power steering pump pulley removal
Old 09-22-2011, 09:53 AM
Grizzlybear226's Avatar
Car: 1988 Trans am
Engine: 358
So the only thing left I need to transfer from my 305 to my new 355 is my power steering pump but can't figure out how to remove the pulley to get to the bolts that are underneath. Any help would be appreciated, don't wanna go out and get a pulley puller and ruin the pulley if I can avoid it. Thanks for the help
Old 09-22-2011, 09:59 AM
Twin_Turbo's Avatar
Re: power steering pump pulley removal
P.st. pulley removal/installer tool:
Old 09-22-2011, 11:41 AM
majobis's Avatar
Car: 1987 IROC Z w/T-Tops
Transmission: Automatic
Axle/Gears: G92
I have a steering wheel puller kit with a bunch of attachments (in an unknown location in my garage at the moment). Anyone know if these kits are universal? Meaning, will some of the attachments in a S.W. kit work on a P.R. kit? I'm just curious.
Old 09-22-2011, 11:57 AM
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
No you have to get a special puller. That thing looks like an installer more than a puller. You usually get a kit that has both. They both use that same giant bolt.
http://www.amazon.com/OTC-7185-Power.../dp/B0002SRG3E
That's a puller. It has two half clamshells that you put around the snout of the pulley. Then you put the ring over it to hold them together. Put a wrench on the hex head at the end of the bolt, and put another on the assembly holding the pulley snout, and start crankin that bad boy off. It's a pretty annoying job. Those things are on there TIGHT.
rent it from your local auto parts place so you dont have to actually buy one.
Old 09-22-2011, 04:11 PM
Twin_Turbo's Avatar
oops wrong pic
Old 09-22-2011, 07:48 PM
jtsk's Avatar
Car: 1992 z28 Purple Haze
Engine: 5.7L Tuned Port Injection
Axle/Gears: 3.23 both spinning
Infernal is right TIGHT and then some! Have some WD-40 or PB Blaster handy. Going back on is fun too.
Old 09-24-2011, 02:27 PM
Car: 1988 Trans am
Engine: 358
Thanks for the help guys, its been bothering me for a few days lol
Old 09-24-2011, 03:57 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
The second picture looks much better. It's a special puller that slips over the collar on the pulley. A generic puller will not remove the pulley no matter how much you try, without damaging the pulley.
As mentioned above, you can usually rent the tool. An impact gun makes using pullers a lot easier but lots of muscles can also do the job. It just takes longer.
Vintageracer
01-10-2020 05:33 PM
colton_carlson
03-08-2019 12:21 PM
backtothe80s
09-05-2015 12:39 AM
Street Lethal
08-12-2015 11:33 AM
3rdgenparts
08-08-2015 07:09 PM
Quick Reply: power steering pump pulley removal
