T5 from camaro 93-97 26 spline
Old 01-27-2011, 07:04 PM
mooch1's Avatar
Car: 1985 camaro Z/28
Engine: 305 V/8 4bbl carb
Transmission: T5 WC
Axle/Gears: 3-23 posi with 4 wheel discs
hi, there is a tranny i found for sale,,it's a T5 out of a camaro 93-97 model with V6...but it has 26 splines...just wondering,,,would this fit on a V8 car and bellhousing?...the 26 splnes would be good for the V8 clutch ..just wondering,,bolts right on?
Old 01-27-2011, 07:45 PM
Received 1,666 Likes on 1,264 Posts
Re: T5 from camaro 93-97 26 spline
No
Not even close
Old 01-27-2011, 07:54 PM
mooch1's Avatar
Transmission: T5 WC
No
Not even close
thanks for the response,,but why?...let's forget the fact it's a V6 model and the gear ratio is different from a V8 T5,,but will it bolt up to a V8 bellhousing?..and it has a 26 spline input shaft like the V8 T5...what else changes?...
Old 01-27-2011, 08:00 PM
Because it's different.
The entire bolt pattern where it bolts to the BH is simply .... different. Won't work. Doesn't seem too hard to understand. Look at pics of ones for sale on eBay or something; I think you'll figure it right out.
Old 01-27-2011, 08:06 PM
mooch1's Avatar
Transmission: T5 WC
ok,,that's what i wanted to know...i didn't see the tranny ,,just a pic and coudn't tell the front bolt pattern...so the front of this model T5 won't bolt up to a V8 bellhousing because it's different...thanks for your help!
Old 01-27-2011, 09:02 PM
Pillsbry10's Avatar
Car: 1992 Camaro RS 25th Anniversary
Engine: 3.4L v6 with a t3/t4 Turbo
Transmission: T-5 Conversion
Axle/Gears: 3.23 SLP Limited Slip
i was wrong....
Old 01-27-2011, 09:10 PM
92RS_Ttop's Avatar
Car: 1992 Camaro RS
Engine: Rebuilt 350 going in after paint
Transmission: WCT5, 7k & counting behind the 350
Axle/Gears: 4thgen disc rear w/ 3.73 Posi
A thirdgen V6 T5 will absolutely bolt up to a V8 bellhousing. I've done it, I know it works. I am not aware of any changes to the T5 case for the 93-97 V6's. I can't see them redesigning the T5 case, but I suppose is possible. IIRC, the 3.4 V6 is also a 60* design so its bellhousing should still be the same or at least very similiar to a thirdgen V6 bellhousing.
Old 01-27-2011, 09:13 PM
Pillsbry10's Avatar
i stand corrected
Old 01-28-2011, 05:10 AM
mooch1's Avatar
Transmission: T5 WC
Originally Posted by Pillsbry10
the only major diffrnece in the 4th and 3rd gen t5 is the spline count
3rd gen is 14
4th gen is 26
ok,,so the 4th gen T5 V6 has 26 splines,,,and will bolt up to a 3rd gen v8 bellhousing?
Old 01-28-2011, 07:01 AM
NO the 4th gen T-5 will not bolt up to a V8 bell housing. The bolt pattern is different.
If instead of listening to the people who have never seen one and are just telling you what they think you want to hear, you would just go to eBay and LOOK AT ONE, it will be IMMEDIATELY obvious. So obvious it hurts. You won't have ANY trouble figuring it out.
So here, I'll do it FOR YOU:
4th gen 6-cyl trans http://cgi.ebay.com/ebaymotors/CHEVR...item2c59e002c1
One with the same bolt pattern that fits a V8 http://cgi.ebay.com/ebaymotors/S10-T...item2c5a5e5b9d
Not sure about the 4th gen BH. It's conceivable that you could put the 4th gen T-5 into a 3rd gen car with a 4th gen BH; but that BH won't bolt to a V8. So you're still left with, the 4th gen T-5 won't bolt to a V8.
