4L60e transmission 1-2 shift accumulator location?
So I'm having transmission problems in both my cars right now. This is actually for my trailblazer but I'm not getting a lot of responce from the trailblazer forum and you guys seem to know alot and its pretty similar to the 700r4 tranny as I understand. When shifting from 1-2 I'm getting a pretty bad shudder but that is the only problem its having. I think this is the problem from this site http://www.twincharlotte.com/transmi...r-Charlotte-NC
3. 1-2 Shift shudder at WOT (Wide Open Throttle); delayed or abnormal 1-2 shift; There's a problem ONLY on the 1-2 shift: 1-2 accumulator piston cracked or stuck cocked in the bore. Check the yellow spring inside the accum housing for breakage. Also, if the accumulator housing walls are scored, the housing must be replaced.
My question is where is the 1-2 shift accumulator and can it be changed without dropping the transmission? Any help would be great! Thanks!
Re: 4L60e transmission 1-2 shift accumulator location?
Yes.
:google:
try http://carcraft.automotive.com/10108...ion/index.html
instead of http://www.carcraft.com/techarticles/ccrp_0711_4l60e_to_4l65e_gm_transmission_conversionviewall.html
http://www.gearstar.net/articles/details.php?unid=21
:google:
16) This assembly is a modified 1-2 accumulator piston and its housing, which improve and regulate the 1-2 shift. Gear Star tailors the combination of springs for different combinations.
Thanks for the reply! Was that a how to article on it from carcraft? The link you gave didn't work and I'm searching their site but haven't found anything on it. How did you find it?
Car: 1988 camaro z28,1997 camaro lt1
Engine: 355 afr 195 heads,tpis big mouth
Transmission: 700r-4 built by me 3-4 z pack
Check the accumulator spring to see if its broken
BlackphantomZ28
04-24-2016 08:14 AM
