I keep burning my spark plug wires
Old 04-30-2011, 07:28 PM
spade's Avatar
Car: 1989 Mystery Firebird
Engine: 350 FIRST TPI
due to me having vortec heads and long tube headers.... i keep either burning the wire or burning the boots. mostly the boots.....
any recommendations?
ive been hearing about ceramic boots?
Old 04-30-2011, 08:21 PM
TNT_Z28's Avatar
Car: 1987 Camaro Z28
Engine: 355ci, XE262 , 650dp
Transmission: T-5, RAM clutch
Axle/Gears: 3.23 limited slip
Re: I keep burning my spark plug wires
Most boots stand up to indirect heat relatively well...
Is there any part of the wires or boots actually touching the head or primaries?
I've fabricated my own "looms" that hold the wires away from any surfaces
Old 04-30-2011, 08:29 PM
spade's Avatar
plugs are VERY close to the headers... pinkys width room....
Old 04-30-2011, 08:35 PM
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
Transmission: Custom Built 700R4 w/3,500 stall
Axle/Gears: QP fab 9" 3.70 Truetrac
Defenitely use some kind of loom to keep the wires neatly away from the header tubes. As far as the boots go, boot protectors are available that go over the boots to sheild them from extreme heat. I can't remember the brand I've used just now. Maybe Spectra? Look for them at a performance automotive supplier like Summit Racing. Warning, they are not cheap. Also, if your exhaust temp seems excessive, look at timing to be retarded, exhaust too restrictive. Excessive exhaust temp will burn up alot more than your plug boots.
Old 04-30-2011, 09:04 PM
t-top havoc's Avatar
Car: '87 Camaro
Engine: '92 Carb'd 350
Axle/Gears: factory stock
Accel shorties plugs if you like Accel products.
Definitly some sort of loom & retainers.
Old 04-30-2011, 09:27 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am, 92 Firebird
Transmission: TKO600, T5
these work well
http://www.summitracing.com/parts/TAY-2528/
but you normally have to take the boots off to slide these on.
Old 04-30-2011, 09:50 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
and they are available at any autozone/advance/oreillys
1992 Trans Am
05-10-2023 07:19 PM
apo_bailon15
03-28-2016 05:20 AM
Bryan F
08-18-2015 02:28 PM
eightsixseven
08-14-2015 03:09 PM
Quick Reply: I keep burning my spark plug wires
