Bad, bad luck with PATC's 700 raptor level 3
Old 01-02-2011, 06:18 PM
thomas1976's Avatar
Car: 91 Trans am
Engine: built 360 TBI
Transmission: built 700r4
Axle/Gears: 10bolt/3.23
Two transmissions from PATC http://www.transmissioncenter.net/hi...00r4.htm#Parts and not one works as it should.
n°1. 700raptor level 3 with a 2000rpm #5X power raptor lock-up converter.
Comes with black powder coat.
-gears banged nasty, shifting up and down since day 1 and little blackish trash could be cleaned of the magnetisized dipstick.
-after a 5 miles cruise it did not whant to upshift anymore, found some tiny metal chips on the dipstick.
Kerry from PATC told me its some trash from the previous transmission that was stuck in the radiator.
Wich I though is possible since I only used compressed air to clean the cooler lines.
-the 2000rpm TC would stall only at around 2600rpm.
Kerry: "Torque converter math is figured on an engine making 250 torque at 2500 RPM. Thanks, Kerry"
That sounded right to me, my engine should be putting around 350 tq to the wheels.
Issues started immediately.
I refreshed the transimission oil and it turned out shifting again.
I hated that transmission, banging shifts, stupid high stall for normal driving with 4th lock up only.
n°2. 700raptor level 3 with a 1600rpm #2 super street raptor converter with stock lock-up and corvette servo's for smoother shifts.
With no paint as I requested.
I installed the Derale automatic transmission filter kit, for extra safety.
-gears bang nasty shifting from P or N to gear, 2-3 shift bang and little blackish trash could be cleaned of the magnetisized dipstick since day 1.
-manual 1-2-D shift control does not work, it stays in 1st.
-after 10 miles highway the transmission was acting wrong and the transmission fluid was toast.
Total miles around 20.
I refreshed the fluid and drove the car to its storage. It makes a silent jet-plane sound shifting.
I am wery disappointed, pay'd big $$$$ and still no resonable working transmission.
Any ideas what to do? I'm thinking of rebuilding the stock 700r4 my self.
Attached Thumbnails Bad, bad luck with PATC's 700 raptor level 3-dsc08510.jpg   Bad, bad luck with PATC's 700 raptor level 3-dsc08619.jpg   Bad, bad luck with PATC's 700 raptor level 3-dsc08630.jpg
Old 01-02-2011, 07:49 PM
the gtaman's Avatar
Car: 1989 firebird gta
Engine: sbc 355 hsr 280xfi 58mm tb
Transmission: raptor 700r-4, 2800 stall
Re: Bad, bad luck with PATC's 700 raptor level 3
if its still under warranty send it back ,i have the raptor jr . had it about 6yrs now and it's just starting to give me problems. thats a lot of money to just throw away.
Old 01-03-2011, 07:38 AM
thomas1976's Avatar
Car: 91 Trans am
n°1 was shipped to me august 15 2010 and n°2 november 12 2010, usually arrive here in 7-10 days.
Unfortunately the whole back and forward shipping process cost almost as much as a new transmission to my door.
That is why I ordered the second n°2 700raptor from them. I could not immagine they would have screwed-up twice.
How was your 700raptor junior? did it shift like a normal transmission or did it shift bang/harsh?
If I knew what to change to get rid of the bang/harsh shifts, I could fix the n°1 700raptor and slap a new converter in front.
This could be the less expensive way to get the car back on the road untill I find the time to rebuild the stock 700r4.
Old 01-03-2011, 02:38 PM
TZFBird's Avatar
Car: 1988 Firebird, 2000 GTP
Engine: 327
Axle/Gears: 9" posi, 4.11
Looking at the build... if that is all from what's listed on the site at the top. The only thing that can really make a harsh shift is the "performance 1-2 accumulator spring" or any other accumulator springs. In fact removing the springs would make it incredibly hard and would result in a hard bang. That could also explain metal material except it would probably be aluminum though.
The only other thing would be "extra wide sun gear bushing, extra wide rear stator support bushing". I'm not sure but if somehow extra wide would result in extra wear somehow that could leave you with filings.
