700r4 wont shift 3-4
Old 06-24-2011, 12:54 PM
oramac91's Avatar
91z was shifting into third and forth wont now.(plugs were fouled)Black)Took for atest drive .Was fine for a few miles.then droped out of forth.It shifs but like it shifts into neutral.3,4.........Have 1,2 but that it.not like computer cars. (Put new motor in very over stock!)Please help
Old 06-24-2011, 01:21 PM
Guest
Guest
Posts: n/a
Re: 700r4 wont shift 3-4
Do you still have second gear? If not, you lost the band. Otherwise, IDK and I'm curious. I've read that no fourth can be a problem with a servo seal.
Old 06-24-2011, 09:52 PM
oramac91's Avatar
ya have frist and second
Old 06-25-2011, 01:19 AM
antoine's Avatar
Car: 1988 camaro z28,1997 camaro lt1
Engine: 355 afr 195 heads,tpis big mouth
Transmission: 700r-4 built by me 3-4 z pack
Do you have third if not the 3-4 clutch pack is no good
Old 06-25-2011, 10:33 AM
torque_is_good's Avatar
yup
so it's rebuild time
do a search on this site (that's a hint) and any other site where the 700r4 or 4l60/e are discussed and you will see no 3rd or 4th is very common
It's your transmissions way of saying it wants you to spend money
Old 06-25-2011, 12:24 PM
NeoTath's Avatar
Car: 1987 Firebird Formula 350
Transmission: 700-R4
happened to mine too. after about 50 miles on the new rebuild trans, 3-4 didn't work. the band broke to go in 3rd gear. so i needed a new trans or rebuild the one i had. if they are not rebuilt right, or been sitting awhile like mine did before it got used. bands break very easily. did it shift really hard through all the gears? mine did, way too hard. got my transmission for $100 and it works even better than the new rebuild one.
Old 06-25-2011, 02:50 PM
DISCLAIMER
you are the exception and not the rule
$100 transmissions tend to be just that; $100 transmissions
Old 06-26-2011, 06:25 AM
oramac91's Avatar
just put a b&m traspack into it to.This sucks *****!!!Thanks all!!!!!!!!!!!!!!
Old 06-27-2011, 08:12 AM
many who feel the onset of transmission slippage will install a shift kit on the advice of their inexperienced friends. Others will change the tranny fluid and filter. Both are desperation plays trying to ignore the obvious
good luck
Old 06-28-2011, 11:40 AM
oramac91's Avatar
?? Did i say that?
loud91rs
10-05-2015 10:05 PM
indygene
09-26-2015 11:21 AM
Dragonsys
09-25-2015 03:51 PM
6998poncho
09-25-2015 02:56 PM
HikoriYami
09-21-2015 07:11 PM
Quick Reply: 700r4 wont shift 3-4
