adjusting kickdown cable?
Old 06-07-2011, 02:21 PM
evilemokid94's Avatar
Car: 1986 camaro Sports Coupe
Engine: L31 350
Transmission: 89 700R4
Axle/Gears: 3.42 gov lock
how do i do this? i changed moters in my car and now when i shift from 1st to 2nd my rpms go to 3500RPM before it shifts so how to i adjust it?
Old 06-08-2011, 11:29 AM
Engine: L31 350
Re: adjusting kickdown cable?
anyone?
Old 06-08-2011, 11:47 AM
chazman's Avatar
Transmission: World Class T-5
Axle/Gears: BW 3.45
Here you go...
http://www.tvmadeez.com/article/index.php
Old 06-08-2011, 06:14 PM
Bobby Suth's Avatar
Car: 1990 firebird,1989 Iroc z,1986 fire
Engine: 3.1lt,5.7tpi,3.1mpfi
Transmission: auto,auto
Axle/Gears: 273?277
my cable housing did not come back out any when I went to WOT.And the picture of the valve bushing thing.that looked like some kind of bracket.Where in the world is that thing?Before I put the 700r4 in I don't remember seeing it on the tranny.and it's not around the motor.I've got a 350tpi in a iroc.89type.I put a tranny from a 91rs in.I dosn't want to shift when cold untill 3500rpm.then after warm seams slow to shift down.and NO PASSING gear.I'm trying to make this adjustment.I think im missing somthing here.
Old 06-08-2011, 10:20 PM
Bobby Suth's Avatar
Axle/Gears: 273?277
OK,It's easyer than that.At least it was on my camaro.I finaly looked in the maintanace manuel.You find the tv cable where it gose through the throtle bracket.you push in on the side peace that is shaped like a D on some.mine was more oval.while holding it in slide the cable housing tward the rear of the vehical till it stops and let go of the D thing.There are pics of it on the link chazman provided.after that take the throtle linkage and open it up all the way.then go for a ride to see if yours was as easy as mine.Mine worked great for an old used tranny out of a recked car.$250.00 and a day under my car(priceless)
88SS6SPEED
11-11-2015 07:05 AM
WejaZ28
10-03-2015 07:38 PM
corey8084
Brakes
09-15-2015 08:14 PM
SG91camaro
09-05-2015 10:27 PM
Buickstaged
Brakes
09-04-2015 07:53 AM
Quick Reply: adjusting kickdown cable?
