another 5.3 LM7 build
Old 07-07-2011, 01:38 PM
1SICK90RS's Avatar
Car: 1991 Camaro RS
Axle/Gears: Stock
watsup third gen, i figured since alot of people are doing ls swap's into a third gen, i'd go ahead and give it a shot.here is my parts list:
5.3 LM7 [X]
4L60E
spohn k member w/ lsx mounts
warlboro 255 pump
custom ground cam from texas speed
tea ported ls6 heads with beehive springs and tsp hardened rods
fast 90, or 92 whichever i can find
fast 90mm throttle body
fast fuel rails
stainless steel fuel line conversion
full spohn suspension
BODY & INTERIOR
4th gen dash assembly and console
front bumper
hood [X]
fenders
that's about all i'm gunna need to do the complete conversion and be able to get the car on the road... if there is anything i left out tell me and i will edit as i am new to these conversions. this project will hopeully kick off around january but as of right now i'm just rounding up parts
car started it's life as a 305 tbi automatic, sadly after 14,000 original miles the previous owner smacked it into a tree... the car was sitting up three years until i decided to buy it, not bad for 500 dollars, all of the interior is ment, it's all there, and it all WORKS!!!
may have gotten a 4.8 for trade, not a 5.3 but i've heard that the only difference between the 2 is the stroke and pistons... engine comes with ECM but no harness
Old 07-07-2011, 01:48 PM
1SICK90RS's Avatar
Car: 1991 Camaro RS
Axle/Gears: Stock
Re: another 5.3 LM7 build
Old 07-07-2011, 02:26 PM
1SICK90RS's Avatar
Car: 1991 Camaro RS
Axle/Gears: Stock
Old 07-07-2011, 02:56 PM
five7kid's Avatar
Engine: LS1/LQ4
Transmission: 4L60E/4L80E
Originally Posted by 1FSTBRD
t56 transmission (4th gen camaro)
Make sure it's a '98-'02.
Old 07-07-2011, 03:01 PM
1SICK90RS's Avatar
Car: 1991 Camaro RS
Axle/Gears: Stock
motor is supposedly a 2001
Old 07-07-2011, 03:06 PM
Guest
Guest
Posts: n/a
Pistons interchange, though LM7 was dished, LR4 was flat-top. LR4 had longer rods to go with the shorter stroke.
Old 07-07-2011, 03:09 PM
1SICK90RS's Avatar
Car: 1991 Camaro RS
Axle/Gears: Stock
so if i change the rotating assembly i will have a 5.3?
Old 07-07-2011, 03:32 PM
Guest
Guest
Posts: n/a
Yes, but if you're going to do that, may as well get the block bored and make it a 5.7L.
Old 07-07-2011, 04:26 PM
Z28FAST1's Avatar
Might want to upgrade from that LS7 clutch if you're going to be putting down more than 400rwhp.
Post up some eye candy, we love pictures here
Old 07-07-2011, 05:55 PM
1SICK90RS's Avatar
Car: 1991 Camaro RS
Axle/Gears: Stock
idk how to post pics, i can post links?
Old 07-07-2011, 07:45 PM
1SICK90RS's Avatar
Car: 1991 Camaro RS
Axle/Gears: Stock
pics can be seen here:
http://s869.photobucket.com/albums/a...birdboi79/1990 camaro rs
Old 07-07-2011, 07:49 PM
1SICK90RS's Avatar
Car: 1991 Camaro RS
Axle/Gears: Stock
link above doesn't work, this one should:
http://s869.photobucket.com/albums/a...20camaro%20rs/
Old 07-07-2011, 11:51 PM
five7kid's Avatar
Engine: LS1/LQ4
I was talking about the T56. You said "t56 transmission (4th gen camaro)"; that could mean '93-'02. You don't want a '93-'97 LT1 T56.
Old 07-08-2011, 12:20 AM
1SICK90RS's Avatar
Car: 1991 Camaro RS
Axle/Gears: Stock
o ok, will look next time i'm at a junk yard...
Old 07-09-2011, 09:27 PM
1SICK90RS's Avatar
Car: 1991 Camaro RS
Axle/Gears: Stock
guy hit the tree so hard that it wedged the drive shaft into the transmission
Old 07-12-2011, 01:59 AM
1SICK90RS's Avatar
Car: 1991 Camaro RS
Axle/Gears: Stock
could someone provide me with a pin up for the 4.8 ECM? me and a buddy are going to try to tackle all of the wiring ourselves to save funds
Old 07-12-2011, 03:59 AM
UnstableAviator's Avatar
Car: 1984 Camaro
Axle/Gears: Ford 9"/4.30
If you find a t56 of any sort at a junkyard, well, that's pure luck. T56 trans are hot items, you can realistically expect to pay close to 1,000 for a good one that doesn't need any work.
