STR cast twin turbo manifolds
Old 08-23-2011, 08:55 PM
Seanmay1's Avatar
Car: 89 Firbird Formula WS6
Engine: TPI 305
Transmission: T 5
Axle/Gears: 3.45 Posi 9 bolt
Did a search for STR and didnt come up with anything so figured I would ask.
Has anyone used these?
http://strco.net/cart/chevy-sbc-turb...fold-p-12.html
Wondering if they would fit with AC
Im building a 87 Cutlass right now and have the serpentine setup up off a camaro and will be keeping the AC. I'm really getting frustrated trying to find something that will work. Only thing im really seeing other than these is the ebay crap.
Old 08-23-2011, 09:31 PM
DIGGLER's Avatar
Re: STR cast twin turbo manifolds
i have a set but have not used them. they are very similar to the gale banks twin turbo manifolds. cast iron, well made.
Old 08-23-2011, 09:40 PM
Seanmay1's Avatar
Engine: TPI 305
Transmission: T 5
Do you have any idea if they will clear the AC compressor?
Old 08-24-2011, 05:20 AM
DIGGLER's Avatar
no sir, no clue. my car hasnt had a/c since 1990. lol
Old 08-24-2011, 06:31 AM
Street Lethal's Avatar
Old 08-24-2011, 11:45 AM
zz17iroc's Avatar
Car: 91' Z28, 92' Z28
Engine: 383, L98 stock
Transmission: Built 700R4, Stock 700R4
Axle/Gears: 12 Bolt 3.73, 10 Bolt 3.23
Whenever you decide to use them let us know how they fit, if you don't mind?
I've been looking at those for some time, just the money never been right. I had to spend it on other things.
Old 08-27-2011, 06:39 PM
5.0slayer's Avatar
Car: 91 camaro RS
Engine: 350, forged 355 in the works
Transmission: 4 speed goin to th400
Axle/Gears: stock 9bolt, 3.27
after adding the wastegate i dont see how they will work, and no ebay headers will fit with out modding, the single header will fit but i heard the cross over wont fit with stock starter, need a mini. but for 700 i think u should try to make ur own,
Old 08-27-2011, 06:44 PM
Seanmay1's Avatar
Engine: TPI 305
Transmission: T 5
I wont be using the ebay ones. I do have a mini starter, it got swapped in with the centerforce flywheel for the T56 swap.
I have since decided to go single turbo, I will most likely be fabbing my own setup from a flowmaster stainless pipe kit and putting the turbo where the battery currently is and relocating the battery to the trunk.
Old 08-27-2011, 11:12 PM
5.0slayer's Avatar
Car: 91 camaro RS
Also where I plan to put mine but Gota finish my swap to a th400 first. But if ur headers turn out nice I'm lookin for a set too if u want to make some extra cash
Old 08-27-2011, 11:20 PM
Seanmay1's Avatar
Engine: TPI 305
Transmission: T 5
I dont mind helping anyone so it wouldn't be to much to make another set if you liked it.
This is what I'm thinking about doing. Flipping cast manifolds or either set of shorty headers and then running pipes like this one.
Then run it in behind grill to intercooler and back out other side and up to a blow through carb.
Originally Posted by FSTFBDY
Room for a 90* bend for DP and runs under the manifold and out.
3inch
http://www.cecoatings.com/images/Car...r/DSC02723.JPG
Hopefully I'll be putting this back in my vrt with a 383Lt1 but I can never make up my mind and might be getting rid of this turbo setup again.
Old 08-28-2011, 12:50 PM
5.0slayer's Avatar
Car: 91 camaro RS
See I don't have the Ac problem I deleted the whole Ac bracket I have tons of room on the passenger side
Old 02-20-2014, 08:37 PM
seafire's Avatar
Car: 1986 firebird coupe
Engine: 5.7 chevy 350
Transmission: T.C.I Streetfighter
Axle/Gears: 3:73
I am so tired of exhaust manifolds that do not fit. I've bought two pair the hugger headers and the headers that go forward (both stainless). There is not enough clearance with either. I tried fabing them myself, then sent them to someone. they returned them in pieces, and said they couldn't do it. I asked multiple people and shops in the area who all turned me down or said the could do it one night and the next day said they were too busy. So I broke down and went to banks power and bought the retardly expensive ones. If they don't fit Im giving up on the turbo idea. 1700$ for the manifolds from banks. I'll let you know if they,... WHEN they fit.
Old 02-20-2014, 08:39 PM
seafire's Avatar
Axle/Gears: 3:73
Also the link to the STR cast iron headers does not work
Old 02-20-2014, 09:43 PM
DIGGLER's Avatar
wow... the str's are pretty much the same thing as the banks manifolds, or possibly better? i have the str manifolds but never did use them.
what is not "fitting"? doing a twin setup means basically nothing is going to fit and you will have to move everything around and/or get rid of some stuff. you will need center inlet turbine housings so the turbos will locate correctly.
you can get a set of stainless up and fowards that fit the car from jardines headers. but you will have to fabricate everything after the v-band on each.
there is tons and tons of fabrication with this sort of thing.
Old 02-21-2014, 05:28 PM
seafire's Avatar
Axle/Gears: 3:73
On my car the hugger headers swoop out and up but hit the wheel well. The other headers that go straight firebird would leave zero clearance between the turbo and radiator, and on the other side it hits the steering column shaft and the alternator. I agree there is always some fabrication. I have never had any thing that just "bolts on"that's a myth as far as I'm concerned. Banks power said they will make them Wednesday and shipp next Thursday Pretty stoked
Old 02-27-2014, 11:48 AM
hardcoreZcar's Avatar
Car: 86 Z
Engine: 400 sbc
Transmission: t-56
Axle/Gears: 4.10
I am going to buy a set of banks manifolds next week. So shopping for turbos. Do I need to shop for center inlet turbos or could I use a right hand and left hand drive turbo? It will be a show car so I was really hoping to go with the symmetrical look.
Old 02-27-2014, 01:30 PM
DIGGLER's Avatar
center inlets, otherwise you will have one turbo over the valve cover.
Hotrodboba400
12-10-2019 07:07 PM
86Firebird86
12-26-2015 07:21 AM
customblackbird
10-01-2015 04:30 PM
355tpipickup
09-13-2015 11:35 PM
Hotrodboba400
09-02-2015 07:28 PM
Quick Reply: STR cast twin turbo manifolds
