Can i start the engine without the serpentine belt?
Hi, im currently with no belt because i removed the smog pump and here in juarez (dont know why) they dont have the right belt and i have to go to el paso but anyway... i will only start like 2 or 3 minutes and thats all, i think theres no problem? right??
thanks in advance
thanks in advance
Re: Can i start the engine without the serpentine belt?
thanks in advance
thanks in advance
As for starting the engine without the serp. belt on?
Sure, its safe for very short periods. Why is it not safe for longer periods? Because without the serp belt on the water pump is NOT spinning so there is no coolant flow, eventually the coolant in the block will overheat and cause damage.
according to the tech article said that i need the belt Dayco 968K6 that is around 1'' longer than the stock belt and i have to reroute the belt
but you didnt reroute and used a smaller belt??
and for starting the car, it will only be like 2 or 3 minutes i just want to start the car because has been sitting like 3 weeks thats why
2 or 3 minutes would be too long. Because there is no coolant flow the system will heat the water in the heads first, it could get hot enough to boil and with no flow it may damage things.
as for the article https://www.thirdgen.org/serpentine that article is mislabled. Look at the engine diagrams, he removed MORE than just the smog pump. he also removed the Power Steering pump as well which DOES require a re-route.
this is the routing i used when removed my smog pump. Notice the smog pump on the left is not included anymore. You are shortening the overall path the belt has to travel and such a shorter belt is needed to maintain the proper tension.
When I did mine I left the stock belt on and notated the angle of the serpentine tensioner. I then used a tape measure to get the length of the route. The angle of the tensioner is important! Different angles would mean that tension on the accessories change and I wanted to maintain the stock tension.
Stock routing.
Stock routing.
very well i now understand, thank you so so so much for your help...
im going to wait until i have the belt to start the car i dont want any problems jeje.
Car: 1989 IROC-Z
Engine: 355, 6.0 (LQ4) soon
Axle/Gears: Borg Warner 2.77 for now
You could kill your battery too
Guest
Posts: n/a
Ok, today took a pic from the belt routing, and is diferent to yours...
i already buy the belt that you recomend me but theres no way that is going to fit so in my case i think i have to go to the 97.8'' belt that is 3'' longer
tomorrow im going to get the new one and try it out...
Car: 88 Camaro
Transmission: 700-R4
Purchase a AC delete pulley, install ac delete pulley, remove ac stuff, remove smog pump, smog lines, Get the Dayco 968K6, slap it on, your good to go, just did this 5 minutes ago, I spent 140$ on belts, the Dayco 968K6 is the best fit "I bought the autozone brand but its still a 968k6. THirdgen89's routing is the correct routing with this belt, the top picture.
Car: 88 T/A. TOTALLED!! (not by me)
Engine: TPI 5.0
Transmission: 700r4 Auto
Axle/Gears: 2.73 posi
The routing may look different but the accessories still spin the same directions in both images. You can route yours the way I posted and not affect anything.
1992 Trans Am
05-10-2023 07:19 PM
db057
08-11-2015 10:11 PM
affect, belt, car, crank, damage, engine, fan, problems, removed, serpentine, sserpentine, start, starting, surpentine, transmission