Old 07-12-2011, 09:40 AM
1nasty86's Avatar
Car: 1986 camaro
Engine: ls2
Transmission: FLT stage 6 60e
Axle/Gears: 8.8 with 3.73's
X 2.... t-56's are not going to be found in a junk yard anywhere around here
Old 07-13-2011, 06:59 PM
1SICK90RS's Avatar
Car: 1991 Camaro RS
Axle/Gears: Stock
found my headers today, they are 1 3/4 tubing with a 3 inch collector for $190. it's a kit from speedway motors so welding will be required...
Old 07-14-2011, 05:11 PM
1SICK90RS's Avatar
Car: 1991 Camaro RS
Axle/Gears: Stock
Moderator, please delete this thread, it's gunna be a while before i can get around to ls swap
Old 07-21-2011, 08:37 AM
1SICK90RS's Avatar
Car: 1991 Camaro RS
Axle/Gears: Stock
ok guys, ordering my 4th gen pedals shortly from hawks, and i was wondering, do i need to include the neutral safety switch, and brake switch, or will those even be necessary?
also getting the 4.8 sometime this weekend, from there i will begin the tear down, and rebuild process. i'll try my best to get some "eye candy"
Old 07-21-2011, 10:19 AM
five7kid's Avatar
Engine: LS1/LQ4
Why do you think we'd do that?
Old 07-21-2011, 10:20 PM
1SICK90RS's Avatar
Car: 1991 Camaro RS
Axle/Gears: Stock
idk, just figured that this thread was taking up valuable space and i was getting discouraged, now about the pedals??? kinda on the need to know basis, waiting to figure out what i need before i order them
Old 07-24-2011, 03:22 AM
1SICK90RS's Avatar
Car: 1991 Camaro RS
Axle/Gears: Stock
UPDATE: got the crappy 305 and 700r4 out a few hours ago, getting the 4.8 tomorrow.
Old 07-24-2011, 09:51 AM
1SICK90RS's Avatar
Car: 1991 Camaro RS
Axle/Gears: Stock
Anybody??? also found a tremec t56 transmission kit, is it suitable for a 5.3?
Old 07-24-2011, 10:19 AM
1nasty86's Avatar
Car: 1986 camaro
Engine: ls2
I bought a nss from advance and I used my stock brake switch.
Old 07-24-2011, 10:21 AM
Guest
Guest
Posts: n/a
Post up a link to the kit.
Old 07-24-2011, 10:28 AM
1SICK90RS's Avatar
Car: 1991 Camaro RS
Axle/Gears: Stock
http://www.americanpowertrain.com/GM...T56-Basic.html
Old 07-24-2011, 10:29 AM
1SICK90RS's Avatar
Car: 1991 Camaro RS
Axle/Gears: Stock
so somewhere down the road i will end up needing the nss?
Old 07-24-2011, 10:35 AM
Guest
Guest
Posts: n/a
Wow!
If you have the funds, that'll get 'er done.
Heck, they probably even give you your choice of gear sets.
Old 07-24-2011, 10:39 AM
1SICK90RS's Avatar
Car: 1991 Camaro RS
Axle/Gears: Stock
Wow!
THEY DO, WHICH BRINGS ME TO THE NEXT QUESTION, WHICH GEARS ARE THE BEST TO GO WITH?
Old 07-24-2011, 10:51 AM
Guest
Guest
Posts: n/a
You shoulda seen this coming: Best for WHAT?
Surviving your future twin-turbo LS3 408? The 2.66 / 0.50 set. Strongest.
MPG? Same.
Driveability with a pure stock 5.3? depends on your axle ratio.
The 2.66 set has close ratios, good for keeping the revs down for MPG, or up for performance.
With close ratios, you don't have to rev as high before you can make each upshift. But when racing, the closer ratios keep the RPM from dropping below your powerband.
With that 0.50:1, and a 5.3, you'll probably need at least a 3.73:1 axle. Even so, that's about the same highway cruising result as a 700R-4 / 4L60E with a 2.73:1 axle.
Old 07-24-2011, 10:27 PM
1SICK90RS's Avatar
Car: 1991 Camaro RS
Axle/Gears: Stock
MPG? Same.
speak my language please
on another note, got the 4.8 today, due to weather and no place to work we just set her in the bay for now, pulling back out tomorrow to get measurements for motor mounts..
