what are the common symptoms of a bad ECM??
Old 12-28-2010, 11:46 PM
yellowsnow's Avatar
I am having multiple problems from multiple areas. I just bought, and have been working on this car that someone else gave up on. I am suspecting it is a ECM problem, but their are so many threads about drivetrain swapping related to the ECM that i am having trouble finding threads to give me the common symptoms of ECM problems.
92 3.1 manual
sorry wrong section, no wonder i couldnt find anything
Old 12-29-2010, 11:53 AM
Chevy86 IROC-Z's Avatar
Car: 1986 Camaro Z28 IROC-Z
Engine: 350 Tuned Port Injection, for now.
Axle/Gears: Posi - 3.23
Re: what are the common symptoms of a bad ECM??
A bad ecm is hard to detect and especially pin point. You may run into issues such as stalling, bad idle, and hard starting. The most best way is to run the trouble shooting by grounding pins a and b in the ALDL. The common error would be a code 51 but the code 51 can also be a bad MemCal. Here is a page of the issue. Please post up the trouble codes that you are experiencing.
Old 12-29-2010, 11:55 AM
If you want, I can sell you the TPI swappers guide which explains tons about the Tuned Port Injection System for dirt cheap.
Old 12-29-2010, 12:09 PM
yellowsnow's Avatar
im going to work on it some more today. i have no speedo, oil pressure gauge, temp gauge, bouncing idle till warm, and it feels like their is no timing advance. Im sure it is either a wiring issue or the ECM. I'm going to spend the day tracking down wires then go from their.
Old 12-29-2010, 12:13 PM
First get the trouble codes bud. Ill hook you up with the diagnostic sheets.
Old 12-30-2010, 11:55 AM
yellowsnow's Avatar
alright i got my oil pressure and temp to work. pulled the codes 34 and 44. I checked my MAF or intake air sensor (whatever) and it has no resistance. So thats probly causing the lean code.
so i guess its not the puter. im going to start a new thread with my crazy speedo problem.
Old 12-30-2010, 01:08 PM
wait a minute. What year is ur camaro? Does it have a speedometer cable that goes from the tranny to the instrument cluster?
Any way. Here are the sheets to use as a troubleshooter.
Old 12-30-2010, 01:15 PM
here you go
Attached Thumbnails what are the common symptoms of a bad ECM??-85.jpg   what are the common symptoms of a bad ECM??-86.jpg   what are the common symptoms of a bad ECM??-87.jpg
last one
Old 12-30-2010, 01:18 PM
your O2 TroubleCode
Attached Thumbnails what are the common symptoms of a bad ECM??-102.jpg   what are the common symptoms of a bad ECM??-103.jpg
Old 01-02-2011, 06:22 PM
yellowsnow's Avatar
thanks for the help. i found my problem. i had several intake leaks
Old 01-02-2011, 09:48 PM
Right on man!
Blue419
09-10-2015 01:03 PM
Stryker412
09-07-2015 09:11 AM
Amillionoh7
09-05-2015 11:44 PM
willyjoejr
09-03-2015 09:26 AM
RyanJB
09-02-2015 01:27 PM
Quick Reply: what are the common symptoms of a bad ECM??
