cold air intake
Old 02-23-2011, 01:12 PM
acsvendsen's Avatar
Car: 89 Camaro RS, Black exterior,
Engine: Stock 305 TBI, K&N air filter
Transmission: stock 700r4
cold air intake
looking through summit saw a dual cold air intake for carb or tbi. would there be any benefits of spending the 100 dollars to obtain this? is there even enough room in the already tiny engine bay to run two air dams on opposite sides of the engine?
Old 02-23-2011, 01:22 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: cold air intake
In my opinion, not enough benefit to justify the expense. You can make your own using the stock TBI air cleaner - just cut another hole in the side, make a snout from some aluminum roof flashing and rivet it on, then use some air duct from auto store to route another intake hose to the pass side - can snag another plastic piece for the headlight bar off ebay to make it the same as the factory job.
There's also a ton of threads on here with pics of what others have done - just do a for "cold air intake"
1992 Trans Am
05-10-2023 07:19 PM
Brinkkl2000
08-04-2018 08:29 AM
stalkier
12-06-2015 11:25 PM
hayesaw0210
08-23-2015 11:15 PM
kyle5647
08-15-2015 11:56 PM
Quick Reply: cold air intake
