electric choke vs Manual Choke?
Old 03-21-2011, 01:37 PM
kazamh13's Avatar
Car: 1987 Camaro Z28
Engine: 5.0 TPI
whats the difference?
i have a 86 sports Coupe 305 carb... my stock carb have a seriuos problem so i need to replace it... i was looking for a Edelbrock or something like that... but i dont know what exactly need...
What do you recommend??
thanks a lot!
Old 03-21-2011, 06:13 PM
five7kid's Avatar
Engine: LS1/LQ4
Transmission: 4L60E/4L80E
I recommend you keep a carb like your stock one. If you don't rebuild what you have (assuming it has problems that would be fixed by a rebuild), get a rebuilt one like it.
I think I already asked you this before, don't recall seeing the answer: Which side is the car registered on, TJ or SD?
Old 03-21-2011, 06:34 PM
kazamh13's Avatar
Engine: 5.0 TPI
Re: electric choke vs Manual Choke?
Sorry dude... yeah i remembered you... my Camaros are registered in Tijuana both... but i work both sides of the border...
thanks for your answer dude...
Old 03-21-2011, 07:31 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Also, to replace factory carb with aftermarket carb, you'll need a vacuum advanced distributor, and a method of lockling the torque converter if it's an automatic.
But an automatic choke is electric, a manual choke you have to run a cable inside the car to pull manually (like the choke on your lawn mower).
gta892000
08-11-2019 11:16 AM
codeysabatini
11-10-2015 04:07 PM
tommy z-28
10-06-2015 10:58 PM
ndndndnd
Carburetors
09-16-2015 04:13 PM
Magman
09-12-2015 11:55 PM
Quick Reply: electric choke vs Manual Choke?
