T5 wont engage into any gear
Car: 1983 Z-28
Engine: 5.7 L
Ok I just rebuilt my engine...i put a new clutch and presure plate on and bolted up the tranny 2 it...wen the car is off I can freely put the gears in but there is sum struggle 2 into puttin them in...b4 I rebuilt my engine the tranny would work fine...now wen the engine is on it doeant ahift into any gears...i bleed the slave cylinder wich is new also...if I press om the clutch it gets sumwat hard...i get presure...but wen I try 2 put the gear in it grinds...
Im gona b droppin the tranny to check the clutch and presure plate 2 c if theres anythin wrong there and 2 re-inspect the tranny and release bearing...
Anythin else I should look 4?...
Any help would b great...
Car: 1983 Z-28
Engine: 5.7 L
Re: T5 wont engage into any gear
Ok thanks...anything else u guys think might b wrong?...
Received 1,666 Likes
What else would you like?
Does it work OK now that you've fixed that?
Car: 1983 Z-28
Engine: 5.7 L
sorry I havent checked it...im gona check that 2day if not 2morrow...i wana just get ideas of wat can b wrong cuz I wana puz me Zeee back on the road...
Check the pilot bearing or bushing while you're in there, whichever you used, make sure it didn't get damaged when you replaced it or anything.
Glowsock
09-06-2015 06:40 AM
UltRoadWarrior9
09-02-2015 08:24 PM
