700R4 tailshaft housing and drive gear removal
Old 06-22-2011, 02:27 PM
RMK
RMK's Avatar
Car: 87 IROC
Engine: modded LB9
Transmission: Pro Built 700R4
I'm half way through swapping over my rebuilt 10 bolt with the new posi and gears and I'm needing to remove the tailshaft housing to swap out the driver gear in the 700R4. What I'm wondering is...
1. Is there a lot of fluid in the tailshaft housing? If the rear of the car is jacked up, will there be fluid running out to warrant a pan to collect it or just the odd drip?
2. Is there any special process for removing the clip that holds the speedo gear on?
I'm just wanting to be prepared and remove any potential surprises.
Thanks.
Old 06-23-2011, 01:12 AM
jmd
jmd's Avatar
Car: `86 SS / `87 SS
Re: 700R4 tailshaft housing and drive gear removal
1) rear up won't be too bad; I'd set a pan there
2) press in the part that's pushing up against the gear. Tap the gear over and away from the clip.
Old 06-23-2011, 07:05 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Maybe something helpful here:
http://sethirdgen.org/vss.htm
JamesC
Old 06-23-2011, 04:24 PM
UnderCover89TBI's Avatar
Engine: gone
Transmission: gone
Axle/Gears: gone
JamesC. Hey thats a good post man. That's some good info. Basically it isnt too hard to do at all to the OP. You'll be able to knock it out in no time.
Old 06-23-2011, 05:05 PM
89RS_82Z's Avatar
Car: 89RS(other cars & pics in vBgarage)
Engine: LO3, 305 TBI Mildly Modified
Transmission: BakerBuilt 700R4 w/B&M Megashifter
Axle/Gears: 3.23 Auburn Pro Series LSD
yea im fixin to have to do that for the new trans i got, thanks for the link
Old 06-26-2011, 03:47 PM
RMK
RMK's Avatar
Car: 87 IROC
Engine: modded LB9
Thanks for the replies guys. Just needing to find the time to get out there and do it now.
specialized
06-18-2022 09:26 AM
jklein337
09-19-2018 06:23 PM
Reddeath210
10-06-2015 08:20 AM
thefirebirdm@n
South Central Region
09-14-2015 01:45 PM
3rdgenparts
08-08-2015 07:09 PM
Quick Reply: 700R4 tailshaft housing and drive gear removal
