How to install new clip on rear wheel cylinder?
Old 05-07-2011, 04:30 PM
Jason444's Avatar
Car: '92 Formula, '92 TA, '91 ZR-1
Engine: 350, 305, LT-5
Hi everyone,
I am replacing the wheel cylinder on the left rear of my '92 and cannot figure out how to install the new spring steel retainer that holds the wheel cylinder in with the limited space behind the backing plate. I can't figure out how to get enough leverage on it to lock in place. Any suggestions?
Thanks,
Jason
Old 05-07-2011, 04:34 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: How to install new clip on rear wheel cylinder?
It's been a long time since I did one, but I remember it being a royal PITA. Determination will be the best tool for the job. I can't for the life of me remember how I got that sucker back in, but I don't have any fancy tools, so it was sheer determination and just enough being PO'd that got it for me.
Old 05-07-2011, 06:31 PM
mooch1's Avatar
Car: 1985 camaro Z/28
Engine: 305 V/8 4bbl carb
Transmission: T5 WC
Axle/Gears: 3-23 posi with 4 wheel discs
clamp the cylinder so it stays put,,,then take the clip and place it at the right place..then tap it in..it should just wedge itself in when you tap it ..remove the clamp that was holding the cylinder and make sure the cylinder doesn't move.
Old 05-07-2011, 07:13 PM
Jason444's Avatar
Solved the problem...I just took 1 1/8" socket, put it over the retainer, and used a C-clamp to squeeze the retainer in place by putting the bottom of the clamp on the front of the wheel cylinder. Just had to think about it awhile.
Old 11-12-2011, 12:25 PM
bdizzle2499's Avatar
Car: 1986 Camaro
i still cant get mine on, and even when i push the cylinder into the slot it doesnt sit very flat and rocks like it doesnt fit even tho it looks the same as the old one
Old 11-13-2011, 07:11 AM
plemon90ta's Avatar
Car: 1990 TA
Engine: 350 in the works
Transmission: th700r
Axle/Gears: 10 bolt Eaton Posi 373
Just replaced mine. Even with the new clips, the wheel cylinder still wiggles a bit.
Old 11-13-2011, 01:46 PM
Car: 1986 Camaro
just got it on, i used a 1 and 3/8 circular drill bit and wedged wood infront of the cylinder to hold it steady and i got it after a couple trys you really just have to get the right angle. but it sits in there nice and snug. but now i have to put these stupid springs back on :/
1992rs/ss
05-19-2020 07:02 PM
Vintageracer
01-10-2020 05:33 PM
1992rs/ss
16
01-28-2016 09:58 PM
B_Dubya
08-26-2015 05:09 PM
kah992
08-19-2015 02:55 PM
Quick Reply: How to install new clip on rear wheel cylinder?
