pioneer DXT-2266ub help
Old 02-14-2011, 07:20 PM
kmcn47's Avatar
Car: 84 Trans Am, 84 Fiero, 86 944
Engine: 5.0, 2.5, 2.5
Transmission: 5spd
having a ton of trouble with getting this in, and getting the speakers it came with to fit in the stock locations, anyone have on of these and know any way to make it work and could tell me, or if they just could show pics ?
Old 02-15-2011, 10:23 AM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
Re: pioneer DXT-2266ub help
as with any aftermarket radio, you'll need a wiring adapter to plug into the car harness, an antenna adapter to attach the factory connector, and a mounting kit to get the radio to fit in the din & 1/2 hole.
as for the speakers, you'll need to make adapters to get the rears to fit in the 6x9 spots, but should be pretty easy. up front, it may be tricky since the factory pieces are 4x6
Old 02-15-2011, 11:55 AM
The Project's Avatar
Car: 89 IROC
Engine: 305 TPI / ZZ4 cam
Transmission: Stage 2 700R4, LS1 driveshaft
Axle/Gears: Strange 3.42 w/ Auburn
Installation (mounting) kit - Scosche part number GM1516B
Wiring Harness (adapter) - Scosche part number GM02B
Old 02-15-2011, 02:12 PM
kmcn47's Avatar
Transmission: 5spd
hey thanks, the real trouble i was having is with the speakers got the back ones to fit, but idk what to do about the indash ones, or where else i could put them, the damn connector i got said for 82-92 firebird, it was from schoche and its the wrong thing, idk how i could have been so stupid not to look at it
Old 02-15-2011, 02:34 PM
Car: 89 IROC
What install issues are you having with the dask speakers?
What kind of speakers (make, model, size) are you trying to install?
Old 02-15-2011, 04:20 PM
kmcn47's Avatar
Transmission: 5spd
pioneer 6" speakers, not only are they too big around but they are also too deep to fit in the stock location, i cant figure a way to get them through the dashpad so that it can go back on like normal and lay flat otherwise the being too deep problem wouldnt be a problem
Old 02-16-2011, 08:36 AM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
without a lot of cutting and creativity, the front's are not going to work. your best bet would probably be to grab a set of decent 4x6's and try and sell the 6 1/2's to try and recoup a few bucks.
Old 02-16-2011, 09:48 AM
Car: 89 IROC
1ADAN's solution is probably your best bet.
There are some 5 1/4" speakers that would fit in the dash in the stock location under the pad. Just make sure to find a set of speakers that are less than 1 3/4" deep (otherwise you'll end up cutting into the top of the gauge cluster ).
I've seen a set of 6" in the dash but the owner cut the top of his dashpad in order to mount the speakers (personally, I wouldn't cut my dashpad, I'm just giving you options).
Old 02-16-2011, 01:57 PM
kmcn47's Avatar
Transmission: 5spd
well i'm not gonna sell my speakers or cut the dash, i guess i'll just have to find a way to mount them somewhere else like maybe the doors?
Old 03-07-2011, 05:38 PM
kmcn47's Avatar
Transmission: 5spd
managed to get everything in, just bought some sony 4X6s int he end, i recommend swapping the fuse from 10 to 15 though i blew mine just the other day, not sure why but the new fuse seems fine
Old 03-08-2011, 09:05 PM
evilemokid94's Avatar
Car: 1986 camaro Sports Coupe
Engine: L31 350
Transmission: 89 700R4
Axle/Gears: 3.42 gov lock
i have 6.5s in my dash and i didnt have to do anything?
Old 03-08-2011, 09:22 PM
kmcn47's Avatar
Transmission: 5spd
you have a camaro i have a firebird, i know they look pretty much the same but maybe theres a difference, mine woudnt fit under the dashpad and they were too tall, the diameter was no problem though
Old 07-24-2011, 11:41 PM
kmcn47's Avatar
Transmission: 5spd
wow old thread, but, would having the stereo hooked into the ignition (red wire) and the dead 12v (yellow wire) together be bad, because well i have no 12v wire really because it isn't hooked up i guess, would this kill my alternator if i was really jamming and had an mp3 hooked into it? i'm pretty sure it would as i'm gonna be on my third in 4 months now and although there remanned duralast ones, i really didn't have any problems until i put the stereo in, i just want my car to work dammit
Nick Locking
Car Audio
09-30-2015 04:24 PM
zayne0
08-24-2015 07:22 PM
Pukka
Aftermarket Product Review
11-25-2001 07:09 PM
Pukka
05-22-2001 03:15 PM
Quick Reply: pioneer DXT-2266ub help
