700R4 Hard Shift
Old 03-23-2011, 06:40 PM
Timinsk's Avatar
Car: 1989 Camaro RS
Axle/Gears: 3.23 LS
700R4 Hard Shift
Trying to figure it out.
From P to R or D it'll give a hard thump feel, basically my idea of a hard shift i guess. But while driving in Reverse or from 1,2,3 & OD I have no issues.
Anyone else experience this issue?
Old 03-23-2011, 06:45 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: 700R4 Hard Shift
Sounds like time for drive shaft U-joints.
Old 03-23-2011, 07:05 PM
chevydrvr's Avatar
Car: 1985 camaro Z28
Engine: 305 5.0 V8 carburated
I had the same issue after I replaced my tv cable It turns out that the one I bought was bad, but I fixed it,and I have no problems now. The cable would get caught inside the cable housing and cause high line pressures within the transmission. Does it shift hard while you drive too?
Old 03-23-2011, 07:06 PM
Timinsk's Avatar
Car: 1989 Camaro RS
Axle/Gears: 3.23 LS
weird because I just did them last year near end of the summer...
Old 03-23-2011, 07:07 PM
Timinsk's Avatar
Car: 1989 Camaro RS
Axle/Gears: 3.23 LS
hmm, doesn't have a hard shift feel just a bit of a drop from rpm to shift, mid 3k to shift and gives a slight feel like its a stick powershifting :P haha
I did notice on & off that my shift indicator is off a bit, sometimes its good sometimes its not always on the right spot
Old 03-23-2011, 07:09 PM
chevydrvr's Avatar
Before I fixed mine, the shifts were late and hard. Now she shifts like a dream. I would jsut check out your tv cable, and maybe readjust it. If you know how...it's simple.
Old 03-23-2011, 07:11 PM
Timinsk's Avatar
Car: 1989 Camaro RS
Axle/Gears: 3.23 LS
I told my father about the indicator and told me that the holder ont he tranny might be balding or something? being worn out.
but for what you said is there a guide? or pictures to show me how or what to do?
Old 03-23-2011, 07:17 PM
chevydrvr's Avatar
TO adjust the tv cable:
All while that car is NOT running...
1. Find the tv cable and push in the silver button on the side of it and hold it in.
2. Push the black slider part in (the part that the cable itself comes out of) push it in toward the button you are holding.
3. Release the button, and go inside the car and floor the gas pedal.You should hear it click a few times as it is "ratcheting out".
NOTE" Make sure the cable is not adjusted all the way out, and make sure there is no slack on the cable. It must be tight. If the cable is sticking out or adjusted out too far, the cable is sticking.
Old 03-23-2011, 07:32 PM
Timinsk's Avatar
Car: 1989 Camaro RS
Axle/Gears: 3.23 LS
tv cable is the throttle cable?.. or am i mistaken?
Old 03-23-2011, 07:39 PM
chevydrvr's Avatar
No, the tv cable is a separate cable that goes from the throttle body to the transmission. You have a 305 just like me, so the tv cable will be attacked at the throttle lever at the bottom. If you look there should be two cables connecting to the throttle body on the driver side. The bottom one is the tv cable.
Old 03-23-2011, 07:42 PM
Timinsk's Avatar
Car: 1989 Camaro RS
Axle/Gears: 3.23 LS
ooh ok
Old 03-23-2011, 07:57 PM
Timinsk's Avatar
Car: 1989 Camaro RS
Axle/Gears: 3.23 LS
this is what i see...
Old 03-23-2011, 08:00 PM
chevydrvr's Avatar
That bottom thin silver cable is your tv cable. From what it looks like it's not adjusted. Unless that IS the correct adjustment point. Just try to adjust it like I said earlier and take another picture of it.
Old 03-23-2011, 08:32 PM
Timinsk's Avatar
Car: 1989 Camaro RS
Axle/Gears: 3.23 LS
wheres teh button though your talking about? I dont see any buttons...
Old 03-23-2011, 08:37 PM
chevydrvr's Avatar
If you are standing on the driver side of the car, the button will be facing away from you. It isn't really a button per say, but acts the same way. If you look where the tv cable is mounted int eh bracket, you will see a silver "D" shaped metal part. That is the "button".
The picture I attached should help you out a lot.
Old 03-23-2011, 08:45 PM
Timinsk's Avatar
Car: 1989 Camaro RS
Axle/Gears: 3.23 LS
that helped alot, thanks! i'll try this out tomorrow
Old 03-23-2011, 09:37 PM
racerx520's Avatar
i had a similar problem when i shifted gears at high rpms or sometimes when just shifting gears i got a big thump right back near the back seats. turned out to to be the transmission mount was ripped apart. replaced it and it was fine (well actually the crappy napa one i put in first tore in half in about 2 days, so i had to get a high performance one)
Old 03-23-2011, 10:14 PM
Timinsk's Avatar
Car: 1989 Camaro RS
Axle/Gears: 3.23 LS
what was the specific part you replaced it with?
Old 03-23-2011, 11:05 PM
racerx520's Avatar
I forget. It was probably the most affordable performance tranny mount from jegs
Hotrodboba400
12-10-2019 07:07 PM
Vojtush31
10-11-2015 01:07 PM
TheTraut88
09-07-2015 05:22 PM
Randomtask2
09-07-2015 05:06 PM
Hotrodboba400
09-02-2015 07:28 PM
Quick Reply: 700R4 Hard Shift
