Big Block Sound..
Old 02-03-2011, 11:01 AM
BrandonSB's Avatar
Car: 1987 Z28 Camaro
Engine: 30Slow
Big Block Sound..
will i be able to get that big block choppy sound out of a 396? or do i have to go big block.. all help will be appreciated,kind of a dumb question but id like to know.. lol.
or any small block for that matter..
Old 02-03-2011, 12:12 PM
92 BBC Z's Avatar
Car: Currently have 3 cars and 1 truck.
Engine: 1970&92 Cams,both BBC's
Transmission: LS1 T-56 & PG w/vendor's
Axle/Gears: Built 10 bolt& 9inch w/spool
Re: Big Block Sound..
Brandon, when you say, "choppy" I assume your refering to the cam's lopey' idle sound. If thats what you mean, then yes. Sure, you can get the same "choppy" sound out of most any size sbc. Choosing a cam with a small lsa(lobe seperation angle) would produce a "choppy" sound but thats not the way to choose a camshaft. Try looking into Lunati"s Thumper series cam's, thats probaly the way to go.
Old 02-03-2011, 12:43 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
A 396 IS a big block. At least everyone I've seen is.
Old 02-03-2011, 01:02 PM
92 BBC Z's Avatar
True a Chevy Produced 396 is a Big Block, but I think he was refering to a bored and stroked sbc.
Old 02-03-2011, 04:04 PM
AmorgetRS's Avatar
For those asking about a 396 SBC
https://www.thirdgen.org/forums/tech...m-choices.html
Old 02-03-2011, 04:23 PM
five7kid's Avatar
Engine: LS1/LQ4
Transmission: 4L60E/4L80E
First, let's address the premise: Where did you get it in your head that big blocks have a choppy idle sound? My '66 396 BBC had as smooth of an idle as my 283 when both were stock.
Next, what are you really after? Just the sound? Don't care how it runs or drives?
If that's the case, look into the Comp "Thumper" series of cams. That's what they're all about.
FWIW, my son just picked up a 2001 Blazer with an LS1 swapped into it. The aftermarket cam they put in it has as choppy and mean sounding an idle as the 396 BBC with XS282S solid lifter cam in the '57 did. (We're hoping we can get it tuned so it sounds and runs better. )
Old 02-03-2011, 05:31 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
My 454 SS pickup truck has a nice rumble because of the dual Hooker Aerochamber mufflers on it but I wouldn't call it choppy. It has a computer friendly camshaft in it and I still get a lot of compliments on the sound. I can't sneak up on anyone.
My race car is very loud without mufflers but I run Magnaflow race mufflers on it and it still isn't choppy. Spectators have told me it sounds real good going down the track.
It all depends on the valve grind. If you want a cam that gives you a "rump rump" sound, don't expect it to have good street manners. Cams like that also need higher stall converters.
Old 02-04-2011, 01:01 AM
BrandonSB's Avatar
Engine: 30Slow
lookin for the sound and about 500+HP.
yes i care how it runs and drives, aswell i dont want too much of a gas eater(if possible) hahaha. pump gas aswell
Old 02-04-2011, 01:07 AM
BrandonSB's Avatar
Engine: 30Slow
i appreciate your input, and yes thats what im referring to, im gonna check out those cams. i like that old muscle choppy sound.
Old 02-04-2011, 01:26 AM
BrandonSB's Avatar
Engine: 30Slow
thumpr is from comp cams? they sound exactly like what i want lol.
Old 02-04-2011, 04:12 PM
Daz
Daz's Avatar
Car: 87 Camaro
Engine: Chevy V8
Transmission: auto
Sure!!
Get a cam in the 240-250@.050 duration (I/E),Dish pistons and stock 781 heads,Dont put any advance on the timing and rock on!!
Its so choppy that you might want to put a bit more advance on it just to keep it running
Old 02-04-2011, 04:13 PM
Daz
Daz's Avatar
Car: 87 Camaro
Engine: Chevy V8
Transmission: auto
just dont race V6 GM cars..lol
Old 02-05-2011, 12:40 PM
BrandonSB's Avatar
Engine: 30Slow
whys that, blast em off the road?
Old 02-05-2011, 12:41 PM
BrandonSB's Avatar
Engine: 30Slow
Sure!!
dont put any advance, then your telling me to put advance?
Old 02-05-2011, 02:41 PM
COTM Editor
QwkTrip's Avatar
Received 1,855 Likes on 1,270 Posts
Car: '89 Firebird
Engine: 7.0L
I think what you're after is the thunderous sound that shakes your chest, right? You don't want the crisp snappy noise. You want the kind of deep rumble that pulses through your body if you stand close to the car.
You want this kind of sound....
http://www.youtube.com/watch?v=yo_dCG0-S8w
That sound is rare in a street car. I've stood next to that car when it idles and it shakes your body. What I can tell you is it is a fairly high compression stroker LS engine with long tube headers and a Magnaflow premium catback system. My 2000 Camaro 6.0L has a similar rumpy idle (MS3 cam) with mild 10:1 compression and a cheap Hooker catback system and the sound is snappy raspy. However, I'll bet if I just put on the Magnaflow it would be a much deeper rumble. Exhaust makes a lot of difference.
