Cast iron or aluminum heads what do have?
Old 02-27-2011, 11:12 AM
Gisys's Avatar
Car: 1989 IROC
Transmission: 5 speed
Axle/Gears: ???
How to tell the difference between cast iron and aluminum heads?
Here are some pictures. I FEEL 100% retared on this one thanks for any help you can give.
Attached Thumbnails Cast iron or aluminum heads what do have?-p1010175.jpg   Cast iron or aluminum heads what do have?-p1010176.jpg   Cast iron or aluminum heads what do have?-p1010178.jpg
Old 02-27-2011, 11:14 AM
toomany's Avatar
Re: Cast iron or aluminum heads what do have?
I'm going to say cast iron because of the rust on them.
Old 02-27-2011, 11:18 AM
Shadow Z's Avatar
Car: Lots of 'em
Pull off the valve covers and get the cylinder head casting number. Well, only pulling one of is necessary. That will give you a lot more useful information than just the material type.
Although, they have to be iron. Aluminum does not rust like iron will. Aluminum is not a ferric material, so it will only oxidize. Basically get very dull.
Here's some SBC head casting numbers.
http://www.kendrick-auto.com/chevrol..._number_re.htm
Hope I helped you out.
Old 02-27-2011, 11:22 AM
cuisinartvette's Avatar
Car: 67 ******mobile
Engine: 385 Solid roller
Axle/Gears: 4.11
Magnet wont stick to aluminum
Old 02-27-2011, 11:25 AM
///DAN///'s Avatar
Car: 1984 camaro Z28
Engine: 355 SBC
Transmission: 700 r-4
Axle/Gears: Strange 3:73 posi
they would be cast my friend it's pretty hard to confuse, cast look like that and aluminum look like well aluminum .
Old 02-27-2011, 11:32 AM
Gisys's Avatar
Car: 1989 IROC
Axle/Gears: ???
Thanks for the help guys. Not going to pull valve covers off today but will keep that in mind for when I do if ever. Just trying to get the right spark plug and felt like having another opinion.
junkcltr
08-02-2019 11:12 PM
Chuck84TA
07-15-2016 09:05 PM
anesthes
42
10-24-2015 07:30 PM
bdads
DIY PROM
08-24-2015 06:01 PM
Zeek1041
Theoretical and Street Racing
08-21-2015 08:45 PM
Quick Reply: Cast iron or aluminum heads what do have?
