1.6 Roller Rocker ????
Old 06-04-2011, 03:00 PM
Gallileo60's Avatar
Car: 89 RS, 92 Z28
Engine: 305 TBI, 350 TPI
Transmission: 700R4 Both Cars
Axle/Gears: 3.23 Posi.. 4 wheel disc both cars
Who, or how many out there are running 1.6 roller rockers on their TBI 305, with NO HEAD MODIFICATIONS??? Has anyone had pushrod clearance issues??? Thanks for any replies to this....Tom
Old 06-05-2011, 04:02 PM
Schurkey's Avatar
Re: 1.6 Roller Rocker ????
Self-aligning rocker arms???
Old 06-07-2011, 11:27 AM
UnderCover89TBI's Avatar
Engine: gone
Transmission: gone
Axle/Gears: gone
my buddy ran some 1.6 on his 305 tpi with 416 heads but with a stock camshaft. with no problems. but that head design is different then the centerbolts.
Old 06-07-2011, 06:59 PM
l_dis_travlr's Avatar
Car: 90 Formula -- tot resto in progress
Transmission: 700R4 w/ 2500 stall, by Owen @ ARD
Axle/Gears: 3.23 posi disc
Dude, where you at?
Haven't seen you at the gas shop since it re-opened. PM me...
Most of the aftermarket 1.6 rollers are to wide for the stock center-bolt
head-covers -- the oil breather won't fit in between them.
I wound up going with some Crane's that are specifically for these GM heads.
And they were, as you might guess, price-ier than e-bay bargains.
Also the push-rod length is a bit different (shorter if I recall) to keep the
roller properly centered over the valve. Off-center will cause excessive
side-wear on the valve guides. At least thats the theory.
I'm pretty close to getting mine running -- when I get back in town soon.
kk
Old 06-07-2011, 09:08 PM
82_Camaro's Avatar
Car: 82 Z28
Transmission: Turbo 200C
Axle/Gears: 3.43
i will be using comp cams 12-364-4 cam with 1.6 self aligning magnum roller rockers and magnum lifters and push rods. there will be clearance issues so i will need to machine the heads. if your using the stock cam then u should be fine if not you may need to mod your heads.
Old 06-07-2011, 09:38 PM
Gallileo60's Avatar
Car: 89 RS, 92 Z28
Yes mine are self aligning....
Old 06-07-2011, 09:41 PM
Gallileo60's Avatar
Car: 89 RS, 92 Z28
Originally Posted by l_dis_travlr
Dude, where you at?
kk
Have Comps version, the clearance problem is in the hole in the head where the push rod goes thru...Am at a different Gas Shop, same Company..Hurricane Ike took my job out at the old place...
KO1
16
10-15-2015 05:00 PM
Agent507943
Firebirds Wanted
10-02-2015 07:18 AM
92projectcamaro
09-29-2015 07:07 PM
dusterbd
09-29-2015 08:40 AM
tcarlos13
Interior Parts Wanted
09-28-2015 06:31 PM
Quick Reply: 1.6 Roller Rocker ????
