700r4 to th350 driveshaft questions
Old 08-25-2011, 12:38 AM
89_camaro's Avatar
Car: 89 camaro
Transmission: 700r4 w/huges 3000 stall
Axle/Gears: 3.73 posi
i currently have a 700r4 in my 89 camaro and am in the process of building a th350. whats the length difference between the two driveshaft from r4 to 350 and is there on out of another car that would work, i have herd a driveshaft out of a 200r4 would work or would it be easier to have one made. thanks for the help
Old 08-25-2011, 01:27 AM
jmd
jmd's Avatar
Car: `86 SS / `87 SS
Re: 700r4 to th350 driveshaft questions
Assuming you have a short tail th350, an 82-83 driveshaft from a th200 f-body would work.
A 700-R4 Caprice driveshaft is 2.92" shorter than a same-year 200-4R Caprice driveshaft so that length longer than stock would work for you.
If you had a long tail th350, you wouldn't need to change driveshaft.
Old 08-25-2011, 09:56 AM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
correct. 6" tailshaft housing will need the th200 length driveshaft, 9" will use the 700r4/T5 version. and (in case it slipped your mind) don't forget that a torque arm adapter is required for these cars if you're tossing in a th350 or 400
Old 01-14-2012, 11:00 AM
86InfidelIrocZ's Avatar
Car: 86 IRoc
Engine: 383 @ 505hp 530ft/lb torque
Axle/Gears: 10 Bolt and 2.73
Hello, I was wondering if you had any luck with this. Also I was wondering what the drive shaft length is for a TH350 in a 3rd gen?
redmaroz
08-16-2015 11:40 PM
djmarch
DIY PROM
08-11-2015 10:22 AM
Leggman1
08-06-2015 04:15 AM
Quick Reply: 700r4 to th350 driveshaft questions
