hood louvers Iroc
Old 01-30-2011, 02:06 PM
Bobby Suth's Avatar
Car: 1990 firebird,1989 Iroc z,1986 fire
Engine: 3.1lt,5.7tpi,3.1mpfi
Transmission: auto,auto
Axle/Gears: 273?277
hood louvers Iroc
I had to take my hood louvers off the iroc and was as carful as I could be.I still broke 3 on one and 2 on the other.garbage all under them.Have to repaint the hood top,Is there any way to repair the studs I broke?Plus is there any replacment insulation for the hood?there are chuncks missing and oil heavy enuff to coat your fingers.clean oil too.Wonder how that got there?any guesses?
Old 01-30-2011, 02:31 PM
chevysquid's Avatar
Car: 1986 IROC T-TOP
Transmission: 700-R4
Re: hood louvers Iroc
I've heard of guys epoxying bolts on there and securing them with nuts.
Old 01-30-2011, 03:26 PM
Bobby Suth's Avatar
Axle/Gears: 273?277
that might do it.what about replacment hood insulation
Old 01-30-2011, 03:28 PM
The Project's Avatar
Car: 89 IROC
Engine: 305 TPI / ZZ4 cam
Transmission: Stage 2 700R4, LS1 driveshaft
Axle/Gears: Strange 3.42 w/ Auburn
Epoxy worked on mine when I refinished the louvers.
Try 1A Auto for hood insulation.
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Yeah - seen alot of bolts epoxied onto the louvers where the plastic tabs broke.
Old 01-30-2011, 09:31 PM
jchaussee's Avatar
Car: 85 Z28
Engine: 327
Bolts? Or just the treads? I have quite a few broke on mine also
Old 01-31-2011, 11:30 AM
Car: 1992 RS
Engine: Carbed 350
Bolt. The epoxy holds the bolt better since it has the bolt head to adhere around - more surface area = better hold.
Old 02-01-2011, 07:11 PM
Bobby Suth's Avatar
Axle/Gears: 273?277
that sounds good.I wont have to worry about them twisting off again.
Old 03-27-2011, 12:34 AM
david chambers's Avatar
Car: 1986 iroc Z-28
Engine: "LB-9" TPI 305
Transmission: 700-R-4
Axle/Gears: corporate 2:73-1
epoxy .25 bolts in the place of the broke studs,works like a charm
Old 03-29-2011, 08:31 PM
pleiku10's Avatar
I saw a post where they used velcro tape making it easy to pull the louvers off to clean underneath them-just a thought that I might try
Old 03-29-2011, 11:18 PM
coryprine's Avatar
Car: 85 Camaro Z28
Engine: 5.7 TPI
mine are epoxied....
Old 03-31-2011, 03:43 PM
znate's Avatar
Car: 87 iroc
Engine: 305 tpi
Transmission: t5
Axle/Gears: 3.73 posi
3m 2 way tape it works jus have to b careful taking them off the next time!
Old 04-03-2011, 07:42 PM
Bobby Suth's Avatar
Axle/Gears: 273?277
I epoxed the broken ones with short bolts with nuts and lock washers.replaced the old rubber washers between the louver and hood while at it.Is there anything that I can put on them to bring them back to a dark black that wont crack or flake?
Old 04-04-2011, 01:13 PM
MNformula350's Avatar
Car: 1990 Formula
Axle/Gears: 3:73 Posi
Yeah, Underhood heat was not nice to the Plastic Studs on those, Must be why they went to Metal Studs on the 91-92 Blisters.
I wonder why an aftermarket Company has not reproduced these, they would make a killing. Unless GM won't release the rights?
Frozer!!!
01-19-2024 04:55 PM
PestilenceIV
08-20-2015 02:33 AM
kyleb24
08-15-2015 08:24 AM
mustangman65_79
08-11-2015 03:17 PM
Quick Reply: hood louvers Iroc
