With 383, How much power will I have
Old 09-06-2011, 06:46 PM
87IROCZCamro's Avatar
Car: Chevrolet Camaro IROC-Z,96 Vette
Engine: 350 5.7 Liter
Transmission: 700r
Well I rebuilt the motor over the winter and after 3k in parts and etc I blew the motor on the dyno. Havent torn the motor nor will I be since my dad is mad haha I think I broke a lifter and blew a headgasket since the exhaust was not opening on cylinder #1. Coolant got in oil and was running for a little bit bearings are unknown and car runs on around 5-6 cylinders. I want to make it a 383 now stroker so heres what I have done so far.
Comp 503 cam
Patriot 190cc Aluminum heads
1:6 roller rockers
7/16 pushrods
Headman headers
Stealth Ram Intake
30lb fuel injectors
Holley Fuel rail
Walbro Fuel pump
Cap and rotor
8.5mm wires
stock pistons
3:73 rear gears
I want to stroke it and wonder how much hp I should have around and 1/4 mile times.
Old 09-06-2011, 07:35 PM
88gta3508's Avatar
Car: 00 SSEi / 94 C4
Engine: 231 / 383
Transmission: 4T65E / ZF 6sp
Axle/Gears: 2.93 / Dana 44 3:45
Re: With 383, How much power will I have
you need to give the combustion CC's ???
Headman FL or shorty??? what about the rest of the exhaust???
2 or 4 valve relief pistons ??
"7/16 NO" pushrods, FP, cap, rotor add nothing
zero deck 383???
gasket thickness???
so far I'll give you 360 - 400 <> 12 range 113 - 116
Old 09-06-2011, 10:35 PM
izcain's Avatar
Car: 1983 Camaro Z28
Engine: 584
Transmission: TSI Glide
Axle/Gears: Quick performance 9 inch
What kind of times do you want from the car that is the better question
Old 09-06-2011, 11:43 PM
Transmission: 700r
zero deck 383???
gasket thickness???
To be honest I do not know right now. I am taking to a shop that will deck and block and heads and I know the fp cap etc add nothing was just noting for what i have in the car.
I want the car to run low 12s if possible with a 383 mid 11.
5spdcamaro
08-28-2015 02:12 AM
sailtexas186548
08-24-2015 10:11 PM
Accerrito22
08-23-2015 07:22 PM
86White_T/A305
08-17-2015 12:16 AM
sreZ28
08-14-2015 07:48 PM
Quick Reply: With 383, How much power will I have
