Computer friendly Cam for 350 TBI
Car: 2002 Trans Am WS6
Axle/Gears: 4.10
I am swapping my 305tbi for a 350tbi and would like to swap cams while the engine is out. I don't plan on having the vehicle down for a long enough time to tune it and was hoping to be able to just make some fuel pressure and base timing changes to compensate for the cam. Is this possible or do I absolutely need a new tune? I know I will not realize 100% of the gains from the cam without a tune but I do pplan on doing one down the road when I swap heads.
Car: 1988 Camaro IROC-Z
Engine: L98 350 TPI
Transmission: WC-T5
Axle/Gears: 2.73:1 Open
Re: Computer friendly Cam for 350 TBI
What cam is in the 350 now?
I ran an L98 long block with a stock Corvette cam and a TBI system for a couple years; it worked great. Started up everyday, burned the tires down when I needed it to, and the fuel pressure, computer tune and injectors were stock TBI. Just remember, the throttle body unit itself is the same one that is used from the 4.3 up to the 5.7 of that generation. The only bigger one they made was for the 454, and you don't need anything that big unless you want to do alot of tuning for daily driving.
Car: 89 K3500 Fleetside
Engine: RAT *tbi* EBL
Transmission: TH400
Axle/Gears: 3.73-Dana 60
Does your "Camaro" 350 have a roller or flat-tappet cam is the first Q that needs answered.
Axle/Gears: 4.10
It's actually a 91 chevy truck I'm looking to swap out the tired 305 for a 350 out of a 95 chevy truck. The 95 350 has the stock cam. Would I see a difference with a "stock corvette cam"?
Car: 1992 z28 Purple Haze
Engine: 5.7L Tuned Port Injection
Axle/Gears: 3.23 both spinning
For my 2 cents worth, I put a Comp Cams XR264HR cam in my L98. I am running the stock computer and haven't experienced any issues of drive-ability at all. Nice torque gain too.
Transmission: TH400
That's what I thought...you were given four good cams to choose from on the FSC forum, now you also have a comp cam suggestion to choose from.
Any and all will require tuning, running acceptably and running right are two very different things.
Axle/Gears: 4.10
As I said on FSC, I am really only looking for it to run acceptably right now. When I get time and money I will tune it. Also, I wasn't given any choices for cams on FSC of ther than stock. That's why I came here.
Transmission: TH400
I quote,
"Grab one of the four cams listed in the other thread, get it running then get it tuned.
Life will be good"
Thread referenced: http://www.fullsizechevy.com/showthr...aders-Question
Are you blind or just that hard-headed?
The question is rhetorical.
Life will be good"
Axle/Gears: 4.10
Considering I never posted on that thread, I guess you're the one that's blind. I know you referenced it but on there you say you can install one of those cams with no problem and on mine you say a tune is necessary for everything. Are you that much of a tard you don't realize what you wrote? I'm done with this crap. Figuring things out for myself will be easier than this.
Transmission: TH400
No, you didn't post on that thread you were sent there to READ it.
The other poster was also told "If you don't want to be changing anything then don't change the cam"
NO I will not just give you the answer that you WANT to hear.
Your in a "GIMMIE" zone that will not get you far.
The computer loving a cam only means the cam is not outside the ECM's ability to be tuned for it. Ppl changing cams & not re-tuning for them are blissfully ignorant of their potential.
As always tuning is the FIRST step in developing optimum output from a computer controlled engine, whether you like it or not, and especially important once you begin to modify the engine.
junkcltr
08-02-2019 11:12 PM
