700r4 shifting hard from 1st into 2nd...
Old 06-14-2011, 10:23 PM
BigRogZ28's Avatar
Car: 1992 Camaro RS
Engine: Was L03 305 TBI...now BB 454 :)
Took my car into the tranny shop today, don't want to get ripped off. Anyone know what this problem could be? It's a rebuilt tranny within 7 years, and less than 50,000 miles, probably not even 25,000 miles!! When you really get up on the gas from a stand still tranny hits hard shifting from 1st to 2nd, like someone's hitting the bottom of the car...looked at tranny mount, it is in excellent condition for the age of car...1992 Camaro RS 305
any help MUCH appreciated!!
Old 06-14-2011, 10:34 PM
hellz_wings's Avatar
Car: 1986 Chevrolet Camaro IROC-Z28
Engine: TPI 310ci (LB9)
Transmission: Custom Rebuilt 700R4 - 2600 Stall
Axle/Gears: 10 bolt, 3.73 Eaton Limited-Slip
Re: 700r4 shifting hard from 1st into 2nd...
Depends what it actually sounds like.. Did it just start happening? Mine shifts VERY hard even in part throttle. This happened right after the rebuild as I had asked for hard shifts (corvette servos, higher pressure pump etc.). Could be a performance transmission for all we know?
Old 06-14-2011, 10:49 PM
BigRogZ28's Avatar
Car: 1992 Camaro RS
I've had the car for two years now, I'd love it if it was performance built, but this problem has only happened in the last month! It literally feels and sounds like someone is taking a hammer in hitting right under the center console, and it jerks the whole damn car lol
Old 06-15-2011, 01:55 AM
geoffz28's Avatar
Car: 88 IROC-Z
Engine: 5.7 TPI
Axle/Gears: Moser 12bolt 4.10s
broken trans mount maybe?
Old 06-15-2011, 01:58 AM
Pro Built Automatics's Avatar
Then it is the transmission mount, even if it looks good unless there are some bolts missing or loose on the mount. As for the 1-2 hard shifts, the transmission builder porbably blocked the accumulator or used the B&M valve body kit. Either way that is not good in the "long run". Part throttle shifts should not be very noticeable, just WOT shifts.
Old 06-15-2011, 01:15 PM
HawkZ28's Avatar
Car: 86 Z28
Engine: Built 312
Axle/Gears: 10 bolt 3.42
^X2. I had the same problem. Mine looked good while in the car too......but it came out in 2 pieces. I now have a nice dent where the balancer on my aluminum driveshaft was hitting the tranny tunnel.
Old 06-15-2011, 01:34 PM
evilemokid94's Avatar
Car: 1986 camaro Sports Coupe
Engine: L31 350
Transmission: 89 700R4
Axle/Gears: 3.42 gov lock
check the mount and make sure your tv cable is adjusted correctly
Old 06-15-2011, 06:35 PM
Stevolwevol's Avatar
Car: 86 IROC Z, 92 RS
Engine: 305 4bbl, 305 TBI
That sound is too patented to be anything else but a bad tranny mount.
Old 06-15-2011, 06:46 PM
RS Chris's Avatar
Car: 1991 RS
Engine: 5.0
Agree to all above.
Old 06-15-2011, 07:04 PM
BigRogZ28's Avatar
Car: 1992 Camaro RS
Well, got my car back today, they say tranny needs completely rebuilt....should I believe them?
Old 06-15-2011, 09:04 PM
I would definitly get a second opinion.
Old 06-15-2011, 09:25 PM
BigRogZ28's Avatar
Car: 1992 Camaro RS
I'm not great with tranny lingo, but they said a spring was broken in the 1st gear and that third and overdrive were slipping, and something else I can't remember. I did have them put on a polyurethane tranny mount and the bang/hard shift is still there. I really don't want to get my tranny rebuilt...BUT might be a good time to look into a beefed up 700r4 now for the same money as getting this one rebuilt! I dunno...any suggestions!
Old 06-15-2011, 09:39 PM
There are many used r4's out there that would bolt in. If you are concerned about spending lots of money, this would be a viable alternative. Tranny shops will insert there hands deep into your pocket.
Old 06-16-2011, 01:53 AM
Is the 1-2 shift hard? Or just making a noise? Does it make the noise at all throttle openings? How does the transmission shift to you? Are all 4 gears there? Does torque converter lockup work alright? If these things are ok....... then the transmission shop just wants your money.
Old 06-17-2011, 07:58 PM
xX89RSXx's Avatar
Car: 1989 Camaro RS
My tranny mount was bad and looked ok from under car. The rubber was actually seperated from the metal. you can't tell unless you remove and inspect. When hitting the gas from a stop the tranny would hit on bottom of the floor. Replaced with ploy mount and all is good.
Old 06-17-2011, 08:13 PM
Just out of curiosity, did you replace the mount, or was it the shop that told you you needed a complete rebuild?
Old 07-05-2013, 04:36 PM
Buglimit's Avatar
I am going through the same scenario with hard shifting, also shifts hard going into gear. when inched forward or reverse sounds like a small clicking(universal joints?). shifts better after gone through to OD.
This was rebuilt with shift kit HP.
is this TV linkage?
Fluid smells ok, level ok.
Old 07-11-2013, 05:49 PM
rusty vango's Avatar
Car: 86 IROC
Engine: 5.0 TPI
Transmission: 700-R-4
Axle/Gears: 2.73 open
I would look at the torque arm bushing as well as the mount
F-body driver
03-06-2023 11:44 AM
Hotrodboba400
12-10-2019 07:07 PM
db057
04-28-2019 07:45 AM
TheTraut88
09-07-2015 05:22 PM
Hotrodboba400
09-02-2015 07:28 PM
Quick Reply: 700r4 shifting hard from 1st into 2nd...
