Theft Deterrent Module
Old 01-25-2011, 04:20 PM
91camrs707's Avatar
Car: 1991 Camaro RS
Engine: 3.1 V6 (new crate)
Transmission: 5 Speed Manual
I need some help with my Theft Deterrent Module, Supposedly you can bypass the complete VATS system (not just the key with a resistor) by reproducing the signal that is output by the TDM to the PCM. Does anyone know anything about this? or how it is done? Any and all help is GREATLY APPRECIATED!
Old 01-25-2011, 08:03 PM
Six_Shooter's Avatar
Transmission: 5-speed/T-5
Re: Theft Deterrent Module
Yep, lots of posts on that very subject, search feature will be your friend.
Old 01-26-2011, 03:39 PM
91camrs707's Avatar
Car: 1991 Camaro RS
I thought it would be helpful as well, but doing a search for either TDM or Theft Deterrent Module comes back with zero results. The only thing I have been able to find so far is the VATS resistor trick which I have already done, and nothing to do with the Theft Deterrent Module (the VATS brain that sends the signal to the PCM) itself. But thanks for the "help"...
Old 01-26-2011, 06:28 PM
Search "VATS bypass" The information is here, with circuit diagrams and specs.
TDM and Theft Deterrent Module will likely not get you the results you want.
Old 01-27-2011, 02:03 AM
91camrs707's Avatar
Car: 1991 Camaro RS
ALRIGHT! Thx for the tip, I will try that search and see what I can find. Again, Thank You!
InfernalVortex
04-20-2021 11:31 AM
1992Z28!
11-19-2015 07:33 AM
dusterbd
09-29-2015 08:40 AM
AmorgetRS
09-28-2015 09:33 PM
tattmann
09-27-2015 05:20 PM
Quick Reply: Theft Deterrent Module
