camaro dies after it warms up
Old 06-07-2011, 09:47 PM
blown-z's Avatar
Car: 1989 iroc-z
Engine: supercharged 305
Transmission: automatic
My 89 iroc was stored for 2 years-took it out and it started shaking during idle. Then it would barely run and then shut down-Replaced fuel pump and filter. Ran fine for 15 minutes-then died. Was told i have three bad injectors. Could that be causing the problem? Any advise would be appreciated
Old 06-07-2011, 10:12 PM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Re: camaro dies after it warms up
yup. injs can cause this.
Old 06-07-2011, 10:14 PM
blown-z's Avatar
Car: 1989 iroc-z
even if just three are bad?
Old 06-08-2011, 01:03 PM
JustCruzin's Avatar
That blows, maybe they just need to be cleaned. The little filters in them can clog up or dry out fall apart and generally cause disaster. Or just replace them and be done with it.
Old 06-08-2011, 05:54 PM
southbay08's Avatar
Who told you that you have 3 bad injectors? How do they know? If the car sat for 2 years there is a good chance that the injectors are dirty/clogged....but did anyone test them??? You can also check the resistance. Anything less than 11 is indicative of coil failure which means the injectors need to be replaced.
www.southbayfuelinjectors.com
516-492-6504
Old 06-08-2011, 08:14 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Might also try the ignition module inside the distributor - could have accumulated rust on it when sitting, and thus gets hot and fails.
pimp2303
07-27-2017 02:03 PM
mustangman65_79
04-14-2017 05:37 PM
Andrew6.688
12-13-2015 10:59 AM
legendaryhero7
08-12-2015 06:19 PM
Quick Reply: camaro dies after it warms up
