New Prom?
Old 12-25-2010, 02:20 AM
coryprine's Avatar
Car: 85 Camaro Z28
Engine: 5.7 TPI
New Prom?
I just purchased an 85 Z28 which originally had the 305 in it. The previous owner put a built 89 350 in the Z28. Bored, mild cam, ignition system, etc, as well as a different rear end. My question is, the car runs great but I think shes running rich. Does the stock PROM suffice or should I look at a replacement concidering the new engine isnt exactly stock.... If I should look at a replacement can someone point me in the right direction...
Old 12-25-2010, 07:48 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: New Prom?
If the '89 engine has the correct 350 injectors then it will because computer thinks it still has smaller 305 injectors.
Need 350 prom and knock sensor
If you think your mods require a custom tune then there are plenty of mail order places that can do one and also do mods like delete EGR / AIR and change fan operating temps , etc
Old 12-25-2010, 05:23 PM
coryprine's Avatar
Car: 85 Camaro Z28
Engine: 5.7 TPI
Re: New Prom?
How do I find out if the car has the proper PROM already installed?
Old 12-25-2010, 06:23 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
Re: New Prom?
Take the inspection cover off the computer and read the 4 letter code written on the silver label inside the blue cover of the memcal ( Chip ). Then post it up here
See
http://tpiparts.net/inc/sdetail/19022
Old 12-26-2010, 02:32 PM
coryprine's Avatar
Car: 85 Camaro Z28
Engine: 5.7 TPI
Re: New Prom?
The main ECM number is 7-7165 and the code inside of the blue chip is APYU 3516. Previous owner claims that he added a Hypertech chip. Where would this chip be if he actually did replace it.
Old 12-26-2010, 04:31 PM
red rock's Avatar
Car: 1987 iroc
Engine: 383 TPIS intake, Dyno Don headers
Transmission: 700R4 w/Pro-built Auto/transgo 2-3
Axle/Gears: 3.27/3.70 borg warner 9 bolt
Re: New Prom?
4?
Old 12-26-2010, 07:11 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
Re: New Prom?
APYU is a '89 350 w/auto chip
Hypertech chip replaces original in the ECM
http://www.performancepartswholesale...B3YXJyYW50eS4=
Old 12-26-2010, 07:26 PM
coryprine's Avatar
Car: 85 Camaro Z28
Engine: 5.7 TPI
Re: New Prom?
Ok so my ECM is correct... where should I look now for the running rich issue... Just put a Cat on here or is it something else.
Would the Hypertech be good enough for the modifications on this drivetrain....... or going to somewhere.. say Thunder Racing for a custom tune/programming.
Old 12-29-2010, 06:10 PM
GreekItalianMan's Avatar
Car: 1986 Trans Am
Engine: lb9 305 tpi
Transmission: THM700R4
Axle/Gears: Posi-rear,3.27 9 bolt Borg Warner
Re: New Prom?
Could be rich because of the wrong thermo and fans as well. Remember it's also a different engine perhaps the ecm could be wrong for the engine. It's best to custom tune it(if you dont know how you can bring it someone) Most of the time its an ecm error. But, it could be something else.
Old 12-29-2010, 06:53 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
Re: New Prom?
He has a '165 ECM (86 -89 TPI) on a '89 TPI engine with a '89 chip
Old 12-29-2010, 11:22 PM
Car: 1986 Trans Am
Engine: lb9 305 tpi
Re: New Prom?
Oh,didn't read that. Then it's clearly something else.
Old 12-30-2010, 10:22 AM
Rod Behring's Avatar
Car: 88 IROC
Engine: L98 HCI
Axle/Gears: 3.27 9 bolt
Re: New Prom?
Do you know the specs for the cam?
It might not be a computer friendly cam.
Check your vacuum at idle, if its below 15 inches it could have too much overlap for the ECM.
Old 12-30-2010, 03:17 PM
coryprine's Avatar
Car: 85 Camaro Z28
Engine: 5.7 TPI
Re: New Prom?
I have no clue what cam the PO put in the car... no way to find out without tearin er down...lol
Old 12-30-2010, 05:28 PM
John 89 Formula's Avatar
Car: 89 FORMULA FIREBIRD, 86 CHEVY CAMARO
Engine: L98, LB9 RESPECTIVLY
Transmission: 700 R4 (BOTH)
Re: New Prom?
are there any check engine codes?
how old is the o2 sensor?
Old 12-30-2010, 05:56 PM
coryprine's Avatar
Car: 85 Camaro Z28
Engine: 5.7 TPI
Re: New Prom?
O2 sensor looks quite old, I will change it when I get paid. I need to change the check engine light bulb, as it is not illuminating. Can't very well pull codes with a burned out light...lol.....I think I will change em all while I have the cluster out.
Old 12-30-2010, 06:49 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
Re: New Prom?
A thought
Some aftermarket chips attach to the side of the original chip using a adapter and can't be seen through the inspection hole.
Take ECM out , open it up ( 4 x 7mm nuts on sides ) and see if there is a 2nd chip attached
Old 12-30-2010, 06:54 PM
coryprine's Avatar
Car: 85 Camaro Z28
Engine: 5.7 TPI
Re: New Prom?
I pulled the whole ECM from the car, and removed the PROM, stock chip installed, PO claimed that he had put a chip in it.... BS...lol
I really dont see the need to go for a custom tune for the mods that have been done to the car... I was thinking about just ordering a performance chip from one of the companies.... So many choices, lol, hard to tell whats the best bang for the buck.
Old 12-30-2010, 07:08 PM
coryprine's Avatar
Car: 85 Camaro Z28
Engine: 5.7 TPI
Re: New Prom?
anyone by chance have a picture of the inside of the ECM, my dici cam is down, but therea a white wire running from the center of the ecm back to a spot beside where the vehicle harness plugs in. about 4 inches long.... just seems out of place....
Old 01-06-2011, 01:04 PM
jt92's Avatar
Re: New Prom?
I just installed a chip in mine and it had the same white wire inside. Must be normal.
89-IROCZ-5.0TPI
02-22-2022 09:26 PM
Linson
09-25-2021 07:55 PM
dusterbd
09-29-2015 08:40 AM
BLK87Z
09-18-2015 11:29 PM
Winchester1094
09-15-2015 09:48 AM
Quick Reply: New Prom?
