Head rest removal??
Old 09-09-2011, 01:47 PM
t-top havoc's Avatar
Car: '87 Camaro
Engine: '92 Carb'd 350
Axle/Gears: factory stock
Head rest removal??
How does the head rest get removed?
I'm going to go ahead & start to remove the seat cover from a passenger seat & driver seat, & put the passenger seat cover on the driver seat.
Is there a trick or special tool?
Thanks for any tips!!
Old 09-09-2011, 01:48 PM
Thirdgen89GTA's Avatar
Car: 1989 Trans Am GTA
Transmission: M28 T56
Re: Head rest removal??
Usually there is just a tab you push in so you can pull the headrest up and out of the seat back.
Old 09-09-2011, 01:56 PM
Car: '87 Camaro
Thank You for such a fast response!!
I'll be starting in a couple hours when my Bride goes to work-- I need some space in the garage! Lol!
We have a power seat in now, plus a manual slider. I may put the manual on the passenger seat for now, & take the cover off the driver seat, then use the other passenger seat to start to cover the driver seat.
We have 2 passenger seats to work with.
I know the lay back won't be easy to get to, but we generally don't lay back at all, pretty much straight up.
Old 09-09-2011, 03:09 PM
Car: '87 Camaro
DOH!!
Yup, there are a couple links!! I just used the wrong words when I searched!!
Old 09-11-2011, 06:25 AM
89transam*pearl's Avatar
Car: 89 T/A
Engine: LB9
Transmission: W/C T-5
Axle/Gears: 10 bolt posi, 3.73 Richmond Gears
I just removed mine, took a thin piece of metal - 2 or 3 inchs wide - slide down the front of the head rest bracket and pull up with the head rest and metal strip together, slides right out...
Old 09-11-2011, 02:42 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
I've got a question along these lines:
What do I do when the headrest comes right out, and it doesn't stay up when set? My passenger's side headrest does this, and it bugs me. I know I'm going to have to replace both of them somehow (neither one holds the seatbelt loop for beans... Heard there is a block of wood in there and I'm going to assume it's cracked), but I'd like to solve the puzzle... Even if I get new seats.
Frozer!!!
01-19-2024 04:55 PM
camaroken83
08-10-2015 11:35 AM
89mulletbird
Southern California Area
08-10-2015 10:16 AM
3rdgenparts
08-08-2015 07:09 PM
drathaar907
08-06-2015 04:20 PM
Quick Reply: Head rest removal??
