Organized Drag Racing and Autocross Drag racing and autocross discussions and questions. Techniques, tips, suggestions, and "what will I run?" questions.
Help Me get my 60 ft. times down.. Suggestions
Old 09-21-2011, 09:32 PM
  #51
91_B4C_RS's Avatar
Car: 1991 B4C Camaro RS
Engine: 370 lsx ls3 heads victor jr w/carb
Transmission: TH400 w/brake coan 8"4500-4800 stal
Axle/Gears: Moser 9" locker w/ 4.11's
Re: Help Me get my 60 ft. times down.. Suggestions
UPDATE:
Went to the track with new 4500 8" coan converter
car went NEW BEST!!!
1.571 60ft
7.389 1/8 @ 92.86 mph
11.587 1/4 @ 116.87
old best
1.739 60 ft
7.579 1/8 mile
11.808 1/4 @ 116.89
this thing hits the tires really hard!!!! compared to that 10' converter i hadtried leaving on the wood at 5100 rpm on the brake no traction lol resulted in a 2.57 60 foot time LMAO. next pass i came off the line at 3500 rpm resulting in a 1.597 60 foot. best 60 foot was launching at 3800 rpm on 26x11.5x16 et streets at 14 psi. didnt have a chance o try the new 28x10.5sx15 et drags . ran outta time. Car pulls both front tires off the line now shooting for 11.49 gonna need a 1.500 60ft time to get it
i will post video soon
Old 09-21-2011, 09:37 PM
  #52
mw66nova's Avatar
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
awesome news! thanks for keeping us posted!
Old 09-21-2011, 09:40 PM
  #53
mod313's Avatar
Car: Camaro
Engine: 305-150/254 combo
Transmission: TH350 or T200
Axle/Gears: Srange 12 bolt; 5.14 or 5.38
What rpm are you going thru the traps at? Also, try staging at 2800-3000 rpm. With larger tires you will likely find that you'll need more gear but try it first. No reason you shouldn't be able to get it 60 in the 1.4x's with some work on the car itself.
Old 09-21-2011, 09:55 PM
  #54
91_B4C_RS's Avatar
60ft improved from 3000 to 3500 and to 3800. fell off at 4200 slight spining. i cant see 2800-3000 being any faster
Old 09-21-2011, 09:59 PM
  #55
johnfwz28's Avatar
Car: 1987 Z28 Camaro
Engine: 5.7L TPI
hey mw66nova, how far is warner robbins from atlanta? i've seen your posts on here for a long time. where do you race your camaro? please take a look at my car and tell me how i can make it leave harder. go to youtube, type in slim camaro again dragfest. tell me what u think. i'm footbraking, no transbrake
Old 09-21-2011, 10:41 PM
  #56
91_B4C_RS's Avatar
VIDEO LINK
http://m.facebook.com/home.php?refid...783c8a6f271bd6
Old 09-22-2011, 06:28 AM
  #57
mw66nova's Avatar
Engine: 7.0L
you can start by going to a better track than HeadHunters
WR is ~1.5 hours south of ATL
i race at Silver Dollar Raceway in Reynolds, GA
Old 09-22-2011, 12:39 PM
  #58
91_B4C_RS's Avatar
Thinking about messing with front mounting location of my Umi crossmember mounted t/a . Right now it is at the upper of the two holes. I've read a couple places that lowering it allows tires to get hit harder and some say differently. My goal is a 11.49 pass with a 1.500 60'. What yall think I can do before next wedsday
Old 09-22-2011, 12:56 PM
  #59
zacharyhorn's Avatar
Car: 91 Firebird
Engine: Turbo 355
Axle/Gears: 3.73:1 7.625" 10 Bolt
The video link isn't working for me.
