replacing icm
Old 07-12-2011, 03:37 AM
scarr001's Avatar
Car: 92 camaro rs anniversary edition
Engine: v8 5.0 Tbi
replacing icm
So to replace the icm I am going to need to take the distributor cap off, what's the best way to mark it to make sure I get it back on correctly- at least close enuff so then I can tweak it?
Old 07-12-2011, 11:12 AM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
Re: replacing icm
The cap only goes on correctly one way, so no need to mark anything. Making sure the plug wires get back in the same places is the important part
Old 07-12-2011, 11:47 AM
scarr001's Avatar
Engine: v8 5.0 Tbi
Re: replacing icm
@henryd3 thnx so much for the info- maybe I should go to a mechanic bcse I didn't know I had to remove the plugs!
Old 07-12-2011, 12:03 PM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
Re: replacing icm
You don't need to remove the plugs, but you probably need to remove the plug wires from the cap to get it off. This is pretty easy, you can do it if you have any kind of mechanical ability at all, and a little organization and patience. What kind of engine is this you're working on?
Old 07-12-2011, 12:15 PM
scarr001's Avatar
Engine: v8 5.0 Tbi
Re: replacing icm
Henry3d thanks, I can't tell u as a single mom how great u guys are! its a 92 camaro v8 5.7 ok so I could put a piece of tape with the plug number on it?
Old 07-12-2011, 12:38 PM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
Re: replacing icm
That's one way that will work. Do you have a Chiltons or similar manual to use for reference? Not the best, but a good starting point for most basic operations like this. So you have a Z-28 with a TPI motor with the distributor under a cover at the back of the engine, or is it exposed where you can see it? And BTW, why are you changing the module?
Old 07-12-2011, 02:58 PM
scarr001's Avatar
Engine: v8 5.0 Tbi
Re: replacing icm
Henry3d thanks, I did have a manual but it was taken. I have a schematic of the plugs if that's what I need? The reason I am replacing the icm is bcse the car will run vroom vroom vroom and then go vroom sputter and then more sputter as if its flooding and then it will stall and not start for hours and hours and then do the same. Its a regular distributor behind the air filter its not fuel injected its a v8 5.7 I have had the whole fuel system changed out twice, plugs, wires etc etc.
Old 07-12-2011, 03:25 PM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
Re: replacing icm
Yeah, sounds like a possibility that's your problem. Yes, as long as you write down which # plug wire goes on which pole on the cap and you can identify the wires either by labeling or if they're original or Delco they may already be numbered for you, getting them back in the right place shouldn't be a problem. So it's take off cap, remove rotor(checking both for unusual wear), unplugging and then unscrewing module from the dist and removal. Be sure and coat the bottom of the module with the dielectric grease that is supplied with it before installing, or you invite early module failure. Reverse steps and you should be good. Manuals are good to have and cost about $20 at most parts stores. So your car is carbed now, with a coil-in-cap distributor ? Good luck with this, just be careful not to drop the tiny screws
Old 07-12-2011, 04:29 PM
scarr001's Avatar
Engine: v8 5.0 Tbi
Re: replacing icm
Thanks Henry3d I have got to tell u I luv that car, but aftr being garaged for years and now all the trbl when my teenage son drives it,its getting hard to keep luving it
Old 07-12-2011, 05:21 PM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
Re: replacing icm
Cars don't respond all that well to sitting around for long periods of time. Well, good thing there's a TGO to help you out. I know some stuff, but little about carbs. Fortunately lots of people here do. Do you have a mechanical or leftover electric fuel pump in the car?
Old 07-12-2011, 07:02 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: replacing icm
Unless you know that you (or someone else) changed to a carb setup, it's probably a TBI car - the TBI unit looks just like a carb, but has 2 injectors inside, and in which case it's probably a 305 (5.0) motor and not a 350 (5.7).
You can just take a sharpie, and mark on the dist cap numbers at each wire, and mark the same numbers on each wire boot.
pimp2303
07-27-2017 02:03 PM
Thornburg
08-30-2015 08:05 AM
Winchester1094
08-18-2015 10:23 AM
bradleydeanuhl
08-12-2015 11:48 AM
Fronzizzle
08-09-2015 01:15 PM
Quick Reply: replacing icm
