Blown head gasket, only to find pistons upside-down...
Old 07-14-2011, 08:15 PM
kerplunk318's Avatar
The picture says it all... Where do I go from here? The valves don't look bent but should I pressure test them? I have to pull the motor and swap the pistons around; will I have to re-hang the rods so they can all go back into the same bores?
Old 07-15-2011, 12:24 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Axle/Gears: 3.54 Dana 44
Re: Blown head gasket, only to find pistons upside-down...
Getting the heads checked would be a good idea. Honing and re-ringing should be enough to swap the pistons from side to side.
Old 07-15-2011, 12:12 PM
Guest
Guest
Posts: n/a
What about the rod offset?
Old 07-15-2011, 12:32 PM
Apeiron's Avatar
Engine: 383 Carb
They're aftermarket pistons, I doubt they have a rod offset.
Old 07-15-2011, 12:36 PM
Is a re-ring imperative? The motor has less than 4k miles on it.
Old 07-15-2011, 12:38 PM
Apeiron's Avatar
Engine: 383 Carb
The rings are broken-in to the cylinders they're in now. They won't seal in different ones.
Old 07-15-2011, 12:41 PM
Apeiron's Avatar
Engine: 383 Carb
Ahhh ok, I see what you mean... yeah, they'll probably have to be rehung.
Old 07-15-2011, 12:53 PM
I'm willing to bet the guy who put the motor together put half the pistons in wrong... won't know 'til I pull it.
http://www.jepistons.com/TechCorner/Pin-Offset.aspx
The pistons did seem really loud when cold.
Old 07-15-2011, 01:01 PM
Apeiron's Avatar
Engine: 383 Carb
Those pistons probably don't even have pin offset. The problem is the connecting rods. They have a side that has to face the other rod on the pin, and a side that faces the crank throw. Essentially you need to turn the piston 180 degrees without turning the rod, which can't be done without taking the rods off.
Old 07-15-2011, 04:22 PM
DarthBubba's Avatar
Car: N/A
I'd be having a little chat with that guy.
Old 07-15-2011, 06:14 PM
travis401's Avatar
Car: 91 Camaro RS
Engine: empty bay (for now)
Transmission: Built T-56
Axle/Gears: 3.42 stock posi disc
Thats just bad workmanship. you can clearly see were the valve was contacting the piston, so they are most likely damamged in one way or another. Best thing to do would be to pull each rod/piston assembly at a time, pull the piston off the rod, and rotate it 180 degrees. then reinstall with new spirolocks on the pins. and i would most def have the heads checked out for bent/damaged valves.
NinjaNife
08-23-2015 11:49 AM
lakeffect2
08-23-2015 08:44 AM
NWAsonoma
08-18-2015 05:45 PM
Quick Reply: Blown head gasket, only to find pistons upside-down...
