C-4, C-5, or C-6 Brakes for my '83 Z-28
Old 01-15-2011, 11:25 AM
Guy2dogs's Avatar
Car: 1983 Z-28
Engine: 396 SBC, w/ Dual TBI
Transmission: Tremec TKO 600
Axle/Gears: Factory pegger, saving 4 S60
Hey Fellas,
I have an '83 Z-28 with 4 wheel disc brakes. I would like to run the larger rotor and 4 - 6 piston calipar of the Corvette set up on the front of my car. I was told to look for the 1le set up, but I found out the Corvette bakes are cheaper in the long run (as in disc and pad replacement). any help or ideas would be greatly appreicated. Guy
Old 01-15-2011, 11:30 AM
sailtexas186548's Avatar
Car: 1991 z28
Engine: Turbo 310
Axle/Gears: D44
Re: C-4, C-5, or C-6 Brakes for my '83 Z-28
what wheels are you going to run? larger brakes require larger wheels.
Old 01-15-2011, 11:34 AM
chazman's Avatar
Transmission: World Class T-5
Axle/Gears: BW 3.45
AFAIK, only the 1LE's will clear your *STOCK* 15" wheels - if that's what you're still running.
Old 01-15-2011, 11:59 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Welcome to TGO. The following site sells many combinations. Many members have upgraded to larger brakes, so a search will net you a ton of info.
http://www.flynbye.com/
JamesC
Old 01-15-2011, 06:16 PM
kevinc's Avatar
Car: 1982 Z28
Originally Posted by Guy2dogs
Hey Fellas,
Wheel size will dictate your options, as was posted earlier.
If cheapness is your priority, then the 18" rims you'll need are a contradiction.
Old 01-15-2011, 07:31 PM
Guy2dogs's Avatar
Car: 1983 Z-28
Oh yeah, I forgot! I will be getting 17X10s for the front and rear w/ 5.5 inches of backspacing.
Old 01-16-2011, 06:36 AM
kevinc's Avatar
Car: 1982 Z28
You're not likely to fit 6-piston Z06 brakes under 17" rims.
Depending on the brand of wheel, maybe C6 Z51 2-piston fronts will clear.
C5/C6 regular fronts will fit most 17" rims, but again it depends on the brand.
Old 01-16-2011, 12:38 PM
Guy2dogs's Avatar
Car: 1983 Z-28
My buddies are trying to talk me into buying Z06 wheels, which are 17X9.5 for the front and 18X10.5 for the rear. The thing is I would need 2.25 inch spacer for the front and a 2 inch spacer for the rear. Bumping up to 18 inch wheels is not a problem. I just do not want to go aftermarket brake system not only because of cost, but I would like to take a ride to the local Chevy dealership or parts store and getting a new rotor and pads on the spot instead of waiting for a delivery. The Zee is being set up for street/road racing and way I like to drive, I am going to need pads and rotors every other month.
PS: I am the only member of the family that believes that the third gen f-bodies are the best cars around. Everone else in the family believe in the fox body mustangs.
Old 01-16-2011, 04:47 PM
kevinc's Avatar
Car: 1982 Z28
I was talking about C6 Z06 front brakes previously, not C5 Z06.
C5 Z06 front brakes will fit under most 17" wheels.
Old 01-20-2011, 01:46 PM
Guy2dogs's Avatar
Car: 1983 Z-28
JamesC
Dear JamesC,
Thank you for the link. Flynbye.com has what I am looking for. I love the site and I love all the useful information on here. Guy
BADNBLK
Convertibles
09-21-2015 07:56 PM
dbrochard
09-19-2015 08:13 PM
Necron
Brakes
09-14-2015 12:45 PM
Buickstaged
Brakes
09-04-2015 07:53 AM
1Aauto
Sponsored Vendors
09-02-2015 01:50 PM
Quick Reply: C-4, C-5, or C-6 Brakes for my '83 Z-28
