Clockwise or Counterclockwise?
Old 05-19-2011, 09:18 PM
Paddiee's Avatar
Car: 1987 Firebird Aftermarket Trans Am
Engine: 5.7 V8
How do I tell? I want to buy a fan that bolts to the water pump pulley. It's a SBC 350 from a '72 Nova. There are counterclockwise and clockwise fans. I don't know how to tell. Help is appreciated.
Old 05-19-2011, 09:34 PM
blackbmagic's Avatar
Car: 1985 IROC-Z
Axle/Gears: 3.42 10 Bolt Posi
Re: Clockwise or Counterclockwise?
Your first clue would be in the rotation of your water pump start your car and find out.
Next either look in the description, or if you are viewing the fan in person. Looking at the front of the motor if the fan is spinning clockwise the blades should be on a downward slope from engine forward. If it spins counterclockwise the blades should slope upward.
Or spin it to see which way it pushes.
Old 05-19-2011, 09:42 PM
t-top havoc's Avatar
Car: '87 Camaro
Engine: '92 Carb'd 350
Axle/Gears: factory stock
You want a fan that spins clockwise, pulling thru the rad.
I don't recall fan blade orietation, but you should be able to get a fan from a u-pull-it type of jy, or get a new 1 from your local parts store, Jegs, Summit, etc, or talk to a local mechanic // machine shop.
There are 2 types--
clutch & fixed.
Fixed fan is always turning, clutch fan either works by temperature or rpm, & engages when needed. I forget which makes it operate.
( edit )
Old 05-19-2011, 10:40 PM
Paddiee's Avatar
Engine: 5.7 V8
I can't start it because the engine is out of the car. It's on an engine stand. It's an OEM long water pump.
Old 05-19-2011, 11:02 PM
8t2 z-chev's Avatar
Car: '82 z28
Engine: L83 5.7
Transmission: 700r4-1985
Axle/Gears: 3.42 posi
if its a v-belt setup it is clockwise rotation-most pre-88
chevy v-8 are all clockwise rotation.
If you find a v8 firebird shroud,it is meant for a 17"fan
thirdgen '82-85 camaro v-8 shrouds us a 18.5" fan-
not sure if the camaro shroud will clear the hood on a
firebird.
Old 05-19-2011, 11:11 PM
Paddiee's Avatar
Engine: 5.7 V8
firebird.
I'm running 1/2 serp, 1/2 V belt. Would that affect anything? I assume it wouldn't. Thanks for the help!
Old 05-19-2011, 11:13 PM
LS4GXP's Avatar
Car: 87 Z28
Engine: AFR 383
Axle/Gears: 4:11
firebird.
Chevy v8's are not all clockwise. unless am reading your post wrong.
V belt = clockwise
Serpentine system = counterclockwise
V belt systems the grove on the belt is on the pulley, serpentine system the smooth part on the belt is on the pulley.
Old 05-19-2011, 11:26 PM
8t2 z-chev's Avatar
Car: '82 z28
Engine: L83 5.7
you missed the"most pre-88"part-AFAIK,the only pre
-88 chevy v-8 with CCW rotation water pump is '84 up
"C4"corvettes.The mid-85 thru '87 partial v-belt setup
Old 05-19-2011, 11:34 PM
Paddiee's Avatar
Engine: 5.7 V8
lol just clarifying even more. I gotcha. Thank you much for the info.
Old 05-19-2011, 11:36 PM
LS4GXP's Avatar
Car: 87 Z28
Engine: AFR 383
Axle/Gears: 4:11
now i get it....
sometimes when you post
like this the information
could be confusing..... :P
gta892000
08-11-2019 11:16 AM
mike22115
09-28-2015 04:49 AM
Dragula
Carburetors
05-10-2002 11:40 PM
Slow Iroc
04-09-2001 11:09 PM
Quick Reply: Clockwise or Counterclockwise?