Old 02-05-2011, 02:57 PM
BrandonSB's Avatar
Engine: 30Slow
basically yes, did it sound like this at idle?
http://www.youtube.com/watch?v=ZNe9i...layer_embedded
Old 02-05-2011, 03:09 PM
COTM Editor
QwkTrip's Avatar
Car: '89 Firebird
Engine: 7.0L
You just can't tell with video. It doesn't ever sound the same in real person. If I had to guess I would say, no. Those engines sound like a small block and don't have the big bore engine rumble. They have the right idle quality, but not the deep tone.
My suggestion is to go to a car show or drag strip when the weather warms up. Find 5 cars with the sound you like and find out from the owners what the build is like. One of those five will be similar to something you might be willing to do. There are a lot of combinations that will do the job. You just need to find one similar to what you can replicate with your parts. Remember, your car is a single exhaust. You need to focus on 3rd and 4th gen cars with single exhaust.
Old 02-05-2011, 04:55 PM
BrandonSB's Avatar
Engine: 30Slow
wont be single for long, and i dont have any parts yet, im waiting till i know what i want. have the money put aside, so any suggestions at this point would be wonderful, i know theres some work if you wanna drop in a big block for space, but im open to any and all suggestions, but i wanna stay big block.
Old 02-05-2011, 05:33 PM
Daz
Daz's Avatar
Car: 87 Camaro
Engine: Chevy V8
Transmission: auto
Easiest and only way to make a big block sound is put a big block..Not a small dinky big block.
Old 02-05-2011, 09:16 PM
BrandonSB's Avatar
Engine: 30Slow
454?
Old 02-06-2011, 02:23 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Originally Posted by BrandonSB
454?
Minimum
Old 02-06-2011, 02:36 PM
BrandonSB's Avatar
Engine: 30Slow
Originally Posted by Air_Adam
Minimum
496? ahahaha.
Old 02-06-2011, 02:39 PM
BrandonSB's Avatar
Engine: 30Slow
would i have to get more work done to an LSX block or a DART block, which one would be a better choice?
Old 02-06-2011, 02:47 PM
COTM Editor
QwkTrip's Avatar
Car: '89 Firebird
Engine: 7.0L
A big cube LS swap will be very expensive. You'll have $10K in the engine alone.
I have a supercharged 454 (468 actually) sitting in my Firebird right now. I am pulling it to go a different direction. I have custom made Lemons headers, March serpentine pulleys and brackets, and other stuff. If you want to go big block it would be cheaper to buy my setup for yourself. Let me know if you're interested. I'm in central Illinois. It will make a hell of a lot more power than a 396. I never finished it. The cam still needs to be broken in first time you start it (Crower supercharger cam).
Old 02-06-2011, 02:59 PM
BrandonSB's Avatar
Engine: 30Slow
i appreciate your offer, but id rather learn myself, i plan on building a 454 aswell.(boost and turbo'd in the future, posisibly a 496) but for now just a stock 454 will suffice. just not sure which block to go with?id like that classic big block muscle sound.what specs should i be looking for? would like 10:1 heres a few. i dont wanna spend too much but im looking between the 5-600hp mark.
http://www.summitracing.com/parts/NAL-19212192/
http://www.summitracing.com/parts/DRT-31273444/
http://www.summitracing.com/parts/DRT-31263444/
http://www.summitracing.com/parts/DRT-31263654/
http://www.summitracing.com/parts/DRT-31273344/
http://www.summitracing.com/parts/DRT-31273654/
http://www.summitracing.com/parts/DRT-SUM31273644/
http://www.summitracing.com/parts/DRT-31263454/
http://www.summitracing.com/parts/DRT-31263354/
theres so many big blocks on there im just confused hahaha. i just want a stock 454 for now but have the availability of 5-600hp W/O power adders, but also able to bore it out to a 496 in the future. what would be my best block to go with? i also want a thumpr cam, i like the sound of the classic muscle also wanna be able to turbo and boost it in the future, Carbeurated.. :S i have the money im just confused haha.
gimme some build ideas?
Old 02-06-2011, 03:04 PM
COTM Editor
QwkTrip's Avatar
Car: '89 Firebird
Engine: 7.0L
If you want to learn, you can always disassemble my engine and put it back together.
Old 02-06-2011, 03:59 PM
BrandonSB's Avatar
Engine: 30Slow
ahahahaha
Old 02-06-2011, 05:25 PM
92 BBC Z's Avatar
It takes more than just an over-bore to get 496 cu. in, you need a 4.25 stroke crank also.
Old 02-06-2011, 06:56 PM
Klortho's Avatar
Car: 1987 GTA
Axle/Gears: 9 bolt 3.70 posi
427 LS based motor?
gta892000
08-11-2019 11:16 AM
3GZJerry
LSX and LTX Parts
10-14-2015 05:17 PM
RyanJB
09-14-2015 03:39 PM
Nick McCardle
09-10-2015 08:36 PM
Quick Reply: Big Block Sound..
