sbc 400 build starter question
Old 01-27-2011, 09:08 PM
tjtaylor's Avatar
Car: 1991 Camaro RS ttops
Engine: 00 383
Transmission: t-5
Axle/Gears: moser 9" 3.50
so im building a 1973 400 small block chevy, it is going in to my 91 camaro with the five speed it came in it, orignally has a tbi 305 in it. i pretty much have everything done on the motor almost time to put it in just waiting for thhose paychecks haha. i bought i ram flywheel that is 168 tooth. i bought it for the block not the car. and about to get a dual friction centerforce clutch kit for it. my question is can i just buy a starter for the engine and be fine cuz ive heard the block mounted starter doesnt fit the flywheel right with the normal bellhousing on the transmission. now im pretty car smart and didnt think about this till tonight but i dont really think it matters? i wanted your opinion though if anyone has done this before or not.
also wondering if any of you have anythought on how much the motor will make at the crank. it is a 73 400 block. two bolt main. it is .60 over so its 410 cubes. 11 to 1 comp. has gm 200cc fast burn heads 2.02 1.60 valves, lunati cam .504/.525 lift .233/.241 dur its a hyd flat tapp. harland sharp 1.5 full roller rockers. stage two intake summit brand and a 650 cfm electric choke edelbrock carb. with 1 5/8" headers shorties into a 3 inch collector and 2.5 inch exhaust out the back.
should i possibly go bigger on the carb say a 750 or 850?
Old 01-27-2011, 09:25 PM
zraffz's Avatar
Car: 1994 Z28
Engine: 355 LT1
Re: sbc 400 build starter question
No idea on the first part.
You defiantly need a larger carb though.
Old 01-27-2011, 09:32 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Axle/Gears: 3.54 Dana 44
If your block has 2 starter mounting holes instead of 3, you'll need to drill and tap the missing one to mount the 153 tooth flywheel that fits inside the T5 bellhousing.
Old 01-27-2011, 09:48 PM
tjtaylor's Avatar
Engine: 00 383
Transmission: t-5
but i bought a 168 tooth flywheel, will that fit inside the t-5 bellhousing?
Old 01-27-2011, 09:53 PM
Apeiron's Avatar
Engine: 383 Carb
No
Old 01-27-2011, 09:59 PM
tjtaylor's Avatar
Engine: 00 383
Transmission: t-5
may i ask why it wont? and i found a centerforce one that is 153 tooth but they both hold a 10.4 diaphram clutch. so i assume they are same size..
Old 01-27-2011, 10:04 PM
Apeiron's Avatar
Engine: 383 Carb
The diameter of the clutch friction has nothing to do with the number of teeth on the flywheel ring gear. The ring gear on a 168 tooth flywheel is just too big to fit inside a T5 bellhousing.
Old 01-27-2011, 10:07 PM
tjtaylor's Avatar
Engine: 00 383
Transmission: t-5
would it fit inside this? http://www.summitracing.com/parts/LAK-15020/
Old 01-28-2011, 04:06 AM
Grumbles's Avatar
Car: 1978 Chevrolet impala
Engine: 350ci 300hp/356tq pace crate
Axle/Gears: 3.42 Yukon posi
It would fit that but you'd be better off just getting the right flywheel. Much much cheaper.
Old 01-28-2011, 06:00 AM
tjtaylor's Avatar
Engine: 00 383
Transmission: t-5
its just that ive kinda been looking at that scatter shield anyway because i saw a clutch explode on launch and it went right thru this trans ams floorboard and into the car. and im not sure if my block is drilled for the other hole for the starter. anyone ggot pics of what a two hole and three hole set up look like? and what about the numbers on hp for my motor anyone got any ideas? or the size of carb id need?
Old 01-28-2011, 03:37 PM
five7kid's Avatar
Engine: LS1/LQ4
Transmission: 4L60E/4L80E
Let's be real - that engine will put out a lot more torque than a T5 can handle. Time to upgrade to a T56 or something else much stouter.
A scattershield is a good idea. Putting a T5 behind a 450-500 HP 400 SBC is a very bad idea.
You'll need a better intake manifold and carb, as well as better headers. Is your 2.5" exhaust single or duals? If single, it's about half what it needs to be.
Old 01-28-2011, 07:54 PM
flyjum's Avatar
650cfm is right on the limit for a 400 cubic inch engine at 6000 rpm
The headers are going to choke it before the carb most likely I would upgrade to some long tube 1 3/4 at least maybe even 1 7/8 diameter.
