Radiator fan wont shut off
Old 03-18-2011, 11:57 PM
Tory Cook's Avatar
Car: 1991 Camaro RS
Engine: 305 V8 5.0
hello, my problem has never happened before this spring. my car has been sitting over the winter and everything was working perfect until i drove for a while like an hour or so and then all of a sudden my radiator fan will not shut off. Even if i turn my car off and take key out of the ignition. My temp is around 140 degrees and it stays there i know its not that temp but it wont move. but when i start it up it will be at a lower temp but when i start driving it goes to 140-150 and flutters at times. any one have this problem or know of solutions. also the only way i can shut the fan off is to disconnect the battery.
Thanks in advance
Tory
Old 03-19-2011, 12:03 AM
84redta's Avatar
Car: 80 SE/TTA;88 T/A GTA;86 T/A
Engine: 4.9L Turbo; LT1; empty
Transmission: TH350; T56; empty
Axle/Gears: 3:23 disk; 4:10 disk ; 3.42 disk
Re: Radiator fan wont shut off
So does the fan stay on when the car is off? Or just when you start the car the fan turns on and stays on? The temps are normal to fluctuate as the fan comes on and off, at least on a TBI engine. Temps should be making it to 210 as far as I remember, been a while since i've been behind the wheel of my hibernating bird, but it's roughly just under half, and fluctuate to just above half till the fan brings it back to before half.
Old 03-19-2011, 09:08 AM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
For the gauge, try a new sender - driver side head, between #1 & #3 spark plug, has single dark green wire to it.
For the fan, unless someone has rigged it to run always, it won't run very long after key is off, but it will run for a minute or two sometimes after key is off. Might need a new fan switch, located pass side head between #6 & #8 spark plug, has single wire, mushroom-looking connector.
Old 03-19-2011, 11:41 AM
Tory Cook's Avatar
Car: 1991 Camaro RS
Engine: 305 V8 5.0
I changed the fan relay switch in it and i tired it but it doesn't change anything. The fan does run after the car is off and key out of ignition for ever until my battery would die. i took the positive off so it wouldn't drain the battery. i unplugged the sensor on the front of the motor to test if it was that but it wasn't. does anyone know if it could be that it isn't grounded right? if so how to go about testing it?
Old 03-19-2011, 11:55 AM
Car: 1992 RS
Engine: Carbed 350
I'm lost - something weird is going on.
Remove the relay, then see if the fan runs at all. Turn on the A/C to make the fan run with key on, if it does, let us know. That means the relay is not being used in the system.
Old 03-19-2011, 11:58 AM
1989GTABlown632's Avatar
Car: 1989 Pontiac Firebird Trans-Am GTA
Engine: Blown 632 CID with Nitrous
Transmission: TH400
Axle/Gears: 4:10
There should be a large bosch style relay either up front by the radiator or on the firewall I dont remember exactly, that controlls the main power to the fan. This relay can arc shut if its older when the fan is switched on. To check it pull out the relay and listen or feel for an internal click, if you dont here the relay click and the fan turns off you probably have a bad relay. Plug it back in and tap it with a pair of pliers or a screwdriver it may knock the contact loose. To check the relay you need a multimeter, and a 12v source. Put the coil terminals of the relays to 12v and meter the contact terminals. You should see them change state from open to shorted if the dont the relay is bad.
Old 03-19-2011, 12:25 PM
Car: 1992 RS
Engine: Carbed 350
He said he already replaced the relay. But - maybe he replaced the fuel pump relay and not the fan relay ... Fan relay has a large black with red stripe wire, fuel pump relay does not - that's how to tell the difference between the two.
Old 03-19-2011, 04:01 PM
Tory Cook's Avatar
Car: 1991 Camaro RS
Engine: 305 V8 5.0
this is what i was told was the problem and i replaced the part and it didn't change a thing. this is located near my firewall.
the picture above is the other sensor i took out and tested to see if it would change anything but it still isnt. Once i put the positive back on the battery the fan starts.
also i removed the relay and tried the a/c and it wouldnt work when the key was on but when i plugged the relay in it worked fine. radiator fan still was running.
i think it has to do with the wires them selves in my opinion but what do you think?
Old 03-19-2011, 04:58 PM
Tory Cook's Avatar
Car: 1991 Camaro RS
Engine: 305 V8 5.0
I tested the wire connected directly to the fan it self and it gave me a positive on both wires so one of the grounds is messed up:/
Old 03-19-2011, 05:22 PM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
It does sound like the relay may be fried and staying on. The fan relay looks just like the one in your pic, but is located on the driver side between the brake booster and the fender. There should be two of them behind a small metal frame that holds them. The fan relay has four wires going to it, the other one has five. That's the one to check/replace. The other sensor you show is the CTS and has no effect on the fan in your single fan system.
Old 03-20-2011, 01:45 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
It should not run at all with the key off. The coil side of the relay is powered by 'key on/run' only. It should not be powered during crank as well.
Old 05-29-2011, 06:40 PM
Electro_X's Avatar
Car: 84 T/A Recaro
Engine: L69 H.o
Hello everybody
I have the same problem.
Today i was Cruising all day and when i got home i park the car turn off the engine and the radiator far is still running so now i have to disconnect the battery.
no idea what's the problem
Old 03-05-2016, 10:44 PM
tiredgrunt0311's Avatar
Having the exact same problem. cant get the damn fans to turn off. its hit or miss. was driving all day today, didnt start acting up till much later on. after the car had sat for awhile.
Old 10-14-2020, 08:53 AM
venus1ntx's Avatar
Car: 1989 Camaro RS
Engine: 305 TBI V8
Did anyone ever solve this problem? I have the same issue with the fan running with the car off and the key out plus the SES stays lit with key on but has no codes besides 12. Any thoughts would be appreciated!
Old 10-14-2020, 09:27 AM
Received 1,666 Likes on 1,264 Posts
It's the fan relay.
The guy from years ago probably changed out the wrong relay.
Look for the one whose connector has a red or orange (big), blk w/red stripe (big), pink w/ blk stripe (small), and grn w/ wht stripe (small). Replace it.
1983Z28Custom
07-31-2012 01:18 PM
92FormulaBird
04-23-2008 08:50 AM
ad356
05-29-2006 06:50 PM
MikeDirntRulez
11-28-2004 11:17 PM
SpeedPhreak
04-11-2002 08:28 AM
Quick Reply: Radiator fan wont shut off