Old 09-22-2011, 01:10 PM
  #60
mw66nova's Avatar
Engine: 7.0L
tire hit is dictated by your IC. the torque arm up/down adjustment does not adjust your IC like adjusting a ladder bar or 4link. you can tune the hit with lca angle (cause the IC on our cars is the intersection of the lca plane with the plane of the torque arm mount that is perpindicular with the ground) and i've heard some folks say pinion angle too, but for the most part, folks keep that at -2* and forget about it.
to get infinite adjustability in lca angle, people are reverting to making the rear ride-height adjustable. i've heard 2* upward (from rear to body) is a great starting point. i'm planning on doing a set of Racecraft spring perches with adjustable ride height this winter, just for this type of fine tuning.
Old 09-22-2011, 04:46 PM
  #61
johnfwz28's Avatar
Engine: 5.7L TPI
yeah, that track is a little bad. i've raced at commerce before and got better times
Old 09-22-2011, 05:26 PM
  #62
mw66nova's Avatar
Engine: 7.0L
a little bad? we went once...never again
Old 09-23-2011, 10:13 AM
  #63
Fast 383's Avatar
Car: 1986 Camaro SC
Engine: None
Transmission: None
Axle/Gears: Moser 9" W/ spool 3.50 gears
Congrats on the new times. We all knew the car had that in it if you read back my posts.
If I could make a suggestion.
Leave the car alone. Don't touch anything. Take it out with a fresh, clear mind and try it again. You may get the car into the 11.40's the way it sits. You just need some additional track time. No one has ever maxed out there cars abilities in 1 track vist with a few passes. Trust me. Theres more in it.
This is how.
turn your 2 step launch point up to 4200 where it was previously slightly spinning. Work with that as your new launch point. Thats probably where your 1.49- 1.50 60ft is sitting. Once you can get the car to work at that RPM your almost garunteed some results. My advise would be to get in the burnout box and melt the tires till the rubbers falling off them. Let it fly at 4200 and post results. If that doesn't hook, than start figuring out what your suspension needs to make the 4200 launch hook.
On another note.... You should take the chip out of the 2 step and run the converter up on full throttle to see where it's lock up point is. You should always verify that the converter is hitting it's advertised number. And 4800 sounded better than 4500. JMPO
Old 09-23-2011, 08:31 PM
  #64
91_B4C_RS's Avatar
I really dont know where to go with suspension adjustment to getthe 4200 launch to work.Full throttle no chip on 2 step is 5000rpm flashes to 4700 while cruising. Of course it wouldn't hook. Or i can maybe say f*** it and try my 28x10.5 s m/t at the track see if I can get it to 60better..
Old 09-23-2011, 10:53 PM
  #65
Fast 383's Avatar
Car: 1986 Camaro SC
Engine: None
Transmission: None
5000 is good. You lucked out and they got it right. Doesn't always happen that way.
I'll bet you can get the 4200 to hook the way it sits with more burnout. Melt the tires.
If that doesn't work than these guys on here can suggest a lot of good suspension stuff to try. It's not my field. I re did all my suspension with pretty good stuff but never got to use it. A Roll bar, Torque arm, and lower control arms are a good start and a adjustable rear drag bar is a real nice piece.
But i'll bet the 11.40's are at that launch point and thats a good goal to work towards.
Old 09-24-2011, 06:04 AM
  #66
91_B4C_RS's Avatar
I guess I can drop air pressure next time out. Ran 14-15 psi all night
Old 09-24-2011, 06:33 AM
  #67
Fast 383's Avatar
Car: 1986 Camaro SC
Engine: None
Transmission: None
I would run 10-12 in my E.T. streets and melt them. That always gave me my best results. I've only been 1.52 though on bone stock suspension and tight *** converter.
Old 09-24-2011, 07:56 AM
  #68
91_B4C_RS's Avatar
To view video you have to go to my facebook page http://www.facebook.com/jgillen91 its posted on my wall from a guy named Tylor.
theshackle
09-17-2020 08:26 AM
Amillionoh7
05-24-2020 08:01 AM
backtothe80s
09-05-2015 12:39 AM
InfinityShade
08-22-2015 08:00 PM
djmarch
08-09-2015 05:27 PM
Quick Reply: Help Me get my 60 ft. times down.. Suggestions
