oil pan drain bolt wont budge.... how to remove??
Old 07-04-2011, 08:06 PM
WILL85IROC's Avatar
Car: 85 IROC-Z Z-28, BLUE & SILVER
Engine: 5.7L & 5.0L
Axle/Gears: FACTORY
im trying to change the oil in my car, its a 85 iroc, 5.0 tpi... the drain plug bolt is stuck and wont turn.... i tired to turn it for a bit but then stopped because i dont know what damage i could to the pan if i really force... in the mean time i hosed it down with some wd40 and will try again in about an hr... if it doesnt work how do i drain the old oil so i can change it???
Old 07-04-2011, 08:56 PM
Robby12's Avatar
Re: oil pan drain bolt wont budge.... how to remove??
there is one way to drain the oil on a sb Chevy and its threw that stuck drain plug if the oil pans not super rusty get a long backer bar on it and a six point socket and brake it lose other then that there's not much you and do,PB blaster works well for stuck bolts
I would stay away form heating it at all so you don't burn up oil in it and get stuck with sludge
Old 07-04-2011, 10:06 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
either the plug has to come out, or the pan has to be dropped - no other alternatives.
Old 07-04-2011, 11:25 PM
affliction1's Avatar
Car: 89 chevy camaro rs
i second the breaker bar
i use the bar from my jack. assuming you have one use it or a piece of pipe,slip it over ratchet and use it as a cheater bar ive done this neumorous times,with oil drain bolts,flywheels,and reinstalling harmonic balancers(works great)
Navy8125
08-21-2015 09:32 AM
MY87LT
08-17-2015 08:43 AM
matthew911
08-12-2015 09:38 AM
89mulletbird
Southern California Area
08-10-2015 10:16 AM
gwade12
08-08-2015 08:17 AM
Quick Reply: oil pan drain bolt wont budge.... how to remove??
