taking a carbed 2.8 and putting fuel injected stuff on it?
Old 04-14-2011, 04:06 PM
evilemokid94's Avatar
Car: 1986 camaro Sports Coupe
Engine: L31 350
Transmission: 89 700R4
Axle/Gears: 3.42 gov lock
i have an 86 camaro and i found a cheap 2.8 that runs strong but its carbed. can i put my fuel injected stuff on it?
Old 04-14-2011, 06:40 PM
Project 3.4 Camaro's Avatar
Car: 1996 Camaro, 1985 Camaro
Engine: 3.8, 3.4
Transmission: WC T5, 700r4
Axle/Gears: 3.23(?), 3.42
Re: taking a carbed 2.8 and putting fuel injected stuff on it?
Yes.
Old 04-14-2011, 07:49 PM
Engine: L31 350
alright, its coming out of an 84-85 s10 with a manual so i wanna make sure everything works
Old 04-14-2011, 08:07 PM
Engine: L31 350
what would you say this engines worth?, its my step dads uncle who buys junk cars and scraps them and he remembered i needed an engine, hes getting my old engine after the swap so he could still junk it and he told me to just tell him a price i thinks right, but i dont wanna offer too low, i was thinking $100. also do i need anything to do this swap besides my intake, and fuel system, sensors so what else/
Old 04-14-2011, 08:20 PM
Engine: 3.8, 3.4
Idk without knowing the condition and mileage of the engine or how complete it is, but I wouldn't go over $300 for a 2.8 for sure, esp since I got a complete 3.4 for $250, even got the tq converter. So probably $100-300.
Old 04-14-2011, 08:25 PM
Engine: L31 350
its complete, he was driving it till it dumped the transmission for the second time. im not going over $200 since hes getting my old block and everything off
Old 04-14-2011, 08:37 PM
Engine: 3.8, 3.4
Yeah I wouldn't go over 200 either for a 2.8 tbh, I would only go $300 if I were having trouble finding a larger drop in displacement for less, ie. a 3.1 or 3.4, or if I didn't care about power much(but I do, hence the 3.4,lol)
Might I ask whats wrong with the engine you have?
Old 04-14-2011, 08:40 PM
Engine: L31 350
rod knocking
Old 04-14-2011, 08:59 PM
Engine: L31 350
its out of a 93
Old 04-14-2011, 10:46 PM
84CAMARO28inFL's Avatar
Originally Posted by evilemokid94
its out of a 93
I really hate my browser it deletes my posts!
.. ok in a nutshell:
1) how do you ADD/Change injectors on a Carb'd engine?
2) What ALL S-10 2.8 OR 3.4L (years? Cars?) is needed for this?
3) HOW DO YOU DO IT?
Ok not threadjacking as i said in my post my browser ate.. but yes, curious. Thanks!
Old 04-15-2011, 09:44 AM
Engine: L31 350
is there anything im gonna have to take off my old moter to do the swap or is it pretty stright forward and just like the one in my car now? i know i need the intake and the fuel rails and the sensors but what else?
Old 04-15-2011, 10:10 AM
Engine: 3.8, 3.4
Basically just pull your engine, swap in the other engine as a shortblock, ie. block, cam, in this case heads(not the normal definition of shortblock) lifters, timing cover, WP, and just use your original intake manifolds with fuel rail+injectors, also the MPFI heads have ever so slightly larger valves, so if you care about performance and are replacing the HGs anyways(personally I would) then you can also use your original heads.
Old 04-15-2011, 10:12 AM
Very nice basic guide How much more performance is yielded?
And is this the same as putting on a 3.1 or 3.4 head?
Old 04-15-2011, 10:16 AM
Engine: 3.8, 3.4
84 what he is doing is an engine swap for the sake of replacement, entirely different scenario than swapping one for power, if you are looking for ways to get more power, read my sticky at the top of the v6 section.
Old 04-15-2011, 07:36 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
Good thing the engine is out of a late model S10... I was thinking it was an early pre-85 engine when I saw the heading, which would make the swap more trouble than it's worth.
