lost reverse, drives forward in neutral (700r4)
Old 03-24-2011, 10:09 PM
Gibson's Avatar
Car: 1989 Camaro IROC-Z
Engine: LB9
Axle/Gears: 3.08 G80
so i think my tranny died. it revers i can rev it to 2 grand and it wont move. in nuetral it just lurches forward and i can give it gas and it will go. i think my forward clutch is stuck. i think i killed my tranny
Old 03-25-2011, 03:12 AM
bradley23150's Avatar
Car: 83 Trans Am / 96 Jeep XJ
Engine: 355 / 4.0 I6
Transmission: TH350 / Auto
Axle/Gears: 3.23 10-bolt / 4wd
Re: lost reverse, drives forward in neutral (700r4)
Make sure the shift cable is properly adjusted before making a major decision.
Old 03-25-2011, 06:05 AM
Gibson's Avatar
Engine: LB9
98% sure its the tranny. It strains to go forward when its in park. If the parking pin wasn't engaged, it would go forward.
Old 03-25-2011, 10:29 PM
Pro Built Automatics's Avatar
Check the internal linkage to see that it has not come loose.
Old 03-26-2011, 08:50 PM
insomniac's Avatar
Car: 1991 Firebird Convertible
Engine: 5.7 L98
Axle/Gears: 3.45 9 Bolt Posi
yeah defiently going to find melted and siezed forward clutch, planetary prob shot too. Check cooler flow after rebuild may have caused total meltdown in the unit. I saw one of those this week in a 4l60e escalade.
Old 03-26-2011, 09:05 PM
Gibson's Avatar
Engine: LB9
wc t-5 ftw?
Old 05-30-2011, 02:16 PM
mikiman's Avatar
Did you solve your problems ? I have the same. The reverse doesn't work, and when I put the N, the car moves. All the wires and cables seems ok. Now I have the transmision out of the car, and next week I want open the gear box looking for something broken, but I have never done it. Problably the reverse band or the clucht it's old.
I was looking for in youtube any video explaining how to do it, but I only found for the 4L60e, not for the 4L60 ( 1990 V6 Firebird ).
I have the service manual, but don't explain how to do it, and as you see, my English it s very bad and it's dificult to me to understand the technical words.
Old 05-30-2011, 03:10 PM
insomniac's Avatar
Engine: 5.7 L98
no either a planet is blown or a clutch pack is seized and staying on. if you never opened a transmission before. dont even attempt it. trust me
Old 06-05-2011, 02:29 PM
mikiman's Avatar
I know it's very dificult, but I haven't nothing to loose. In Spain repair it it's more expensive than buy one in the USA and pay the delivery and taxes.
I opened it and I have found something rare :
Between the valve body and the valve filter are a check ball case with a little damage, like as the ball had too much travel working and the ball consume it . And with the gasket it happens the same. I have read the manual service, and says that it's the "55F #8 check ball (2nd /1-2)". I suppose that these didn't have relation with the reverse, but it' posible that the presion works bad in the circuit ?
Uploaded with ImageShack.us
Tomorrow I will take of the pump to see the band. What it's the size to know if it's too small ? or how can I know if it doesn't work well ?.
Thanks a lot
BlueIroc-Z
06-09-2019 03:22 AM
camaro11j
09-19-2018 08:49 AM
wbrooks63
Exterior Parts Wanted
10-04-2015 08:40 PM
BewleyBizzIROC
08-14-2015 02:52 AM
mizz0313
08-12-2015 06:45 AM
Quick Reply: lost reverse, drives forward in neutral (700r4)