Old 01-28-2011, 07:45 AM
mooch1's Avatar
Transmission: T5 WC
thanks,,i never saw one up close...i see the difference...
Old 01-28-2011, 08:45 AM
Umm... ,,,, ... yeah....
eBay is your friend in matters like this. Not just car parts. People go to a GREAT DEAL of trouble to put up the best pics of their whatever that they can; it's gotta be the world's richest resource of pictures of .... things. My advice to people who otherwise would post WRONG non-information like all that drivel above would be, instead of arguing about stuff like that, USE IT to your benefit.
Old 01-28-2011, 10:10 AM
92RS_Ttop's Avatar
Car: 1992 Camaro RS
I did use Ebay to look at the pics of T5's before I posted my answer. I wasn't able to find anything conclusive on there. If you look at the two links posted by sofa, they bolt pattern appears to be the same. It looks like they may have just added some reinforcement between the two bolts on the driver's side of the case. If you look closely at the pics, the bolt holes appear to be directly over each other on both transmissions. That's why I said they "should still be the same or at least very similiar to a thirdgen".
It may be better to compare pics of the bellhousings where you can clearly see the bolt patterns of the transmissions.
Thirdgen V6: http://cgi.ebay.com/ebaymotors/82-92...item4aa6615310
Thirdgen V8: http://cgi.ebay.com/ebaymotors/Camar...item45f84fb239
Fourthgen V6: http://cgi.ebay.com/ebaymotors/93-94...item4aa803268e
Old 01-29-2011, 08:08 AM
mooch1's Avatar
Transmission: T5 WC
umm...you can bolt a v6 trans to a v8 bellhousing there are threads all over the place on here about doing it
i have bolted up a V6 3rd gen tranny to a 3rd gen v8 bellhousing,,i know it will work,,but never seen or heard anything about the 4th gen V6 T5 bolt up to a 3rd gen V8 bellhousing...
Old 01-29-2011, 10:03 AM
jmd
jmd's Avatar
Car: `86 SS / `87 SS
Thirdgen V6 pattern is a rectangle, tilted 17deg. to the driver side with the lower passenger side bolt moved out about an inch so the spread across the lower bolts is wider.
Fourthgen V6 pattern has a wider spread across the top between bolts.
If you want to try and bolt the trans. upsidedown and find that it still doesn't work for the OP, go right ahead.
Old 01-29-2011, 12:56 PM
92RS_Ttop's Avatar
Car: 1992 Camaro RS
And that is why I suggested looking at the bolt pattern on the bellhousings. All the pics I found on Ebay, and posted by Sofa did not give a clear view of the bolt pattern and spacing on the front of the transmissions.
Both generations tilt the transmission towards the driver's side.
Old 01-29-2011, 02:32 PM
mooch1's Avatar
Transmission: T5 WC
it would be great to have a 4th gen V6 T5 and a 3rd gen T5 V8 bellhousing and figure things out,,i think it would help a lot of other people curious about this ....
Old 01-31-2011, 10:49 PM
nomind's Avatar
Car: 85 Trans Am
Engine: LB9
Transmission: Finally Fixed (T5)
I was also under the impression that the 4th gen T5 had a longer input shaft then the 3rd gen V8 T5, but I'm frequently wrong.
Old 02-01-2011, 08:41 AM
mooch1's Avatar
Transmission: T5 WC
all i wanted to know was if this 4th gen t5 would fit on a 3rd gen V8 t5,,,because it has 26 splines like the 3rd gen v8 clutch...i never have seen one up close,,,there are a few for sale real cheap...but like these guys here said,,the front bolt holes on the t5 4th gen are different and won't fit my v8 bellhousing ,,it's too bad,,because it would make a good temporary replacement...this is why i ask here...lot of helpful and knowledgeable people..
hectre13
12-11-2023 08:14 AM
hectre13
08-26-2015 08:17 AM
red90IROCls1
08-25-2015 06:56 AM
mcgarnicle
08-12-2015 04:58 PM
knight72
08-10-2015 09:32 PM
Quick Reply: T5 from camaro 93-97 26 spline