The 93 is NOT carbed, it's TBI (same intake but a fuel injection carb instead of an old-school E2SE carb). You do NOT need to swap cylinder heads as they are the same (any RWD head after 85 to 95.5 is the same along with the TBI Lumina and similar vans). Everything above the intake swaps over nice. May need to swap over the exhaust manifolds, however, in case they aren't the same. And, of course, all of the accessories and brackets if they are different. Almost forgot that the only other thing you will want is a water pump... Front covers are the same on all RWD engines as well.
The engine you have is good for one thing... Scrap. And it's not worth much at that, either.
Old 04-15-2011, 07:41 PM
90 camaro cj's Avatar
Car: 1990 camaro RS
if hes using his old acc. he doesnt want the new water pump as the new water pump will be rev. flow... he could use the acc. off the S10 and have serp setup then
Old 04-15-2011, 07:44 PM
Engine: 2.7L V6
Axle/Gears: 4.41
I don't recall saying he wanted a water pump for the S10 engine, just that he's going to want a new one period... Never know how long the pump has sat dry on the engine and how good the seals and such inside are...
Old 04-17-2011, 04:35 PM
Engine: L31 350
alright i got my engine stuff today. i got chevy red-orange engine paint, oil and filter, doughnut gaskets, dizzy gasket, oil pan gasket. also i wanna keep the engine as stock as possible. so im gonna use the camaros acc, also dan, both engines are running. the s10 was my step dads uncles, he killed two 5 speeds in it and decided to sell it. iv heard it run so nothing is dry, same as mine, not dry, i get the engine saterday. well the entire truck saterday
Old 04-17-2011, 04:42 PM
Engine: L31 350
are these engines pretty much the same inside? same cam, crank? also which intake is better? the TPI or the one MPFI?
Old 04-17-2011, 05:08 PM
Engine: 2.7L V6
Axle/Gears: 4.41
IIRC, the truck engine may have a cam designed around torque and not power... Other than that, they're the same...
Get a new WP for the 86 engine as you CANNOT use the S10 pump on the V-belt accessories, unless you want to swap the alternator and power steering pump pullies to use the S10 accessory brackets. And even then you'll need to do something about the A/C compressor if you have one as the pulley on there is difficult at best to change and requires special tools. The reason this is because the 2 water pumps flow in reverse of each other, and if you spin the reverse-flow serpentine pump on a V-belt engine, you're "new" engine won't last long as it will overheat like crazy due to no coolant flow.
Old 04-17-2011, 05:10 PM
Engine: L31 350
im keeping the 86s acc setup... i have no desire to put the s10s setup on.
Old 04-17-2011, 05:14 PM
Engine: 2.7L V6
Axle/Gears: 4.41
And, while the engine is out and what not, I'd put a new timing chain set on as you can't possibly know how old it is unless he's told you so...
Old 04-17-2011, 05:16 PM
Engine: L31 350
dont know, i know he did alittle work to it before putting the new tranny in but 500 miles later, poof
Old 04-17-2011, 05:18 PM
Engine: L31 350
i know it runs healthy, and starts up no problem, i only ran it for about 3 minutes though, no leaks from what i saw and it seemed alright.
Old 04-17-2011, 05:24 PM
Engine: 2.7L V6
Axle/Gears: 4.41
Well, ask if he's done the timing chain recently, or ever... If he hasn't, if I were you, I'd rather do some preventative maintenance now rather than having to do it if/when it breaks AND pay the tow truck . Oh, and a full gasket set, if he hasn't done that either, might be good... Especially the rear main seal and oil pan gaskets.
Old 04-17-2011, 05:26 PM
Engine: L31 350
already got the gaskets
jhawkeye
05-25-2022 06:33 PM
midge54
12-27-2019 04:14 PM
9192camaro
16
02-03-2019 12:21 AM
84z96L31vortec
08-20-2017 12:16 AM
84z96L31vortec
08-10-2015 08:27 PM
Quick Reply: taking a carbed 2.8 and putting fuel injected stuff on it?