The t5 might last a while depending on what tires your going to run as well as mileage on the trans.
Full slicks will blow it to hell but street tires it could last a while.
IF the flywheel fits in the housing then I believe you will need a staggered 168 tooth starter.
Some 400 are straight and staggered for the starter and some are staggered only.
The engine should make around 420ish hp. The cam should make good mid-top but the headers will limit the top end a bit. That engine will have damn good midrange for sure.
Those are pretty good heads with that lift should flow 260/180 cfm or so.
Also he is some 408 sbc chevys dyno charts with the mods listed
http://www.ryanscarpage.50megs.com/combos9.html
Old 01-28-2011, 10:08 PM
tjtaylor's Avatar
Engine: 00 383
Transmission: t-5
wow thanks guys and the car and tranny have only 94000 miles. and its an open rear end right now with a ten bolt.. i really didnt think itd make that much power.. here is my problem though with the headers.. i have some longtubes 68460 hedmens i do believe 1 5/8 " primaries with 3 inch collector.. but there for the auto and the hit the slave cylinder on drivers side as you may know. and the only lt's ive come across that fir are the 2210's from hooker and are 500+ dollars not trying to spend that much on just headers. anyone find other headers that fit a manual?? or modify the ones i have? and for the exhaust its a 2.5 true dual exhaust with x pipe
Old 01-28-2011, 10:09 PM
tjtaylor's Avatar
Engine: 00 383
Transmission: t-5
oh ya and if i wanted a stronger manual trans were do i find a t56
Old 01-28-2011, 11:03 PM
five7kid's Avatar
Engine: LS1/LQ4
Look for a T56 out of a '93-'97 f-body. You can get 400-type flywheels for them.
Old 01-29-2011, 06:37 AM
tjtaylor's Avatar
Engine: 00 383
Transmission: t-5
the swap looks kinda hard. i looked at the sticky late last night. how much money are we talking about to put a t56 in? any ways to beef up my t5?
also something off topic but with hypereutetic pistons what is a safe shot of nitrous to use? anyone doing it with hypereuteticc and not forged?
Old 02-20-2011, 05:57 PM
PEEPOD2727's Avatar
Car: GMC Envoy but looking for a 3rd gen
Engine: 4.2 i6
Transmission: 4l60e
Axle/Gears: non-G80 :(
I don't know how the hard the swap is but here's "kit" to swap a t56 but i have never tried it so i don't how its.
http://www.hawksthirdgenparts.com/ca...rsion-1-2.aspx
Old 02-20-2011, 11:25 PM
Cerridius's Avatar
Car: 1988 Camaro sport coupe
Transmission: T5 world class manual transmission
Axle/Gears: i think its 3.08 ration posi
Oh man awesome thread my car is a 305 TBI I'm getting a 400 tomorrow out of q 73 Capri and I'm gonna do this swap also. I already have the t56 transmission so, hopefully this thread helps me out because I'm a noob at this stuff. So the T56 will bolt up to the 400 huh? One of my concerns is the flywheel also I'm wondering what kind of flywheel I'm going to need, the guy I'm buying it from is going to give me a flywheel for the 400. Do you guys think my starter will fit onto the 400? On my 305 right now I have a high torque mini starter (don't remember any specifics) and would I also need to get a different radiator for the 400? Thanks for the help in advance!
Old 02-21-2011, 05:49 AM
Received 1,672 Likes on 1,269 Posts
Of course; it's a Chevy V8.
Centerforce 700173
Probably not, since a Caprice didn't come with a flywheel; it came with a flex plate, since it had an auto trans.
No. You will need to have a bolt hole drilled in the block. Have a machine shop do it BEFORE you put the engine in. Do a search on my userID and "starter bolt hole", you'll find that I've posted the reason about 50 times along with a pic of a 73 400 I drilled.
Don't know if you need a new radiator or not; "400" has nothing to do with that.
Old 02-21-2011, 07:38 AM
Cerridius's Avatar
What do you think about 2460 hooker headers shorty, are they acceptable enough for the 400?