Old 07-26-2011, 02:24 AM
1SICK90RS's Avatar
Car: 1991 Camaro RS
Axle/Gears: Stock
here are a few pictures of the car, i will post pics of the motor and hood i got when i get the time to take them
Old 07-26-2011, 02:25 AM
1SICK90RS's Avatar
Car: 1991 Camaro RS
Axle/Gears: Stock
more pics
Attached Thumbnails another 5.3 LM7 build-4.jpg   another 5.3 LM7 build-5.jpg   another 5.3 LM7 build-6.jpg
Old 07-26-2011, 02:27 AM
1SICK90RS's Avatar
Car: 1991 Camaro RS
Axle/Gears: Stock
Attached Thumbnails another 5.3 LM7 build-9.jpg   another 5.3 LM7 build-10.jpg   another 5.3 LM7 build-11.jpg
Old 07-26-2011, 08:04 AM
Guest
Guest
Posts: n/a
Was it a theft recovery? All 4 tires flat, one shredded...gotta wonder
Old 07-26-2011, 08:19 PM
1SICK90RS's Avatar
Car: 1991 Camaro RS
Axle/Gears: Stock
na it wasn't a theft recovery, his son hit a tree a few years back and it's been sitting ever since, tires were completely dry rotted, but looked brand new before we put it on the trailer, it took us 5 hours to load it up, we started at 8:30 at night, finished up at 1:30 in the morning
Old 07-27-2011, 01:26 AM
1SICK90RS's Avatar
Car: 1991 Camaro RS
Axle/Gears: Stock
ok guys, i need your help loacating a few sensors, such as the MAF, and also i need to know what the coil control plugins look like...
Old 07-28-2011, 10:53 PM
1SICK90RS's Avatar
Car: 1991 Camaro RS
Axle/Gears: Stock
doing the wiring saturday, already got the motor back out and on the stand, goin to pertify it while it's out... planning on busting it off on the ground before it goes back in the car. pocket's "ls1 harness start to finish" thread is great help to anyone planning on doing the wiring themselves
Old 07-29-2011, 07:09 AM
88FormulaKiller's Avatar
Car: 1967 Firebird P.T.
Engine: LS3 4" Strkr 422ci
Transmission: MN12 6 speed
Axle/Gears: 3.73 8.5" 10 Bolt Eaton
hey i just wanted to give you this option on the T56, 93-97 LT1 T56's CAN be used in your swap, you have to change the front plate (mid plate, w/e u prefer) the input shaft and bellhousing to LS1 T56 parts. The 93 and 94 T56's are not as in demand due to lesser torque capabilites (93 M28 360 ft/lb, 94 M29 400 tq). Also the 93 M28's had a slightly different gear ratio. so id suggest 95-97 or the usual 98-02. I only tell people about this because you never know, you might find a random rebuilt or low mile T56 from one of those years cheap and when you swap the parts out, they can be sold to recoup the $$$. All parts needed to swap can be found on thegearbox. I couldnt find a reasonable low mileage or rebuilt 98-02 T56 so i bit the bullet and dropped $2K on an low mile MN12 from an 04 GTO. Good luck with whichever you decide.
Old 07-29-2011, 07:21 AM
1SICK90RS's Avatar
Car: 1991 Camaro RS
Axle/Gears: Stock
thanks, but i've decided to go 4l60e route for now, but i'll definately keep that in mind..
fun begins now, got all of the harness off of the 4.8 and i'm about to start stripping it down, now would be a great time for pocket to come in...
Old 07-29-2011, 07:41 AM
Pocket's Avatar
Car: 92 Firebird
Engine: Supercharged 6.0
Axle/Gears: 8.8 3.73
93 T56's cant be used. You have to change the input shaft which has 1st gear cast into it. 93's have a different 1st gear ratio and the gears wont line use
Whats up fstbrd?
Old 07-29-2011, 07:50 AM
1SICK90RS's Avatar
Car: 1991 Camaro RS
Axle/Gears: Stock
right now i'm stripping down the harness unlooming it
Old 07-29-2011, 09:54 AM
1SICK90RS's Avatar
Car: 1991 Camaro RS
Axle/Gears: Stock
ok so right now i'm trying to remove the wires from the pcm mounting thingy, but i don't want to F**K anything up, is there a special way you remove the pins???
Old 07-29-2011, 10:58 AM
Pocket's Avatar
Car: 92 Firebird
Not really, they're the easiest to get out of any connector on the harness. No special tools are needed
Old 07-29-2011, 11:11 AM
1SICK90RS's Avatar
Car: 1991 Camaro RS
Axle/Gears: Stock
a little late pocket as i have all of the pins out, a thread on ls1tech taught me hownow just gotta untangle everything and repin, i still have the piece that went through the firewall of the truck, that's kinda holding me back right now, do i need to dismantle it as well?
Old 07-29-2011, 01:23 PM
Pocket's Avatar
Car: 92 Firebird
Cut it off
Old 07-29-2011, 07:36 PM
1SICK90RS's Avatar
Car: 1991 Camaro RS
Axle/Gears: Stock
ok guys, wiring isn't bad at all, all i have left is to splice all of the grounds and IGN wires back together, and repin and then start on the 3rd gen harness
Old 07-31-2011, 12:17 AM
1SICK90RS's Avatar
Car: 1991 Camaro RS
Axle/Gears: Stock
not much of an update, but i'm still hung up on the wiring, probably would have been done yesterday but i've misplaced my black tape (gotta have alot of it) got the majority of the harness broke down and bundled up, still gotta break down the third gen harness and pin everything back up
Quick Reply: another 5.3 LM7 build
