pinion yoke vs u joint strength
Old 11-15-2010, 10:59 AM
SLEEPER 86's Avatar
Car: 86 coupe
Engine: 383
Axle/Gears: 9 bolt 3.27 posi
I need to replace my pinion yoke and have been looking into various options to gain the most strength possible. the differential is a 1990 3.23 posi disc brake unit. The driveshaft is the stock unit for now although i could replace it at a later date.
1; the stock pinion yoke with a Lakewood 23011 high performance cold forged non cross drilled u-joint
2; the chevy astro-van pinion yoke with a1350 size u-joint and the neapco 2-1153 conversion u joint (hot forged and cross-drilled with a grease fitting)
It seems to me that the larger u-joint and pinion yoke would be the better of the two, but i'm not sure.
I haven't been able to locate a cold forged non cross drilled performance conversion joint but there may be one out there. that woulld seem to be the best bet.
I realize that to see any benefit from either idea i would have to replace the front u joint as well, and in the case of the 1350 conversion the trans yoke would need to be swapped out. right now though I am only concerned with the pinion yoke.
I have also seen forged steel yokes on the market, but have not seen them offered for either of these two options, does anyone know who offers them?
Thank's in advance for your opinions/ ideas!
Eric B
Old 11-15-2010, 11:07 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Axle/Gears: 3.54 Dana 44
Re: pinion yoke vs u joint strength
Is the yoke really a weak point in a 7.5 10 bolt?
Old 11-15-2010, 02:14 PM
SLEEPER 86's Avatar
Car: 86 coupe
Engine: 383
Good point Apeiron, I was asking because I need to replace it anyway and I can do either for about the same cost.
My question centered around the u-joint as much as the yoke. would the u-jount be considered a weak point? And if so, which way would be the best?
Old 11-15-2010, 02:34 PM
85MikeTPI's Avatar
Car: 1985 Camaro Z28, VIN F
Engine: 427 sbc, HSR
Transmission: T-56, self rebuilt 700+ hp
Axle/Gears: Moser 12bolt, 3.42 trutrac
The only reason to put a 1350 pinon yoke on a 10bolt would be if you're getting an upgraded driveshaft that has 1350 ujoints. Don't bother putting one on only to convert it back to a stock drive shaft with a conversion yoke.. The conversion yokes are a weak point and should be avoided.
Old 11-15-2010, 03:01 PM
SLEEPER 86's Avatar
Car: 86 coupe
Engine: 383
mike, if you meant conversion u-joint I understand. my intention is to convert to a 1350 driveshaft at a later date when funds permit.
Apeiron's question is still pertinent, are any of these pieces worth adding to a 10 bolt?
Old 11-15-2010, 05:18 PM
big gear head's Avatar
There are several other parts in the 7.5 that will let go before the yoke or u joint. The 3R u joint is amost the same size as a 1330 u joint, so it's plenty strong. If you had plans of upgrading to a 12 bolt or 9 inch in the future and wanted to get a 1350 drive shaft made then I can see where you woudl want to go with the 1350 u joint, but chances are that you will have to modify the drive shaft later to work with the 12 bolt or 9 inch anyway.
Old 11-15-2010, 05:23 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am, 92 Firebird
Transmission: TKO600, T5
i put a 1350 pinion yoke on myt old 10 bolt, but that was just because i had a new driveshaft made with 1350 joints, and i didnt want a conversion joint in the rear since a new 9" rear was in the works.
like said above, no point upgrading the yokes and using conversion joints to the driveshaft.
but, if you really want to do this, i still have the 1350 10 bolt pinion yoke on the shelf, should still ahve the seal too, if you are interested.
Old 11-15-2010, 10:33 PM
SLEEPER 86's Avatar
Car: 86 coupe
Engine: 383
Thank's guys for the quick answers and valued opinions!
Freddie, I'll be giving you a call tomorrow about what we talked about on the phone a few days back. i'll still be needing that part.
Thank's again everyone!
Eric B
Ed1LE
09-30-2018 09:14 AM
loud91rs
10-05-2015 10:05 PM
gord327
10-03-2015 01:25 PM
sjorgens
10-01-2015 07:54 PM
gord327
09-29-2015 10:18 PM
Quick Reply: pinion yoke vs u joint strength
