Organized Drag Racing and Autocross Drag racing and autocross discussions and questions. Techniques, tips, suggestions, and "what will I run?" questions.
driveshaft loop question
Old 02-19-2011, 12:02 PM
kowboy59's Avatar
Car: 88 iroc-z z-28
Engine: 383
Transmission: th400
Im ordering the lakewood one thats specifically designed for our cars. just wondering how it fits with say the spohn torque arm?? i have a transmission mount torque arm.
http://www.summitracing.com/parts/LAK-18020/
Old 02-19-2011, 12:11 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
Re: driveshaft loop question
If you run a larger driveshaft this one won't fit them. It wouldn't clear my 3.5" shaft during suspension travel. I bought the largest universal lake wood loop and ended up just cutting the ends off and rewelding them to match the floor pan angles.
Old 02-19-2011, 01:36 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
The Lakewood loop will fit normally with an aftermarket torque arm. It's bolted through the floor so you need to remove the seats and pull the carpet up to properly attach it.
I stopped using the Lakewood loop years ago. It was easier to attach a universal loop off the transmission crossmember. I think all the newer aftermarket torque arms use this feature. My old Spohn torque arm didn't.
Old 02-19-2011, 02:03 PM
kowboy59's Avatar
Car: 88 iroc-z z-28
Engine: 383
Transmission: th400
Well I didn't buy it with one for some damn reason. And I have a stock driveshaft size.
Old 02-19-2011, 03:55 PM
xpndbl3's Avatar
Car: 1984 Z28
maybe have spohn sell you just the loop and get a local shop to weld it up
Old 02-19-2011, 04:58 PM
kowboy59's Avatar
Car: 88 iroc-z z-28
Engine: 383
Transmission: th400
Lol well Spohn takes forever to send stuff and I'm in a time crunch unfortunately. I'll just get that one for now and mock it up if I need to
Old 02-24-2011, 02:34 PM
five7kid's Avatar
Engine: LS1/LQ4
Transmission: 4L60E/4L80E
You've probably already ordered, but I have the Jegster loop on both of my Camaros with 3" DOM shafts. Fits fine.
http://www.jegs.com/i/Jegster/550/40732/10002/-1
Irocguy01
09-28-2015 02:03 PM
CORV3TT3
DIY PROM
08-23-2015 11:26 AM
beast94
DIY PROM
08-20-2015 06:44 AM
redmaroz
08-16-2015 11:40 PM
Quick Reply: driveshaft loop question