Unless a clutchpack is dragging to make the deposits.
Old 01-03-2011, 05:00 PM
thomas1976's Avatar
Car: 91 Trans am
n°1 bang's downshifting too.
n°2 bangs when shifting from P or N in to gear and wen it shifts from 2 to 3.
Thanks for the imput, I will open n°1 wen I find some time.
Old 01-03-2011, 07:28 PM
TZFBird's Avatar
Engine: 327
I guess maybe you could elaborate on the bangs. It shifts hard, or it actually makes a noise? I had a problem with mine being very firm out of Park or Neutral and got rid of quite a bit of that when I got a higher stall.
Bangs on downshifting almost sounds like it's more of a line pressure problem. I haven't done enough work(not much at all) with these transmissions to fully understand them and how the mods affect them completely. I'd also maybe wonder about the 'high output pump slide spring'.
I'm basing this off the 4L60E manual I have gone through, but that uses signal pressure to adjust pump output. So I'm wondering if the TV valve signal somehow feeds back to the pump so it can adjust and increase output. It's a lot easier when explained with diagrams and by someone who actually knows something. I just bring it up because they are things to look at in case one of these parts was faulty and maybe broke/were left out/or installed wrong.
Old 01-03-2011, 11:41 PM
UnderCover89TBI's Avatar
Engine: gone
Transmission: gone
Axle/Gears: gone
ugh thats unfortunate. THe TV cable was adjusted properly? Thomas you seem like a smart guy I really think you could rebuild one yourself no problem!
Old 01-04-2011, 07:48 AM
thomas1976's Avatar
Car: 91 Trans am
Bang as extremely harsh shift wich also creates a clunking sound. Worse at light trottle.
n°1 did not bang from P or N to gear but the torque converter wold not move the car without giving some trottle.
TV cable is fully extended at WOT and around 3mm with closed trottle.
WOT shift points are around 4400-4500rpm like stock, with the stock governor.
I also tryed 1-2 clicks in or out to check if it would fix the bang wen shifting in to gear. Made no difference.
Old 01-04-2011, 10:57 PM
antoine's Avatar
Car: 1988 camaro z28,1997 camaro lt1
Engine: 355 afr 195 heads,tpis big mouth
Transmission: 700r-4 built by me 3-4 z pack
Install a Corvette servo and it should not shift as hard
Old 01-05-2011, 03:08 PM
thomas1976's Avatar
Car: 91 Trans am
Should the corvette servo alone cure the banging downshifts too, or would it be best to use a corvette valve body at the same time?
I would also like to put in a stock lock-up solenoid.
Old 01-06-2011, 09:07 AM
siduramaxde's Avatar
Car: 86 berlinetta
Engine: 383
Axle/Gears: 3.42 zexel torsen
Sounds like maybe you should have just stuck with a stock tranny. If you want performance then the shifts are going to be hard. And if you did not properly flush your cooling system (air alone will not cut it) you could have ruined the trans the moment you started the car. Any debris can cause valve body to malfunction, thus a trany that shifts weird. Debris can also cause clutch failure too because it can block oil passages causing low pressure.
Old 01-06-2011, 12:35 PM
thomas1976's Avatar
Car: 91 Trans am
Kerry from PATC reccomended the 700 raptor level 3 for my application, I'm a newby in the 700r4 internals world.
Yes it is possible that the n°1 700 raptor level 3, got some trash from the cooling system.
The main issue with this one are the bangin harsh light trottle up and down shifts.
Though, n°2 700 raptor had the Derale automatic transmission filter installed, there is no way any trash could go back in to the transmission. Still I found the same black trash as with n°1 on the dipstick. But probably that is normal for a rebuilt transmission.
The main issue with this one is that it burned up the oil on a little highway trip with a coupple kickdowns.
tonys91rs
10-10-2015 03:31 PM
GTAman
09-14-2015 09:53 AM
Third_Gens_Rule
09-03-2015 06:56 PM
Third_Gens_Rule
09-03-2015 06:55 PM
tonys91rs
09-02-2015 07:07 PM
Quick Reply: Bad, bad luck with PATC's 700 raptor level 3
