700r4 valve body diagram?
Old 09-06-2011, 02:36 PM
ninetyone's Avatar
Car: 91' Firebird SOLD
Engine: 350 TPI +bolt-ons
Axle/Gears: 3:42
Any one have an exploded view of the valve body? I am going to attempt to take mine apart and clean it as well as replace the accumilator springs inside. Please post a diagram if some of you out there have one . Thanks
Old 09-21-2011, 11:38 PM
antares57's Avatar
Car: 91 Firebird/88 Firebird/91 Formula
Engine: V6 3.1/V8 5.0/V8 5.0
Transmission: 4L60/700R4/4L60
Axle/Gears: 3.23/2.73/2.73
Re: 700r4 valve body diagram?
Don't know if it's too late or will help but I found this here.
http://www.bulkpart.com/Merchant2/me...ode=4L60-700R4
Old 09-22-2011, 09:44 AM
ninetyone's Avatar
Axle/Gears: 3:42
thanks
Old 09-22-2011, 03:52 PM
TallTim's Avatar
Car: 1989 Formula T-Top
Engine: 350 TPI + some bits
That is a very cool diagram. Do mere mortals take a trans apart to that detail?
Old 09-28-2011, 06:36 PM
greggbruce's Avatar
Car: 84 454 monte, 89 formula, 86 camaro
Engine: the bigger the better
Transmission: 700/4L60 in everything
Axle/Gears: wish they were all 4.10's or better
if you have no stuck valves, I don't take them apart. I build transmissions for a living. Make sure each valve moves easily in the bore using a small screwdriver/seal pick. Clean it with lots of brake cleaner and compressed air. Leave out the accumulator springs and replace them with a stack of washers/nuts underneath the piston so the accumulator pistons don't move and it will firm up your shifts. Just make sure the piston doesn't stick out of the bore ANY AT ALL (use a strait edge across the surface). The B & M shift improver kit for 700R4 is a good one. it has you drill a couple holes in the separator plate and remove a spring in the MTVupshift valve, and leave out a checkball.
Old 06-25-2012, 10:38 PM
TA-Rocks's Avatar
Car: 87 GTA, 99 VFR800
Engine: 5.7 TPI wrong heads , 781cc
Axle/Gears: 3.08, msg me if u hav 3.42 4 sale
Hi Greggbruce,
I have some questions also and would appreciate any assistance. Are you still monitoring this link and thirdgen?
This is the thread that I started and explained. Any help would be great.
Old 09-05-2012, 12:43 PM
Cadaver Puncher's Avatar
Car: 92 rs daily driver work in progress
Engine: 3.1 , 204/214 cam
Transmission: 700 r-4, b& m megashifter
Axle/Gears: I want a posi with rear discs
I have a question as well.
I can get a tci constant pressure valve body for my 700r4 for cheap. I was wondering how difficult an install this would be?
Old 09-06-2012, 09:25 AM
Pro Built Automatics's Avatar
My God don't do this "Leave out the accumulator springs and replace them with a stack of washers/nuts underneath the piston so the accumulator pistons don't move and it will firm up your shifts. Just make sure the piston doesn't stick out of the bore ANY AT ALL (use a strait edge across the surface). The B & M shift improver kit for 700R4 is a good one. It has you drill a couple holes in the separator plate and remove a spring in the MTV upshift valve, and leave out a checkball".
If you want to break your transmission in the long run and you want very hard 1-2 part throttle shifts, then this will give it to you. Doing this to the 4th accumulator is ok, but never to the 2nd accumulator. You should have seen what I have taken apart over the years from people doing this, and the damage it did. I thought this way of thinking died years ago.
Old 09-07-2012, 12:23 AM
novaderrik's Avatar
Car: 86 Camaro
Engine: 355- hopefully a 5.3 this summer
it's ok.., he builds transmissions for a living..
lakeffect2
08-23-2015 08:44 AM
g.l.mos
08-22-2015 12:02 AM
crazynights
08-21-2015 06:53 AM
1985chevydude
08-20-2015 12:29 AM
TreDeClaw
08-14-2015 06:58 PM
Quick Reply: 700r4 valve body diagram?
