700R4 tv cable problem PLS help!
Old 07-21-2011, 10:37 AM
gmstrong's Avatar
Car: 95 9C1,99 Sierra,90Sierra,00 sierra
Engine: TBI350,LM7,LT1,Vortec 350
Transmission: 700r4,4L60e,4L60e,4L80e
Axle/Gears: 10 bolt,14bolt,3:42,3:73,3:08,3:73.
I understand that this a thirdgen forum but you guys are pretty damn good so i come here with my problems,the problem is on my 90 gmc sierra c1500 i just replaced the trans and the kickdown cable i adjusted it several times still to no aval.The problem is when i drop on the thorttle then slow down for a red light or something it wont shift out of 1st if i pull over shut off the motor then it will shift again.wierd and confusing.the cable doesnt come out of adjustment and its tight with no play in it.
Old 07-21-2011, 10:41 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Axle/Gears: 3.54 Dana 44
Re: 700R4 tv cable problem PLS help!
The problem started before you replaced the transmission?
Old 07-21-2011, 10:44 AM
fireturd350's Avatar
Car: '90 Formula 350
Engine: 383 SBC
Axle/Gears: 10 bolt 3.23
Have you adjusted the tv cable properly and verified it did in fact click like it was suppose to? Don't drive it if you think the cable is not orrect. That's very easy way to burn out clutch bands.
I'd recommend calling Dana over at probuilt automatics. We could struggle with this for days or a few phone calls he could probably point you the right way in a few minutes.
Old 07-21-2011, 12:08 PM
gmstrong's Avatar
the problem started after i replaced the trans.The way that im adjusting the tv cable is by having someone hold the thorttle pedal to the floor while i push the adjuster back towards the trans until it stops and it does lock because i can hear it click.again it shifts prefect until its wot.Shift points seem fine.Ill call them up,i already called a local trans shop he said 1200 to rebuild basically saying the trans is beat.If im going to replace this trans again it will be a built one from tci so i dont have to mess with this bs.
Old 07-21-2011, 12:49 PM
Apeiron's Avatar
Engine: 383 Carb
Stuck TV maybe?
Old 07-21-2011, 12:55 PM
gmstrong's Avatar
yea thats what he said at first i asked him how much he would charge and he said its not worth it,said just to rebuild it.i would do it but those check ***** push me back.
Old 07-23-2011, 09:23 PM
Pro Built Automatics's Avatar
This is not a rebuild solution. It sounds like the Throttle Valve (TV) is not coming back when the throttle is in closed position. The TransGo Throttle Valve shoud solve this. Did you talk to the original builder on this? I like how everybody looks at us as a "commodity".
Old 07-24-2011, 08:40 AM
gmstrong's Avatar
cant seem to find this transgo thorttle valve you speak of.i found one but it says for WOT 3-4 upshift which would be great to have since this trans wont shift to 4 wot like most 700r4's dont,but if i pull off this valve body ill be doing some upgrading in there.
Old 07-24-2011, 10:20 AM
Engine: 383 SBC
Well maybe if you weren't so good at what you do Dana. :-) Most of the time I recommend people over I figure they need some type of replacement part that you can/will sell individually vs some catalog company selling poor quality rebuild kit that might fix the issue. If you would like me to stop I will.
Old 07-24-2011, 11:05 AM
I don't list the part individually, but I have them in stock. The valve body will have to be removed, the TV plunger and the factory throttle valve will have to come out and the new TransGo throttle valve, springs, and spacer will replace the original TV setup. You will need to replace the valve body gaskets. There is a possibility that there is a minor cross leak that is causing this, not letting the oil exhaust, thereby letting the throttle valve stick in the high throttle position. When you shut off the motor, the valve comes back into position. What do you mean that you replaced the transmission? While this valve is out you could modify the TV plunger to allow the 3-4 WOT shifts. It takes two Allen plugs to accomplish this. I have them in stock, along with the Allen wrench. $15.00 will take care of the parts, valve body gaskets, and the installation instructions. They will go out using the mail. Let me know if you need anything else? Dana
Old 07-24-2011, 08:01 PM
gmstrong's Avatar
i replaced the trans because third gear was slipping not bad since i got 270,000 miles out of it.The trans i put in has around 50,000.Well im going to take to a guy i know thats been doing it for 35 years.Im going to see what he says about it.If he says thats the problem i will buy the parts.Ill keep in touch and thank you for your time!
Old 07-25-2011, 03:23 AM
I have been in the automotive trade for about 46 years and I have been doing automatics around 34 years. See what he says, and go from there.
Old 07-25-2011, 11:56 AM
gmstrong's Avatar
guy was a joke he told me the problem its the tv in the trans getting stuck like you said.BUT now i have too find a new 350 since he killed mine its got a nasty tick in the motor now after he took it for a test drive.Exactly why i try to fix it myself.
g.l.mos
08-22-2015 12:02 AM
Spd-Kilz
Interior Parts Wanted
08-15-2015 12:12 PM
fonzie85
08-13-2015 11:50 AM
ZZ42Fast
08-10-2015 08:20 PM
Quick Reply: 700R4 tv cable problem PLS help!
