat, or it can enter the combustion chamber and exit through the exhaust causing a sweet smell and white steam out of the pipes (not like condensation this is a heavy white steam that stinks of antifreeze). As far as the injector you need a fuel pressure gauge. First test the prime pressure to make sure the pump primes the 40 psi the car needs, if not the pump might be going bad and that is causing a lean condition and the ECM widens the injector pulses to try and make up for it. If the pump primes the full 40 psi. then start the car and make sure you have a running pressure of approximately 38-39 psi. I myself then killed the car and clamped the rubber return line shut and watched my pressure gauge bleed off and I timed it. It took 20 minutes. Im not sure if i'm right with this, but that is way to long so there has to be a leaky injector somewhere. Another thing you can do if you think you have one is to pull the vacuum line off the FPR and see if fuel comes out. That is a sign of a bad FPR and it will cause it to run fat. If there is no fuel from the vacuum line, start the car and pull the vacuum line and make sure the pressure rises to 45-50 psi. That means the FPR is OK. If you have any other questions, feel free to ask.
Old 11-06-2016, 04:06 PM
Manny1018$'s Avatar
Car: 95 Chevy camaro
Engine: 3.4
Transmission: Automatic
I'm having a similar problem.i hVe white smoke coming out my tailpipe but I tighten my throttle body up and it stopped but now I have stem or smoke (dnt call it smoke cause u can barely see it) coming from the area under where my disturber is on my 95 Camaro v6 3.4. oh and my oil dipstick is way passed the full mark,ive checked it cold and get the same result,but my car doesn't over heat at all.???
Old 11-08-2016, 04:26 AM
senior bear's Avatar
duz yore oil smell of fule ?
Old 11-08-2016, 06:30 AM
Manny1018$'s Avatar
Engine: 3.4
No it doesn't smell like fuel at all.a mechanic said it might be a bad EGR Valve since that's where the steam is coming from ?? And insight on that
Old 11-08-2016, 07:18 AM
the egr redirects exhast gas so that may explain yore yore smoke from distributor area but will make no difrence to oil level .have seen oil pan full of fule from leaking injectors /worn rings etc .duz you water level drop.posible inlet craked leaking water into egr.not sure of v6 lay out .id dump oil fill to corect level keep eye on it.swap egr see how she runs
Old 07-12-2018, 03:05 AM
MissC's Avatar
excuse me but as far as I have ever known, a blown head gasket does not give off white smoke. A blown head gasket will cause an actual bluish colored smoke. A possibility of the white smoke that smells like fuel is a stuck or cracked injector because the spider web piece that's part of your injector may not function properly and is forcing fuel through, and down the cylinder in some cases yet will not show up as mixing with your oil if you check it with the dipstick. Another possibility could be a sensor is that it regulates your fuel to air mixture and basically when the vehicle is started it tries to flood out but if the vehicle won't die from flooding, it will force a Blow by which will be blown out the exhaust pipes. Check your Chambers just in front of the tailpipes and see if there is a black area that almost looks like fuel head puddled inside in the area will look chard plus your tail pipes will have a very carboned look to them. The problem is that there are a few different causes that will give this fuel Blow by and fuel smelling exhaust with white smoke. I am just correcting and giving an opinion on one of the options that could be the cause.
bryan623
03-22-2021 06:43 PM
Vintageracer
01-10-2020 05:33 PM
Red iroc-z 305
09-30-2015 05:22 PM
eightsixseven
08-14-2015 03:09 PM
Quick Reply: white smoke from exhaust smells like fuel
