Mystery Eibach Lowering Springs
Old 03-14-2011, 08:04 PM
janson327's Avatar
Car: 1982 Z28, 1983 Z28
Engine: 5.7L 530hp, 5.7L 430hp
Transmission: TH350, 700R4
Axle/Gears: Ford 9", 10 Bolt 3.23
Hey guys,
I just found a set of Eibach springs in my garage #3801.201 and #3801.202. I can't find any information on these springs or how much they would lower my vehicle. The number is similar to the current F-body springs but I am assuming that this is an older set no longer available. Anyone know anything about them?
Old 03-14-2011, 08:10 PM
Twin_Turbo's Avatar
Re: Mystery Eibach Lowering Springs
Those are pro springs, they are black right?
Old 03-14-2011, 08:11 PM
janson327's Avatar
Ya they are a dark gunmetal colour
Old 03-14-2011, 08:15 PM
janson327's Avatar
The standard pro kit springs have a number 3801.140, so these are different.
Old 03-14-2011, 08:21 PM
Twin_Turbo's Avatar
probably and old part number or the number directly off the spring? The 140 number is for the whole kit, the other number for a front or rear spring. The pro kit has very dark gray almost black colored springs and it sounds like that's what you have
Old 03-14-2011, 08:26 PM
janson327's Avatar
True enough, the numbers I gave are off the springs themselves. I guess I could always find out the hard way though and just sorta slap em on.
Old 03-25-2012, 01:37 PM
86t/a305tpi's Avatar
Car: 1986 Trans Am
Engine: LB9 305 TPI
Transmission: 700r4 w/shift kit
Axle/Gears: Borg Warner 9 bolt Posi
Did you ever find out any specs on those springs? I just got lucky at the junkyard and found some and I was wondering how much lower they'd be.
Old 03-26-2012, 09:06 AM
Steven6282's Avatar
Car: 1986 Z28 Camaro
Engine: 350 with .440" lopey cam
Transmission: 6spd T56
Axle/Gears: Detroit Truetrac with 3.73 gears
I can't say with 100% certainty that the first 4 numbers on my springs was 3801, but I know they ended in .201 and .202 for my Eibach Pro-Kits which are supposed to be a 1 inch drop. I swear they dropped mine more than an inch though, but I didn't measure before replacing them to know for sure =/
Old 03-28-2012, 07:59 PM
Car: 1986 Trans Am
Engine: LB9 305 TPI
Thanks. I'm going to try and put them on this weekend or next weekend. I'll be sure to measure the before and after and I'll post the results!
Old 03-29-2012, 12:24 AM
Flip 2's Avatar
Car: 1983 Firebird SE
Engine: C5 LS1
Transmission: 6 speed
The signature pic is with 90s Eibachs- thick spring isolator in rear.
Old 06-03-2012, 12:52 PM
Car: 1986 Trans Am
Engine: LB9 305 TPI
My drop was 1.5 inches. It took me a while to finally do the swap, but it's done
Bubbajones_ya
09-14-2015 08:38 PM
Lanz06
09-14-2015 07:16 PM
crzycamaro86
09-12-2015 05:51 PM
Chiknhawk
09-10-2015 08:55 AM
lakeffect2
09-07-2015 03:52 PM
Quick Reply: Mystery Eibach Lowering Springs
