How can I tell if I I have a later 700R4 or 4l60
Old 09-21-2011, 12:25 AM
Stephen Thomas's Avatar
Car: 84 Trans Am
Engine: 5.7 zz430
I have a 700r4 for sale an I can't for the life of me tell which one it is. Is there a casting number site that would be able to tell me?
The Transmission came out of an 86-88 Pick up truck, 2 wheel drive 1500 series. Leaving me to wonder if its the better one of the two 700's that where out in the 80's
So can can someone pleas direct me to a casting site which will help me put mystry to rest?
Thanks Steve Thomas
Old 09-28-2011, 06:58 PM
greggbruce's Avatar
Car: 84 454 monte, 89 formula, 86 camaro
Engine: the bigger the better
Transmission: 700/4L60 in everything
Axle/Gears: wish they were all 4.10's or better
Re: How can I tell if I I have a later 700R4 or 4l60
700R4 and 4L60 are the same trans, just different names. GM changed how they called em. The 87-92 trannys have a "saint louis arch" cast in the case around the cooler line fittings, earlier units do not. If the electrical plug is on the passenger side, and it has no TV cable hole (some people call it a 'kick down cable' (which it is not), it is a 4L60E which they partially rolled out in '92 and up. You could also look at the numbers stamped in the pan rail on the passenger side rear where the pan meets the case, the first number is the year it was built. A 1-6 without the 'arch' is an 81-86, a 6 up to a 2 WITH 'the arch' would be an 86 - 92. And the ones with 'the arch' have better internal parts than the older ones, thus more desirable.
Old 09-29-2011, 12:30 AM
Car: 84 Trans Am
Engine: 5.7 zz430
Originally Posted by greggbruce
700R4 and 4L60 are the same trans, just different names. GM changed how they called em. The 87-92 trannys have a "saint louis arch" cast in the case around the cooler line fittings, earlier units do not. You could also look at the numbers stamped in the pan rail on the passenger side rear where the pan meets the case, the first number is the year it was built. A 1-6 without the 'arch' is an 81-86, a 6 up to a 2 WITH 'the arch' would be an 86 - 92. And the ones with 'the arch' have better internal parts than the older ones, thus more desirable.
Thanks for your great answer I have a later one, it has the artch. I don't know if you can, I can't seem to find a decoder site but decode this trans..
It has 2 sets of numbers on it..
The main body stamp has the #8663548
The Stamp on the left rear right about the oil pan is #9MXM236H
Old 09-29-2011, 08:20 AM
greggbruce's Avatar
that would be an '89 MXM. I haven't found a chart to tell me what it came out of, but MXM is the calibration -- springs in the valve body, governer weights, wiring harness, ect. 236 is the day of the year it was built, and the H means it was built on the 2nd shift of the day. The 8663548 is probably the part number when it was made, a gm dealer might be able to tell you what vehicles that part number would fit, but I don't think they can tell you what it came out of -- unless it ONLY fits firebirds and camaros.
Old 09-30-2011, 12:39 AM
Pro Built Automatics's Avatar
If is has three bolt holes going sideways through the tail housing, then it is a Camaro or Firebird. The type of governor you have will tell you if it is a high rpm (apx. 5,500 rpm WOT shift points), or a standard V-8 (apx. 5,000 rpm WOT shift points). If it is "plain Jane" tail housing with no sideways bolt holes, then it is most likely a van or truck and will have the standard V-8 governor.
Old 10-03-2011, 12:21 PM
greggbruce's Avatar
Provided somebody hasn't changed the tail housing...
and I believe the 'vette tail has trans mount bolt holes cast in the bottom with no side-to-side holes in it. but all of the vette and f-body codes I found have the letter 'y' in them, so I'm betting it's a truck or big car trans...
loud91rs
10-05-2015 10:05 PM
92projectcamaro
09-29-2015 07:07 PM
IROC ZELLER
09-29-2015 03:00 PM
indygene
09-26-2015 11:21 AM
6998poncho
09-25-2015 02:56 PM
Quick Reply: How can I tell if I I have a later 700R4 or 4l60
