LT4 cam card
Old 08-04-2011, 09:55 PM
ReNeGaDe_Z's Avatar
Car: 1990 Formula, 1989 Mustang LX
Engine: Stock TBI 305, Built 302
Transmission: 700R4, AOD
Axle/Gears: 4.10, 4.10
LT4 cam card
Does anybody have the actual cam card for the LT4 hot cam? I'd like to see the specs for it for another project of mine. Thanks in advance.
Old 08-04-2011, 10:40 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Re: LT4 cam card
https://www.thirdgen.org/forums/tech...ve-actual.html
Seen this posted
I've taken these specs off a H.O.T. cam sample - the .050" duration is 219.1/229.3 deg, .100" duration is 187.7/197.0 deg, the .200 duration is 135.8/143.1 deg, the actual .050" valve timing is: Intake opens at .3 deg BTDC closes 38.8 deg ABDC, the exhaust opens at 49.1 deg BBDC and closes .2 deg ATDC
This cam tested measured 112.3 deg lobe separation angle, Intake centerline was 108.7 deg. Hope this helps, Dr HP
DD2003 confirms those are close, at .050"
IVO 0.5 deg BTDC IVC 38.5 ABDC
EVO 49 deg BBDC and EVC -1.0 ATDC
Old 08-05-2011, 09:22 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: LT4 cam card
I think that this is the same hot cam. Double check the part number as it is only listed as the 'hot cam'.
RBob.
Old 08-05-2011, 11:02 AM
UnderCover89TBI's Avatar
Engine: gone
Transmission: gone
Axle/Gears: gone
Re: LT4 cam card
Might be doing this cam swap next year. have not decided for sure yet. deffinately an option
Old 08-06-2011, 09:59 PM
ReNeGaDe_Z's Avatar
Re: LT4 cam card
Thanks a bunch guys, this will really help.
Jorlain
10-08-2015 01:57 AM
tommy z-28
10-06-2015 10:58 PM
customblackbird
10-01-2015 04:30 PM
Strick1
09-04-2015 07:11 AM
z28guy134
09-01-2015 11:50 PM
Quick Reply: LT4 cam card
