How Do i fix my high beams. They do not turn on
Old 12-14-2010, 07:36 PM
SSZ2891's Avatar
when i try to turn on my high beams they do not come on. What can i do. I pull back the turning signal lever and nothing. they dont engage. Im stuck?
Old 12-15-2010, 07:59 AM
Brads RS's Avatar
Re: How Do i fix my high beams. They do not turn on
Have you checked the dimmer switch to make sure its working correctly? Could be bad, or out of adjustment. Its located on the lower steering column near the ignition power switch.
Old 12-15-2010, 08:59 AM
Jono4820's Avatar
Car: 1991 RS
Engine: 350 TBI
Axle/Gears: 3.08 lt. slip
This may sound stupid but also check to be sure both of your high beams are not burned out.
Old 12-15-2010, 09:54 AM
88FormulaKiller's Avatar
Car: 1967 Firebird P.T.
Engine: LS3 4" Strkr 422ci
Transmission: MN12 6 speed
Axle/Gears: 3.73 8.5" 10 Bolt Eaton
i have the same problem with my 91 cherokee and 91 firebird, when you pull the lever back it doesnt even click, its the catch lever inside the column that attaches to the high beam/wiper lever. i havent taken one of them apart yet to see how it is repaired.
Old 12-15-2010, 10:34 AM
SSZ2891's Avatar
yes exactly. thats my prblem it doesnt click. i have a parts car that when i pull it back it clicks. how can i remove it and put it on this car?
Old 12-15-2010, 12:18 PM
SSZ2891's Avatar
how do i remove the turn signal assembly from the steering column. ive removed the steering wheel, had to go to auto zone and rent a steering wheel puller. now i just needa remove the turn signal assembly...
Old 12-15-2010, 12:22 PM
i dont have answer for you but i will say that i looked at my 91 cherokee lever and it looks very very similar to the set-up on my 91 firebird and from i could see at a glance it may be able to be rigged up with a rod (kind of like a lock rod inside the door if it was cut and bent) and made to work that way temporarily. i can actually push the lever inside the column forward and turn my high beams on since the cover/trim piece is off, may be able to do the same with a firebird/camaro column to get you by... just my .02.
Old 12-15-2010, 12:25 PM
Brads RS's Avatar
Normally there are 2 screws holding the turn signal assembly in and one that holds the turn lever, remove them then unplug the connector at the bottom of the column and pull the turn sig assembly up and out of the way, next i think there are two or three bolts/screws that hold the lock cylinder housing down, you will need to loosen these then pull it up a little. Next there is a cover over the turn sig lever that should be free now for you to work on. Hope this helps. I think thats what you will have to do, its been a while since i have been there.
Old 12-15-2010, 06:08 PM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
If pulling back the lever doesn't make a click, then it's probably just the switch down the steering column that needs to be tightened up in the right position to make it work. Get under there and watch the rod move when you pull back the lever. See that whitish plastic switch the rod is going into? push in on that. If it clicks and your brights are now working, just loosen the two screws that hold the switch on a little bit, pull the switch forward and retighten until you've got it working right. Adjust it with the steering wheel in the position it's in when you drive it. Much easier than that other thing
Spyder_TheGamer
12-25-2015 05:07 PM
Fronzizzle
08-19-2015 01:36 PM
Fronzizzle
08-17-2015 02:52 PM
ZsTransAm
08-11-2015 07:30 PM
Quick Reply: How Do i fix my high beams. They do not turn on