Old 02-21-2011, 10:09 AM
Confuzed1's Avatar
Car: 83Z28 HO
Transmission: G Force 5 speed
Ideally, you need 1 3/4" primary tube shorty headers and a single 3" exhaust at a minimum to get as much power out of it as you can. I have a 3" Hooker Supercomp catback exhaust on my car, but I believe my 408 has been limited using the set of TES headers that's on it.
That really narrows it down to a used set of SLP's, 2210's or Dyno Don's headers. I'm getting a set of Don's headers made right now. There might be another set out there with 1 3/4 primaries I'm unaware of.
Good luck finding 1 7/8" primary tube headers to fit a thirdgen, or running LT headers and having any real ground clearance cheaply.
I have a 800 CFM carb I'm putting on, but I have a blower. I'd think a 750 would be more than enough for any N/A 400.
Invest in a good high torque mini starter now...I went through numerous stock starters due to header heat myself. You've got better heads than I do, so you should get tons of torque out of it....I got well over 400 BEFORE the blower, and now I'm very close to 500...traction WILL be an issue.
Old 02-21-2011, 02:04 PM
Cerridius's Avatar
Crap... So could I use my 1 5/8 hooker shorty 2460 headers for the time being till I can find some 1 3/4? I really dont want long tubes because of possible clearance issues. This is my cam btw. Crane #114142 Compucam
Basic Operating RPM Range: 1,800-5,600
Intake Duration at 050 inch Lift: 216
Exhaust Duration at 050 inch Lift: 228
Duration at 050 inch Lift: 216 int./228 exh.
Advertised Intake Duration: 272
Advertised Exhaust Duration: 284
Advertised Duration: 272 int./284 exh.
Intake Valve Lift with Factory Rocker Arm Ratio: 0.454 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio: 0.480 in.
Valve Lift with Factory Rocker Arm Ratio: 0.454 int./0.480 exh
Old 02-21-2011, 05:01 PM
Confuzed1's Avatar
Car: 83Z28 HO
Of course you can still use those headers. I've been running my TES headers with my 400 for over three years now. I just don't think that engine will see it's full potential until you make it breathe a little better that's all.
Sounds like the same cam on my 305HO when I had it in the car (2040 Compucam). It's not much cam for a 400.
Old 02-21-2011, 09:13 PM
Cerridius's Avatar
Wooo just got my engine I R HAPPEH!!! Ok back to the point, will this flywheel bolt up to the back of the engine, and work with my High Torque Mini Starter and my T56 bellhousing/Tranny? http://www.jegs.com/i/Centerforce/18...oductId=751576
Oh, and that Carb is a Holley 750cfm
Attached Thumbnails sbc 400 build starter question-89.-78-89-400   sbc 400 build starter question-84..jpg   sbc 400 build starter question-80..jpg
Old 02-23-2011, 08:18 PM
tjtaylor's Avatar
Engine: 00 383
Transmission: t-5
yes i agree im still having problems with limited choices on starters cuz i never drilled that hole and i just trimmed the bellhousing to make it fit. get it drilled by a shop. also you do not need another radiator mine is working just fine. btw i got it running on saturday night!!!! sounds soooo good and yeah get a bigger cam im running a .504 .525 lift and its still idling really fast. is your block a 2 or four bolt?? if its 2 bolt get it splayed to four. mine was a 2 and i just left it. if its 4 bolt have fun get the webbing checked by a shop for cracks.
Old 02-24-2011, 01:19 AM
fireburdluvr85's Avatar
Car: 91 formula ws6
Engine: 355 tpi OBDII
Transmission: 4l60E
Axle/Gears: 2.73 with 4th gen brakes
you want the 2 bolt cause there isnt much webbing down there and drilling for the 4 bolt conversion just weakens it further. what casting number? i had a 509 casting from a 74 impala in my 85 t/a. never overheated it. kinda wish i kept it now.....
Old 02-24-2011, 07:35 AM
tjtaylor's Avatar
Engine: 00 383
Transmission: t-5
yes the 2 bolt is stronger than the original 4 bolt i do believe, correcrt me if im wrong though. and getting them splayed 4 bolt is different than the original 4 bolt. and i do believe mine is a 509 casting as well. it was from a 73 b body haven't actually figured out the exact car.
Caspar
06-19-2016 11:19 PM
Wesly_66
08-26-2015 09:55 PM
theurge
08-21-2015 12:46 PM
1985chevydude
08-20-2015 12:29 AM
redmaroz
08-16-2015 11:40 PM
Quick Reply: sbc 400 build starter question
